Projects The pressure's on! My '52 Plymouth build thread...
Discussion in 'The Hokey Ass Message Board' started by don-vee, Dec 22, 2012.
  1. fstfish66
    fstfish66
    from eastern pa
    i hear ya on the pot holes,
  2. whtbaron
    whtbaron
    from manitoba
    What did you do with the rear gl***? Is it still stock height and channeled into the roof or set into the trunk? If it's tempered gl*** I hear cutting it isn't an option. I haven't looked into availability yet, most of the ones I see up here are fogged from the weather conditions.
  3. tailpipe47
    tailpipe47
    That is one of the few chops I have seen that works well on these MOPARS. Looking Good. Those wheels and tires work well also. What Size are you running and did you have to modify rear to fit them in? I have been wheel searching and it would be great to know what fits.
  4. 52Diplomat
    52Diplomat
    Nice Thread...lots of good tips I will use on my 52 engine swap. Thanks
  5. Baiz76
    Baiz76
    Farm Fresh!
    whtbaron likes this.
  6. Alex D.
    Alex D.
    from Hydes, MD.
    I have been thinking about the aerosprings on my 52 Concord. If you would not have relocated the bottom spring plate, would you still have the potential of dislodging the springs??
  7. Good question, I'm actually not sure, since I didn't bother to check before hacking and welding.
