Technical Wheel converison help
Discussion in 'The Hokey Ass Message Board' started by soda4u2, Jul 17, 2014.
  1. soda4u2
    soda4u2
    Is it possible to convert a 5 by 4 1/2 bolt pattern to 5 by 4 3/4 bolt pattern without using adapters?? Thanks for any thoughts.. Jimmy
  2. phat rat
    phat rat
    You could have the axles and hubs redrilled
  3. HOTRODPRIMER
    HOTRODPRIMER
    That's the only way I know of. HRP
  4. Squablow
    Squablow
    Some certain mag/aluminum wheels have enough meat to machine them out to basically make them into unilugs, but it takes a competent machinist and the right lug nuts/washers to do it safely. They'd have to be some damn valuable/rare wheels in conjunction with some very difficult to replace/redrill hubs to be worth the effort. It is possible though. Steel wheels are a different story.
  5. Never2old
    Never2old
    from so cal
    I have done it with aluminum wheels. Fairly easy on a vertical mill. I would not run a "unilug" wheel that is not hub-centric.
  6. soda4u2
    soda4u2
    Thanks for all the replies!! Axels and hub conversion seems the way to go!! Safety first.
  7. low budget
    low budget
    from Central Ky
    You could trade wheels or trade cars I guess:D
    Tell us more, what are you workin on? got any pics?
  8. gimpyshotrods
    gimpyshotrods
    Hamber Rottenleonard makes drill guides for re-drilling your own patterns.
    I have a few. They work super-awesome, and come with the drill bits!
    http://www.rottenleonard.com/
    He even made me a custom one!
  9. Joliet Jake
    Joliet Jake
    from Jax, FL
    I had my 55 Chevy axles drilled to accept Ford wheels, not a big deal, any machine shop with a Bridgeport can do it.
