Projects Plan II - 62 Chevy II Drag Car
Discussion in 'The Hokey Ass Message Board' started by squirrel, Dec 27, 2013.
  1. Exposed hinge....thats what I like about racecars...ya makem easy to work on....mine has a couple "access panels"...
    1Nimrod and els like this.
  2. squirrel
    I got my "circle track" hinges made, and the pins installed. Now I need to do some body work. What fun. It never ends!
    1Nimrod, els and redlineracer42 like this.
  3. jerry
    jerry
    I think the "circle track" hinges fit the character of the car and the era build style.
    jerry
  4. Perfect!
    els likes this.
  5. Nice solution Jim. Looks right and almost nothing to re-build if you opt for an alternative solution. Really enjoyed the ride. Knock their socks off at the big event!
  6. squirrel
    Thanks, I think it'll work ok. Bondo today....primer and sanding tomorrow.
  7. mad mikey
    mad mikey
    GO GO GO !!!!!!!
    els likes this.
  8. squirrel
    Hood is done. The color matches just fine, I didn't wash the car, which is really dusty, except for the hood. Got the new rear tires on, still waiting on the new older front wheels, which will get 6.00-15 tires on them. I need to get the slicks mounted too.
  9. 69fury
    69fury
    from Topeka
    Looks great- at first i didn't think i'd like the exposed hood hinge idead, but it came out great- did you make or buy them somewhere- i've been trying to figure out what i'm gonna do with my falcon and might have to copy your idea, if you dont mind, and if i promise not to show up to prom wearing the same outfit.-rick
  10. squirrel
    I just made the hinges, from 1/8 x 2" steel strap. Welded two pieces together (to resemble a piece of angle iron) to make the part that bolts to the body, it just sits under the fender bolt. I welded the piece on the hood, it ties into the new round tube bracing that I used to replace the original inner structure. Original hood weight was around 50 lbs, now it's around 25 lbs.
  11. swade41
    swade41
    from Buffalo,NY
    That car has came a long way, where are you going to carry your stuff on Drag Week ?
    els likes this.
  12. squirrel
    In the extra long trunk. Might head up to Tucson with it tonight to test-n-tune, if I get all the wheel/tire stuff sorted out, and the weather isn't too bad. I need to try driving it to the strip with all the **** in the trunk, and see if I can make it work.
  13. squirrel
    I went to the strip friday evening, but the racing was cancelled. So, I headed into town, visited my mom, met up with a friend, etc. Drove home thru a serious thunderstorm..about 70 miles of wet. Car ran fine, handled OK, although I'm not used to skinny bias ply tires, short wheelbase, and high profile. I kept a firm hand on the steering wheel at all times. Pic of it loaded up with slicks, tools, parts, jack, etc. Rear sags just a little, but the tires won't rub anything.
    When I was driving around Tucson it was around 100 out, and there's traffic, so the engine got a bit warm. A little over 230. Not boiling, but warm enough to make me want to put a shroud on the fan. So that was today's project.
    winr, Desoto291Hemi, 1Nimrod and 3 others like this.
  14. jerry
    jerry
    Nice shroud.
    jerry
    els and FlynBrian like this.
  15. pila38
    pila38
    Been following this thread since the beginning. The car looks GREAT with that wheel and tire package.
  16. chessterd5
    chessterd5
    from u.s.a.
    Very impressive!
    els likes this.
  17. captmullette
    captmullette
    need a video when you go to the track.........cool build
    els likes this.
  18. squirrel
    there's one video already, but I need to get another with the new tires on it. I might head up again Saturday and see what happens.
    1Nimrod, els and kiwijeff like this.
  19. You've obviously nailed the setup Jim. Watching your video inside the car you moved the steering wheel less in that 10 second quarter than I have to pulling away from a stop sign in my Caddy. Excellent execution in an incredibly short amount of time. Ever consider doing one of those "build a car in 30 minutes" TV episodes?
  20. bobss396
    bobss396
    Very cool, one of the best build threads on here.
  21. mad mikey
    mad mikey
    The car seems to run great!! And looks great doing it! Great job, you should be very proud.
    els likes this.
  22. pitman
    pitman
    The engine seems remarkably stable, in the 1-2-3 shift sequence.
    Great to get a sense of how well it turned out! Thanks!
    els likes this.
  23. Babyearl
    Babyearl
    I am really impressed with the build and video,, straight as an arrow.
    els likes this.
  24. squirrel
    Thanks! I was really surprised watching the video, how straight the car went. I was pretty worried about it, I never built a 10 second drag car before, and this one is kind of wild.
    That run was on radials...we'll see what happens with the old fashioned tires. My guess is it'll get squirrely
  25. alumslot
    alumslot
    Great car for sure. When you run DW are you going to run the drag radials or as you say the old fashion tires? I under stand it's a 60"s build but why not go fast as you can. I hope you make the whole week have fun and be safe.
    Jim
  26. squirrel
    I plan to run the bias ply tires on drag week
  27. mt94ss
    mt94ss
    Turned out great. Looking forward to your times. Cool ride for sure.
  28. squirrel
    thanks!
    A couple more pics, hot off the press.
  29. J. A. Miller
    J. A. Miller
    from Central NY
    Looking good Jim!!
    els likes this.
  30. belair
    belair
    Love the headers "adverti*****t".
    els likes this.
