Technical flat head t-5 adapter
Discussion in 'The Hokey Ass Message Board' started by christopher 78, Jul 9, 2014.
  1. christopher 78
    christopher 78
    1404930637970.jpg Anyone know what brand t-5 adaptor this is? It is for a flathead.
  2. christopher 78
    christopher 78
    It's for a flathed.
  3. farmalldan
    farmalldan
    from Duncan, OK
    Well, it's just my guess, but doesn't the "MCF" suggest Motor City Flathead
  4. christopher 78
    christopher 78
    I think so too. The engine was built there.
  5. jseery
    jseery
    from Wichita KS
    Looks like the Ford T5 pattern.
  6. christopher 78
    christopher 78
    It is I stated that in the begining.
  7. jseery
    jseery
    from Wichita KS
    If you did I can't find it. There are two different bolt patterns used on Flathead T5 adapters, the most common is the S10 Chevy pattern and the less common is the Mustang and later Chevy pattern. Your adapter looks like the T5 mustang transmission bolt pattern.
  8. christopher 78
    christopher 78
    Sorry I put T5 forgot the Mustang part. Wasn't trying to be a dick.
  9. jseery
    jseery
    from Wichita KS
    Interesting looking adapter, which engine and transmission are you running? What year flathead and which T5 transmission?
  10. Texas Webb
    Texas Webb
    Your in Fredricksburg.Whats it going in?
  11. christopher 78
    christopher 78
    20140709_162350.jpg It's a motorcity flathead. Trans is a world class with a s 10 tailshaft
  12. christopher 78
    christopher 78
  13. jseery
    jseery
    from Wichita KS
    Nice looking setup, that is somewhat similar to mine, except I am running a 59a block with a hogshead and then a similar adapter I made. I'm using a motorsport T5 Z. What rear end gears are you running? I like the 4:11s with the overdrive. Do you happen to know how thick your adapter plate is?
    christopher 78 likes this.
  14. Texas Webb
    Texas Webb
    Boy, that's a nice flatty.
  15. christopher 78
    christopher 78
    The adapter is a inch. As for the gears I'm gonna say they are 4:11.
  16. jseery
    jseery
    from Wichita KS
    I built my plate 1 inch but need to take a little of the end of the T5 input shaft to clear the crankshaft. I thought that was the correct thickness, but thought I would check. Thanks for the verification.
  17. christopher 78
    christopher 78
    Anyone know what pilot bearing to use for a ford t-5 to a flatty
  18. flathead4d
    flathead4d
    I use the same pilot bearing for the original three on the tree trans with mine. Where did you get the MCF trans adapter?
  19. V8 Bob
    V8 Bob
    I am using the same adapter that I bought from Mark (MCF) about 14 years ago. I don't remember if he bought rough castings and did final machining or had someone else make them entirely. They adapt Mustang T-5s to any narrow pattern 4-bolt bell housing, from '49 Ford/'51 Merc up to the mid '60s.
    earlyv8 and christopher 78 like this.
  20. jseery
    jseery
    from Wichita KS
    I'm looking for a pilot bearing at the moment! Was thinking about turning a brass one, but a roller bearing would be nice. I'm sure if I check the dimensions I could find something at a bearing supply house, just haven't tried yet. If anyone knows the bearing number or application it would help.
  21. jseery
    jseery
    from Wichita KS
    Do you know the years/models that use that bearing? I work on early year Fords and don't know much about the later years.
    From what I can find all Ford pilot bearings through 53 are 5/8 inch (.625).
  22. flathead4d
    flathead4d
    Try this bearing number 6203 or 6203Z. I think it the same number, just a different manufacturer.
  23. jseery
    jseery
    from Wichita KS
    Thanks for the input. With out the Z it is an open bearing, with the Z it is a metal sealed bearing. If you care 2RS is with contact rubber seals and 2RZ is with non-contact rubber seals
  24. Flat Ernie
    Flat Ernie
    Tech Editor
    I'm a big fan of bushings vs bearings for pilot applications. It's an abusive environment and the bushings are far less critical than the bearings. Seen more damage done with bad bearings than with bad bushings...ymmv
  25. BRENT
    BRENT
    I agree with Flat Ernie I am a fan of a bushing vs bearing. Nice adapter would have saved me a lot of time and engineering on mine adapter2.png
  26. jseery
    jseery
    from Wichita KS
    Agree on the adapter! I built mine, a lot of work. I may go with the bushing, I have had pilot bearings fail, although it wasn't the bearings fault!!
