1948 Dodge 3 Window
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by skelly, Nov 20, 2007.
  1. skelly
    skelly
    Just purchased 48 dodge 3 window coupe. What to do? I would like to keep it Mopar. Will anything subframe under it. Someone mentioned a early 90's Dakota pickup with a 318. Any help would be greatly appreciated Thanks
  2. Circus Bear
    Circus Bear
    Welcome to HAMB.
    I am building a 47 3 window coupe with a 383 big block. Small blocks are defenitely cheaper and easier to put in. Tex smith has a great book on building mopars. It's out of print and about $75 - $100 on ebay. I lucked out and found one at a swap.
    A small block will fit easily it you build it like Ma Mopar always did and offset the engine to the p***enger side by an inch or so. You should clear the steering box that way. I think small block dart exhaust manifold will clear the steering column also. Feel free to PM me and I can try to dig up the book and look a few things up for you.
  3. jbchevypower
    jbchevypower
    circus bear is right i put a 440 in my 48 3 window used a p***enger exhaust manifold for the driver side so the dump is in the front and set the motor center and 3 inches back on custom motor mounts on a k frame
  4. porky55
    porky55
    I got a 53 with a Dakota sub frame. It lines up nice. Check out fargo52's build he gave me the idea. Good luck and have fun
