Anyone have pics of Where these actually mount. Using gl*** fenders but can't see that making a difference. Thanks EB
I have fibregl*** ones as well but I made my own brackets so sorry I can't help. Edit: I did mine like Junkyardjeff and put them just behind the wheel opening at the back. Posted using the Full Custom H.A.M.B. App!
I think the original brackets mounted in the center of the wheel arch,since I am using gl*** fenders too I made a bracket and attached it to the bottom rear of the arch to keep the fender from flapping in the wind. I do not think the original brackets will work good with gl*** fenders,I used the original brackets in the front with no problems yet. I have only seen original rear brackets in pictures.
Here is mine the triangular piece bolts to the frame the round end is threaded and bolts to the bracket on the fender. I still have to finish gl***ing the bracket to the fender. Hope it helps. Posted using the Full Custom H.A.M.B. App!
I have no way to post any pics of the brackets I made since my computer took a **** and I am on a borrowed lap top.they are a simple bent bracket going from the lower fender to a mounting bolt
