Anyone got pics of a 36 dash in a model A
Discussion in 'The Hokey Ass Message Board' started by nailhead29A, Jul 13, 2014.
  1. As the ***le says, I've searched and searched and can't really find much in the way of pics. Going to be installing my dash later next week and would really like to know how some of you guys have gone about this install.
    Thanks in advance..
  2. Anybody????????
  3. 29ToyA
    29ToyA
  4. 29ToyA
    29ToyA
    I think I took both off this site. I was playing with the idea myself
  5. 29ToyA
    29ToyA
  6. brett4christ
    brett4christ
    I'm thinking about the EXACT same thing for the Tudor! Just lovely!
  7. Here is a 37 Dash in my 30 Roadster. I moved it forward of the dash rail. My body is Channeled and I needed leg room. This let me lift the steering column angle some. I'm running a 40 steering box and didn't want to modify the column drop. I cut the top off the dash and made a new flange facing the windshield and bolted in using the Gas Tank bolt holes. I'm building new end pieces curving forward to the A post. The Glove box opens just fine and with the Roadster dash rail trim on it looks right at home. Being it's Flathead powered I'll run all stock gauges as well as mount the starter ****on back where it belongs in the new corner piece.
    The Wizzard
  8. madmak95
    madmak95
    Heres 0119140957~01.jpg 0208141230c~01.jpg the one im putting in m '30.
  9. madmak95
    madmak95
    I just welded it to the stock model a dash header. That way i can bolt it into the stock holes. 0118141203.jpg
  10. fitznstartz
    fitznstartz
    from mesa az
    Sergeant82d likes this.
  11. Sure is Brett, I reckon the 36 dash was just made for an A. Beautiful work guys they all look spot on..
  12. VoodooTwin
    VoodooTwin
    from Noo Yawk
  13. CaliDreamin'
    CaliDreamin'
    "Insert Epic Quote Here"
  14. PurdueSD
    PurdueSD
  15. CaliDreamin'
    CaliDreamin'
    That's super clean. I need one.
  16. Got my dash mounted, just a little finishing work to do. Pie cut the top and changed the radius to suit the shape of the A window opening, cut the original ends off and extended the dash slightly to fit between the A posts as well. Pretty happy with the result, think these dashes were made for the model A, they look perfect in my opinion. ImageUploadedByH.A.M.B.1412762950.525382.jpg
  17. Speedy Canuck
    Speedy Canuck
    How are you going to get the glove box open with the steering column and wheel in the way? :D:D
    Looks really good in there. I have a plan for a 36 dash in a Model A for the next project.
  18. 325w
    325w
    I used 59 Chevy gauges in my 36 tudor. Used the Ford bezels with 59 speedo temp an fuel. Idiot lights for the volt and oil. 36 is the nicest dash out there
  19. madmak95
    madmak95
  20. ImageUploadedByH.A.M.B.1425798444.796105.jpg ImageUploadedByH.A.M.B.1425798533.710004.jpg ImageUploadedByH.A.M.B.1425798559.826610.jpg
    It's been a long time between drinks with work and family life etc, but I've finally got my **** into gear and am Back into the car again. Finally finished off the dash I started ages ago. Filled the panel that usually has large holes in it where the bottom of the window frame seats as well to clean things up a bit. Dash complete, glad to be back into it again. Looking for an ash tray and waterfall as well if someone has one they want to sell..
