Studebaker truck update
Discussion in 'The Hokey Ass Message Board' started by Stude-sled, Sep 4, 2007.
  1. Stude-sled
    Stude-sled
  2. RichFox
    RichFox
    Studes rule. What did you do to lower the front?
  3. Stude-sled
    Stude-sled
    The truck is on a 1999 S-10 frame.
  4. RichFox
    RichFox
    I guess I should have known that. Oh duh. Mine is on the stock frame with a Mustang 2 front end. I have seen on that the owner cut and welded the axel to drop it nd bolted it to the frame. Doubt the ride was very good.
  5. 51ChevPU
    51ChevPU
    from Arizona
    Is the S-10 a long bed or the extended frame. Also, did you need to use spacers in the front to give it a wider stance?
  6. T-Roy
    T-Roy
    Looks great! Diggin' the color of the wheels. *****in'....
    -Troy
  7. Stude-sled
    Stude-sled
    ex. cad short bed, but it is 10 inches shorter now. Yes 1 1/4 spacers up front.
  8. nexxussian
    nexxussian
    Umm, question. I had an 88 4X4 S10 with the stock size tires. I coldn't keep upper balljoints in it or much over 20K mi. Do the newer trucks have beefier stuff? Just curious as I figure the extra 1 1/4" of leverage would aggravate this.
    Of course mine was 4X4 and I rallied the living **** outa it.:confused:
  9. I read those frames are easy to shorten at the fish mouth, is that what you did?
    studevette likes this.
  10. Stude-sled
    Stude-sled
    Yes that is correct, easy to make shorter. GM useed the same frame for all the diff. lengths, they just slid them together or apart to make diff. wheelbases.
  11. studevette
    studevette
    from New York
    Cool truck I have a 49 with all corvette suspension and a 51 that's half done with s-10 thinking of a straight six for a daily driver
