Features Falcons done right?
Discussion in 'The Hokey Ass Message Board' started by guiseart, Nov 20, 2005.
  1. Flootiebuell
    Flootiebuell
    Getting ready for paint as soon as my motor and trans arrives...playing with a few ideas for the wheels, brushed lugs and silver center. Also working a few options on the handles and trim...going for an aluminum look which will also be done on the bumpers.
    droppedstepside and Phillips like this.
  2. Falcon61wagon
    Falcon61wagon
    from Indiana
    Got to take my brothers 63 for a spin on Sunday. My wagon is still on jack stands and going to be there for awhile. ImageUploadedByH.A.M.B.1403065966.077977.jpg
    Posted using my Big THUMB on a small screen!
    droppedstepside likes this.
  3. sdg
    sdg
    Great ride height. Looks good!
  4. No_Respect
    No_Respect
    from So-Cal
    Quick Question actually its a two parter. I heard that strut rods were not suppose to be reused is that true? I have mine off and one of them has slightly striped threads in the middle and question reusing them. My second question is about the bushings. I bought the energy bushings for the strut rods but they are so thick do they work good? I heard they were stiff so I was thinking I could use half energy bushings and half rubber, would that work?
  5. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    You can reuse strut rods, no problem, long as they aren't bent; but I'd bee leery of threads that were stripped because that could make adjustment difficult.
    I dunno' about the brand of bushings you're talkin' about- I used Dennis Carpenter bushings on mine.
    The new ones were way thicker than the worn out old ones.
    Here's a shot of my bushings (with new not bent strut rods) from a couple of years ago:
  6. gimpyshotrods
    gimpyshotrods
    That's a new one, with no basis in fact. They are not a wear item. Unless damaged, there is no need to replace them. It does sound like you have a damaged one, though.
    What year is your car? Later Falcons have the same strut rods as Mustangs, so yo can just get new ones, in that case for the damaged one, or both.
    Do NOT use polyurethane bushings on the strut rods. They prevent suspension movement when used there.
    If you have a roundbody Falcon, I don't believe that Energy Suspension even has a part number for these, and later ones will not work. They are too thick, and have a different inward profile.
    Also, if you have a roundbody Falcon, there is supposed to be a steel sleeve inside the bushings. If that is missing, and the bushings are worn, that may have allowed the rod to come in contact with the ch***is bracket, causing wear to the threads, and the ch***is bracket.
    If that is the case, you should repair the bracket, and replace the strut rod.
  7. Falcon61wagon
    Falcon61wagon
    from Indiana
    Does any one know if a new plastic insert, like this one, is available for the deluxe fomoco fender mirror. ImageUploadedByH.A.M.B.1404149971.975079.jpg
  8. Leon Sandcastle
    Leon Sandcastle
    Dearborn cl***ics, falconparts.com, Mac's all may have the emblem. Not sure though.
  9. 90awdeclipse
    90awdeclipse
    from Us
    I love the way your brothers car sits. Can I please get some specs on suspension?
  10. 64T-bolt
    64T-bolt
    from Kansas
    I posted my '60 a few years back, but its been updated since oiling down mokan at the HAMB drags in '12.. It's now sporting a dart iron eagle 331" with iron trick flow high ports, solid roller, shaft rockers and a GMC 6-71.. Still has the toploader.. Put down 794 at the wheel and weighs 2330#. ImageUploadedByH.A.M.B.1404414832.493446.jpg ImageUploadedByH.A.M.B.1404414848.598948.jpg ImageUploadedByH.A.M.B.1404414863.516996.jpg ImageUploadedByH.A.M.B.1404414877.841702.jpg ImageUploadedByH.A.M.B.1404414895.480093.jpg
  11. Evilfalcon1961
    Evilfalcon1961
    from Ma
    that thing is a monster ! love it
  12. Inland empire hot rods
    from so cal
    Love that blown falcon!
  13. Falcon61wagon
    Falcon61wagon
    from Indiana
    Instead of cutting 50 year old coils he bought 3" drop coils from Dearborn did the Shelby drop, running 5.60-13 tires all around, and 3" blocks in rear with 3rd leaf removed in a 5 pack leaf. Cut down the bump stops and air shocks in the rear. Rockers are about 5 1/2" off the ground.
