Technical Let's see your T-5 shifters
Discussion in 'The Hokey Ass Message Board' started by mr57, Jun 18, 2014.
  1. mr57
    mr57
    Like the ***le says, let's see your shifters, mild to wild. Also, what you got on top of the shifter? I didn't really want to say - "Show me your knob"... Also, anyone know where to get the spacer to shorten up the throw on the shifter??
  2. mr57
    mr57
    Nobody has a T-5 shifter???
  3. LAROKE
    LAROKE
    This is what I have in my '37
  4. simplestone
    simplestone
    Here is a pic of mine in my 51 chevy truck (no knob yet). I created a short throw and made my own spacer out of a hard rubber/plastic cutting board. It was exactly 1/2 inch thick so I doubled it and used transmission rtv between the two. Not saying that's the way to go - that's just what I did.
  5. NMCarNut
    NMCarNut
    I wanted the 3-speed look in my 36 Ford. Chopped off the T5 shifter, bored a 1" deep hole in the nub, and then welded on a cut off Ford shifter with the end turned to fit the bore. Shifter.jpg ShifterInstalled.jpg
  6. HOTRODPRIMER
    HOTRODPRIMER
    This is the shifter in ladyharp's Ranch Wagon..
    The Hurst shifter was originally in my 63 1/2 Falcon Sprint and it had been under the work bench for over 40 years.
    All I did was clean it up and cut the shifter off the shifting mechanism where it was welded and drilled 2 holes to mount it to the T-5 transmission. HRP 54Wagon006.jpg
    The shape of the old shifter fit perfectly.
    sko_ford and 2many projects like this.
  7. Turbo26T
    Turbo26T
    DSC01167.JPG Here's mine...its a Longacre lever / Jeep boot/fab'd floorplate
  8. Mr48chev
    This is turning out better than I first thought when I saw the ***le. Some workable ideas there.
  9. green73
    green73
    If you had to do any modifications, please lets us know what you did like NMCarNut did (spiffy setup by the way). I was gonna drop the coin on the shifter from Johnsons Rod Shop. It has a nice look to me, but after seeing it in person, I think it would be a little too short for my '40. I'd like to see the the Limeworks shifter in a '40. If that one has similar dimensions I may look more closely at NMCarNut's idea.
  10. HOTRODPRIMER
    HOTRODPRIMER
    When I was in the building stages of the wagon I made a shifter from a piece of 3/4" round stock and heated and shaped it to contour with the seat when it was in 2nd,4th and reverse but after the seat runners were repositioned I was able to do away with the belly in the shifter. HRP
  11. scrap metal 48
    scrap metal 48
    "MR 800" shifter.. Pic is a little dark, sorry... cal cust & shifter 001.JPG
  12. gcrod
    gcrod
  13. gcrod
    gcrod
  14. gcrod
    gcrod
