Customs MOTHER of LOWERING threads
Discussion in 'The Hokey Ass Message Board' started by The_Monster, Apr 20, 2014.
  1. motoandy
    motoandy
    from MB, SC
    cody ellingson likes this.
  2. ewob53
    ewob53
    from Minnesota
    1-1/2 coils all the way round. ImageUploadedByH.A.M.B.1404180530.996741.jpg
    MOTOV8N likes this.
  3. el_bole
    el_bole
    What year Ranger where the shocks? I got a similar truck that I want to have same stance as yours
  4. Dreddybear
    Dreddybear
    I think from 80's. You'll need to buy or make locators to straighten them out...
  5. 41FordVert
    41FordVert
    4" dropped axle front / 3" blocks rear. Next step is to lower the camper... ImageUploadedByH.A.M.B.1404182576.620459.jpg ImageUploadedByH.A.M.B.1404182607.102910.jpg
  6. el_bole
    el_bole
    Thanks for the info!
  7. el_bole
    el_bole
    Thanks bro....forgot your quote...
  8. The_Monster
    The_Monster
    Thread update! anyone else want to chime in?
  9. uglysteve
    uglysteve
    Cool thread! Let's see more!
  10. FrankenRodz
    FrankenRodz
    All Fab!
    The ch***is sits 7" off the ground @ stock height, while I channeled the body over it.
  11. HOTRODPRIMER
    HOTRODPRIMER
    Stock frame but with a Model A front cross member,reverse mono front spring and 4" dropped axle. HRP
  12. BLUDICE
    BLUDICE
  13. mgtstumpy
    mgtstumpy
    Before and after. I got ride height to 6" front and rear.. Big drop in height when you compare centre of rear axle to sill in before and after shots. Made a jig to set up ride height and modified ch***is / suspension to sit just right.
  14. Jrockbass
    Jrockbass
    ImageUploadedByH.A.M.B.1434159230.916071.jpg Mono leaf spring in front. Gonna take it down lower soon.
  15. SmokinBill
    SmokinBill
    2" spindles and 1" drop coils in front and 2" blocks in rear with the old worn leafs.
  16. odass
    odass
    from se ok
    2.5 spindle and a coil cut in front
    5" spring in rear, thinking about pulling the 5" for a HD 4" and a 2" block so I can haul better 20150612_145744.jpg
  17. waldo53
    waldo53
    from ID
    3" Sid's axle, plus 3 leafs removed in the front, 2" lowering saddles plus 2 leafs removed in back. I've had 2 other rigs with MII setups - this one rides and handles just as good, maybe better. Stick with "old school" boys!!! Lakeview Park, Nampa, ID, 6-6-15, Best of Show, Idaho Chariots award.jpg
  18. twin city knight
    twin city knight
    2 coils off all four corners and 2" drop spindles from speedway's disc conversion kit with 14" g-body steelies (until I can find some effing 4.75" 15" steelies--where'd they all go??)
    Rides good, exhaust hits before the bump stops so I just use the pipes like curb feelers for the undercarriage. needs shorter shocks in the rear.
  19. 28TUDOR
    28TUDOR
    image.jpg 4" drop axle in front coilover in rear.
  20. 100% Matt
    100% Matt
    Cut coils up front 3" blocks in the rear. Rides real nice
  21. creepyjackalope
    creepyjackalope
    Cut 2 coils front and rear.
  22. john mullen
    john mullen