  14. Leon Sandcastle
    Leon Sandcastle
    I'm going to be doing some lowering and suspension upgrades to help with driving my otherwise stock 62 4 door. I'm going to drop it 3 inches with the help of front coils from Dearborn and blocks. I am doing the "Shelby Drop" and doing the bearing upgrade on the spring/shock mount up front. New steering and suspension replacement parts. Frame reinforcement and connectors. Export Brace and Monte Carlo Bar. Anything else suggested?
  15. gimpyshotrods
    gimpyshotrods
    Add adjusters to the lower control arm mounts, so you can get a proper alignment.
  16. 61falcon
    61falcon
    a photo from early spring
    falcongeorge likes this.
  17. MRK
    MRK
  18. skipperman
    skipperman
    Here's my 65 .... Ain't done yet but GETTIN' THERE !!! Shelby drop, HOT 289,konis,bars, etc, etc ... etc .... falcon020.JPG falcon019.JPG
  19. ffej
    ffej
    That's quit the list. Are the frame reinforcements and the export/monte Carlo bars really necessary for just a lowered car. I know it's worth it if you plan to race the car but seems a lot for cruzin
    1963 Ford Falcon Sedan Base.
  20. Leon Sandcastle
    Leon Sandcastle
    stiffer ch***is makes better cornering in my opinion
  21. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I dig the "R" apron.
    I always have wondered why the bottom third of the radiator was covered by the bumper on Falcons...
  22. Veach
    Veach
    My 60 Falcon Wagon only the Body is stock She has a 347 around 500 Hp Comp Thumpr Cam 521/507 Lift Roller Engine a TKO 5sd Trans and a Currie 31 spline 389 geared Truetrack 9" rear end. A Strange seamless 3" Chrome-Moly Driveshaft with Solid 1350 U- Joints. A Rod&Custom MII rack and pinion that I had to do some work to so it would fit. Custom motor mounts so I could move the engine back a couple inches. 4 wheel power disc brakes and Strange Adjustable coil overs on all corners. A custom 4 link setup and custom sub frame connectors. Custom transmission crossmember and mount. Doug's Try-Y Headers 2 1/2" Flowmasters Delta Flow 40 Dual Stainless Steel exhaust system system with an X pipe. I used a lot of parts from a 95 Mustang. A trick price I used was the brake and clutch ***embly out of the 95 Mustang after some modifying of the brake peddle to clear the steering column it bolt right in giving me a clutch ***embly that I can get parts for anywhere. I have learned a lot Building this Falcon if anybody is Building anything close to it I sure wish you would tell me what you have done. I would love to here your stories so I can learn even more and any info I can help you with I'm more than willing to share with you ask away. Thanks Veach
  23. JohnnyP.
    JohnnyP.
    Well, finally did some things to my wagon. First pic is of the stock ride height. Then did the 3" blocks in back, and shelby drop w 1-1/2 coils out up front. Next I got stock 63 lenses, sunk them in behind perforated aluminum. And last, I removed all horizontal bars in the vertical lines on the grill. More small changed to come.
    ImageUploadedByH.A.M.B.1406520468.659288.jpg ImageUploadedByH.A.M.B.1406520486.610006.jpg ImageUploadedByH.A.M.B.1406520520.927797.jpg ImageUploadedByH.A.M.B.1406520572.792101.jpg
  24. Evilfalcon1961
    Evilfalcon1961
    from Ma
    My 63 squire I just finished up
  25. Ian hall
    Ian hall
    from Uk
    Here's my 65 sprint
  26. need louvers ?
    need louvers ?
    Damn Ian, that is nice! Wheel and tire sizes please?
  27. Ian hall
    Ian hall
    from Uk
    They are 15x7" American racing with 205/70 tyres
    Whilst it looks great, it is a little too low at the front, power steering hoses very close to the ground and it bottoms the suspension over pot holes(we have plenty here!) I intend to get another pair of gt springs and cut a little less than last time
    Ian
  28. Ian hall
    Ian hall
    from Uk
  29. fca2572
    fca2572
    from Texas
    Ian did that car come out of Texas ?
  30. Ian hall
    Ian hall
    from Uk
    Yes the previous owner got it from Texas, do you know of the car?
    Ian
