Projects ****50 mercury build**** sweet memories.
Discussion in 'The Hokey Ass Message Board' started by ryno, Sep 22, 2013.
  1. venturesomerite
    venturesomerite
    from CT
    Looking good, I love the speed hole everywhere.
    I wish I had a lift to transfer the body on and off my ch***is, must make it real easy!
    Any pics of the dolly you had the body on for a while?
  2. 63Compact
    63Compact
    Looking good Ryno.
  3. john51mer
    john51mer
    Looks real good man good work
  4. ryno
    ryno
    welcome...thank you
    ask away. thanks
    yes a lift is very handy!
    i will get you some pics of the cart in the next few days.
    thanks fellas
  5. ryno
    ryno
    been slow at updating this , with weather, sickness and other projects.
    but here is some pics and updates.
    got the housing cleaned up alittle, it looked like the axle pads had been moved a few times in the past on this housing,so there was some gouges to fill, fully welded on the axle pads, and got it narrowed.
    pinion is now centered in car,instead of the stock 4"offset.
    new moser axles.
    also got the new "tanks" gas tank installed. fab'd up a front hanger, basically mounted it like the stock one, but it now goes up to the new x member, and had to clear the pan hard bar. had to also clearence the rear frame alittle, the new tank has reinforcement plates at the mounting points that where not allowing it to align up properly.
    JRussell and FXMike like this.
  6. chigger
    chigger
    Im digging the frame. Did you pin the trailingbarms to the axle pads? I ***ume using the 2 link will eliminate the need for excessive floor pan cutting required in using a 4 link?
  7. ryno
    ryno
    thank you
    yes the rear arms will get locating pins, just like a leave spring. i will do that next time the body is off and i can get a better shot at double checking the wheel base.
    yes this link set up does not require a lot of floor to be cut out, only made 2 cuts for the arms to clear the floor.
  8. ryno
    ryno
    been slowly chipping away at this project. got started on shaving the body clean.
    fuel door, wipers, door handles, side trim, moving the taillights down, firewall all cleaned up and devoid of factory parts.
    JRussell likes this.
  9. Sprout
    Sprout
    great progress
  10. Looks amazing, Ryno!
  11. tikiwagon13
    tikiwagon13
    Ok, so now I'm really chomping at the bit to get started on mine, just waiting for the snow to melt so I can get it into the shop. It's a whole lot rougher that this one, I'm bagging it and was going to go with a 4-link but I like the fact that with the 2-link there is less work to do on the floor.
  12. ryno
    ryno
    thank you
    thanks jake
    the 2 link set up works really well for a custom like this. if your building something more hi performance there is better options out there, but for a cruiser that will handle good, its hard to bet a 2 link set up like this.
    stay tuned, hope to be back on this project next week after the round up..
  13. ryno
    ryno
    sorry for the relay in updates....
    got the front shock mounts fab'd up and welded.
    rear shocks, tower is 1 1/2" tubing, with 1/2 id dom sleeves for the upper, lowers are bolted to speedway u bolt plates.
    started prepping the floors for new sheet metal covers. lots of thick undercoating.
  14. 55 dude
    55 dude
  15. engine138
    engine138
    from Commack NY
  16. ryno
    ryno
    thanks fellas.
  17. ryno
    ryno
    the car is set up for a sbc and turbo 350. as mentioned i custom made all the amounts. with the frame completely laying flat on the ground i had to raise up the engine and transmission. the stock transmission cover bolts to the floor, with co**** sheet metal screws and 10 gallons of undercoating!
    the idea was to make the stock one fit like factory , but work for our new drive line.
    the cover will now bolt in with nut serts and some kind of cool fastener.
    it will be body worked,painted, and pinstriped to match the body.
    stock set up. old floor shifter hack job.
    top cut out to fine tune our clearance
    finished up
    JRussell, REVEREND JAKE and DougO68 like this.
  18. ryno
    ryno
    got the rear end notch cover done.
    bead rolled, broke and welded into the car.
    careful planning, lots of lines..
    nut serts for the air tank
    REVEREND JAKE likes this.
  19. ryno
    ryno
  20. ryno
    ryno
    been plugging a way on the ol girl. running 9 of the normal 11 de soto grill teeth. we didnt have a de soto pan either , so i had to custom roll one out. front fender and grill welded into one piece. it will be getting 56 olds headlight rings.
    JRussell, REVEREND JAKE and FXMike like this.
  21. leadsled
    leadsled
    keep up the good work.
  22. 36 ROKIT
    36 ROKIT
    Nice sheet metal work!
  23. FXMike
    FXMike
    Nice work...new here!
  24. ryno
    ryno
    thanks guys, keep posted, we are back on this project so ill post up some more progress pics as it happens
    travisfromkansas likes this.
  25. rockable
    rockable
  26. chaddilac
    chaddilac
    Any more updates?
    ryno likes this.
  27. ryno
    ryno
    hoping to keep on this now, through the finish...
    extended the stock bumper to fit a std size plate and removed the over rider bar, welded the bumper bolts up, ****ed in the bumper tighter to the body, removed the lower valance.
    started on the headlights. decided to go the frenched look. used speedway repo 52 merc rings. took the stock buckets and modified the face of them clean, mounted them from the rear,s o you can change a head lamp ***embly if need be, or make adjustments.
    weld in bolts, cause you will not be able to reach the front once the rings are welded on.
  28. ryno
    ryno
    moved the stock rear taillights down 2 3/8" will be a subtle modification, that will most likely go unnoticed, unless you know mercs!
    TheMerc, dana barlow and Sprout like this.
  29. Sprout
    Sprout
    Want to do that to mine
