Vintage Tach Collectors Show and Tell
Discussion in 'The Hokey Ass Message Board' started by scottrod2, Nov 25, 2007.
  1. Here is an odball tach/va*** gauge that belongs to a friend. it is huge like 5" across.
    And a sloppy pic of my stewart warner green line that I intend to put a newer movement in so that I can use it. I keep the green line on my desk to remind me that i need to get off my big *** and do something.
    falcongeorge likes this.
  2. DeLuxe 32
    DeLuxe 32
    That's Nice, I do like the 4 digit gauges...
    Here's the one i'm using in my '32 sedan...
  3. Frenchie  1
    Frenchie 1
    from Colorado
    My dad had a 67 fairlane lightweight clone with a original rotunda tach that i believe was correct for the car. we are kind of curious on the value of it
  4. bobbytnm
    bobbytnm
    Here's mine. I think its a Dixco
  5. patinamonster
    patinamonster
    Hey guys,
    Maybe you all can help me ID this tach I got off eBay last week. There's no identifying marks from the outside and the seller didn't really have any information either.
    It's a plastic housing with no clear sign of where (if anywhere) it'd open up. My guess is that it's maybe late 60s/early 70s, but that's just by looking at the style and the materials. Green, red, and black wires (tach signal, power, and ground).
    On the back is a selector for 4, 6, or 8 cylinders. The hole in the center is threaded and the hole in the lower left has a small phillips screw in it, but doesn't seem to do anything when I back it out.
    Any thoughts whatsoever would be helpful. Thanks!
  6. thunderplex
    thunderplex
    In my 1956 Ford Mainline.
  7. Rick 5150 69
    Rick 5150 69
    from N Calif
    Kev posted this, the tach in the upper left, green line tach anybody have a clue to its MFG, I picked one up cheap for a in dash project, just need to confirm wiring, black, red, green.
  8. upspirate
    upspirate
    Old Mopar factory console tach....last used in about 1978 on my old ,73 GTO
    Going to put on E-Bay
  9. Does anybody know what year approx. this is from? And why does it have 2 red needles?
    Sorry, I don't know how to attach the pics from that post, if anyone can tell me how to do that I would appreciate that help also.
  10. ROADSTER1927
    ROADSTER1927
    That tach is from the fifties and the red needles can be moved to set your high and low limits of your power band.:)
  11. sedan33
    sedan33
    This is a SW Green Line 2 5/8 in tach from the 60's that I am using in my 33 Ford.
  12. midnightrider78
    midnightrider78
    Can anybody identify this one? I posted when I first got it a couple years ago and nobody could say with any certainty. It has no markings other than "made in USA".
  13. PSB
    PSB
    My Old 55s tach..The cool part is the needle fit the modern staff of the modern guts. This was a old cable tach.. And now with lights. My 55 and I have been together since high school in 70-71.
  14. jarhead
    jarhead
    Here is my Stewart Warner Pedestal Mount. What vehicles would this tach have come with?...
  15. chubbie
    chubbie
    Looks like a REC
  16. midnightrider78
    midnightrider78
    I looked up RAC tachometer and it appears that is indeed what I have. Thanks!
    Do you have any idea what time period this particular tach is from?
  17. chubbie
    chubbie
    Early-mid '60s
  18. SimonSez
    SimonSez
    I don't recognise that tach, but if you don't get any other info ...
    The green wire is usually the trigger so would run to the -ve terminal on the coil, red to a 12v (ignition) power source and black to ground.
  19. tjet
    tjet
    Late 60's Jones mechanical tachs - one has a rev limiter & the cable splitters. Both have the key reset. The Sun tachs are also from the 60's. Note: The RPM #'s on that magneto rev limiter are distributor speed. Max "engine" RPM is 15,000. It is factory set at 7200. I had it tested & calibrated by the OEM
  20. c322348
    c322348
    From my collection; Stewart-Warner 760 Series Tach Brochure dated December of 1958- for your perusal, education and amu*****t:
  21. PSB
    PSB
    I had not seen the add for these SW before to Cool! thanks. here is the one in my 55. Boy its hard to post photos on here.. They keep coming back not up loaded.. I had better photos but will not take them... Enjoy
  22. c322348
    c322348
    I had to resize my photos to make them smaller- 700x600 pixels or such. Otherwise it won't upload the photos.
    Posted using the Semi-Custom double throw-down H.A.M.B. App, now 20% shinier than before.
  23. PSB
    PSB
    Thanks.. Going to google this semi custom double throw down app.. Al though I am not one for apps.. But love this site!
  24. c322348
    c322348
    What kind of drive mechanism do you have for the tach?
  25. PSB
    PSB
    The add above shows it to be electric.. mine is/was mechanical. But after 29 years of storing my 55. I now use a modern MSD Electrics. So I used modern in sides with a staff that fit the old stock tach needle. came out nice. I love it.
  26. Old-Soul
    Old-Soul
    In the mid 50's through the early 60's, what were common mechanical tachs one would see? I'm building a 265 for my coupe and will be running a Mallory dist w/ cable drive.
  27. Gman0046
    Gman0046
    Looking for 63/64 Chevy factory tach without the mount.
  28. c322348
    c322348
    Just like in the brochure I posted, there were mechanical versions of both the tach and speedo that didn't have the extra blob on the back as used in the electric ones.
  29. SimonSez
    SimonSez
    I bought this one at a swap-meet a few years ago.
    It is made in New Zealand and pretty rare I would think - I have never seen another one like it.
    sko_ford likes this.
  30. cornfed74
    cornfed74
    from Washougal
    One I found in a friends grandfathers loft. Unfortunately he is not around anymore so I dont know what its out of. Any ideas of an era? I would love to find a matching temp gauge for it. IMG_0470.JPG IMG_0471.JPG
