Projects whats your favorite vote
Discussion in 'The Hokey Ass Message Board' started by RatrodKevin, Jul 9, 2014.
  1. RatrodKevin
    RatrodKevin
    i cant make up my mind i got one frame and two bodys a 1929 coupe or a 31 roadster witch one should i build!!!!i cant sleeeeeep!!!!!
  2. I see that you are in Los Angeles. I would go with the '31 roadster. The coupe would be good if you lived in an area that had a lot of rain or was very cold.
    Charlie Stephens
  3. gimpyshotrods
    gimpyshotrods
    '31 roadster.
    I will be down to pick up the '29 after Bonneville.;)
  4. ric
    ric
    Roadster.
  5. fortynut
    fortynut
    Trade that darn coupe an' ol' frame for a decent enough deuce frame to make something out of, an' be a man not a rat, an' act like a real hot rodder and build a highboy your mama would be proud to see you in acomin' up the driveway with her presents on mother's day, her birthday, and Chris'mas. Somethin' you can attract the opposite *** with when you wail around the local Milkshake and burger joint. If that's your kinda thang. Your nex' post should be what kinda motorvation you'll be usin' to power this mos' pleasent of surprises for all the little rodents who will wonder if you done turned traitor and joined the beach house crowd. An' if you got complexes about choices, keep in mind any jackhole worth his sideburns knows coops is for chickens.
  6. big duece
    big duece
    from kansas
    As cheap as model A frames are, I would build both.
    kiwijeff likes this.
  7. Dirty Dug
    Dirty Dug
    I've always said, if you're going to have just one hot rod, it should be a roadster.
    You'll be glad you did.
  8. BORRACHO13
    BORRACHO13
    from Menifee CA
    i will gladly take the coupe of your hands if you need the help :D;)
  9. burnzy37
    burnzy37
    Geeez....what a predicament...;):D
  10. lothiandon1940
    lothiandon1940
    The first thing I would do is change my screen name.;)
  11. Coupe, weather be damned.
  12. brady1929
    brady1929
  13. 69fury
    69fury
    from Topeka
    coupe -because you cant chop a roadster! -rick
  14. rag top 012.jpg It's always "Roadster Weather" even in Wisconsin, California should be a no brainer.
    Say What!!! Windshield gl*** is 7 & 1/2 inches
  16. Austinrod
    Austinrod
    from Austin
    Roadster!!!!
    Posted from Austinrod
  17. Blacktop VooDoo
    Blacktop VooDoo
  18. HOTRODPRIMER
    HOTRODPRIMER
    Both make cool cars.
    Build the coupe now and find a Deuce frame for a hiboy roadster on down the road. HRP
  19. MAD 034
    MAD 034
    from Washington
    Early A coupes are awesome -- build it.
  20. 56don
    56don
    How could you NOT build a roadster if given a choice??
  21. Rusty O'Toole
    Rusty O'Toole
    Need more info. How tall are you? How much do you weigh? How old are you?
  22. F-6Garagerat
    F-6Garagerat
    **** I'd build the roadster if I lived in Alaska! ;)
  23. Saxman
    Saxman
    I have two girlfriends, both hot models. One is a brunette and one is a blonde, which one should I sleep with?
  24. ssrs71
    ssrs71
  25. 50Fraud
    50Fraud
    '29s are cooler than '31s. The coupe wins.
  26. need louvers ?
    need louvers ?
    That one is easy! The brunette!!!
  27. big duece
    big duece
    from kansas
    If they are indeed both "girlfriends", you can have both...
  28. RatrodKevin
    RatrodKevin
    thanx guys!!! roadster won!!! new it!!! the drive train will be the 241 hemi on my profile pic...(supercharged vs-57) included!!!
  29. HellsHotRods
    HellsHotRods
    Make mama proud!!!! And get rod of the rat rod mentality
