Hot Rods 1937 Chevy Coupe Grill
Discussion in 'The Hokey Ass Message Board' started by Chuck G, Jul 7, 2014.
  1. Chuck G
    Chuck G
    I must be stupid. :) I recently bought a 37 Chevy coupe street rod semi-project car. It has the factory grill. It was missing the crank hole cover, so I ordered one for the 37 p***enger car from The Filling Station.
    Came today. Can't figure how it mounts.
    Anyone know? Am I missing a hinge or some other mounting device for it?
    TIA.
    Chuck
  2. oldolds
    oldolds
    From factory there was a spring steel clip that held them in. I know the repro 39's are set up to be bolted and not removable.
  3. Yeah, if it looks like this it snaps in.
      943 bytes
      822 bytes
  4. Chuck G
    Chuck G
    My cover is simply a stainless steel "U" shaped gizmo, about 4" long. It's actually wider than the grill itself.
    I'll post some pictures.
  5. Chuck G
    Chuck G
    Here are a few pictures.
      136 KB
      149.5 KB
      76.4 KB
      127.7 KB
      122.1 KB
  6. raymay
    raymay
    I have the same problem. The repros are not shaped like the originals. Years ago I did have an original one that either fell out or got stolen. Looking for a more permanent way to attach without using a stainless screw like I have seen others do. I will be watching your thread for ideas. I have a friend that does excellent work on repairing stainless. May take it to him this winter if I decide to take my grille out or I could try holding it in place with a good metal adhesive. Until I find a good solution my cover sits in my glove box.
  7. Chuck G
    Chuck G
    You're in the same boat as me. :)
    If you look at my pictures, I already have a screw in the grill, but this crank cover isn't long enough to utilize that screw and cover the opening.
  8. Stu D Baker
    Stu D Baker
    from Illinois
    Not for sure, but I would imagine that there are some "tangs" that can be bent over the back side to hold it solid. Stu
  9. Chuck G
    Chuck G
    I'm bringing this back TTT as they say, as I have solved the problem, and wanted to p*** on the solution.
    The problem was that "The Filling Station" sells a one size fits all crank hole cover. That's the one that did not fit.
    I was looking through the "Chevys Of The Forties" catalog, and they listed one cover for a stock grill, and one for an aftermarket grill.
    I ordered one for the stock grill, and it fits just fine. It has pinch-on ribs on the top, but I added the screw, as I figured it would pop off if I didn't. It wouldn't lay flat with the screw that holds the center grill bar anyway. :D
      68.8 KB
      127.4 KB
      137.2 KB
      96.5 KB
      75.2 KB
    lothiandon1940 likes this.
  10. That's what so great about this forum, problem found, problem fixed, information p***ed on !!!!!!!!
