Technical Flathead - spark plug thread repair
Discussion in 'Traditional Hot Rods' started by zgears, Jul 17, 2014.
  1. zgears
    zgears
    Looks like I'll need to repair my spark plug threads on my 37 Flathead. These heads take a 18mm plug. My local machinist isn't much help on getting this helicoiled. It looks like some of the options are expensive. Anyone have any thoughts or suggestions?
  2. dreracecar
    dreracecar
    from so-cal
    Thread Kits Co
    1-800-372-4477
    Perma-Plug Spark plug repair kit 18- 1.50mm PN 1218-500
  3. 302GMC
    302GMC
    from Idaho
    You may want to check the depth of the pitting before going too far. And a machinist who can't helicoil a plug hole ????
  4. Put the offending cylinder on exhaust. Take your shop vac and put it on blow. Let it clean itself for minute or so and then install it on the exhaust pipe. While you are working , drilling tapping etc all chips a debris will be blowing out into your face probably but that beats into the cylinder. Works perfectly. The reason machinist don't want to do it is the possibility of getting chips and debris into the cylinder making a simple job into a nightmare. I tried this about 20 years or so ago (I am a mech by profession)and have used it many times since. How do you know when you are on exhaust? Wind will be coming out the hole from the shop vac blowing into the exhaust system. Otherwise follow the instructions on the repair kit exactly and you will be fine.
  5. Atwater Mike
    Atwater Mike
    Look into dreracecar's source. These will be 'bushings', rather than loose-coiled 'helicoils'.
    I have been in the aluminum engine German car biz for 57 years, and only use helicoils when a permanent stud will be inserted, NOT spark plugs which get removed and replaced with decided regularity.
  6. dreracecar
    dreracecar
    from so-cal
    But the head is already off the block
  7. greybeard360
    greybeard360
    Heli Coil makes a sleeve type of spark plug repair kit that works very good. The kit is a little pricy just to do one plug. I would call another machine shop and ask them if they have this type of insert.
  8. Rusty O'Toole
    Rusty O'Toole
    Every auto parts store sells thread inserts for spark plug holes. Another tip is to grease the tap so it will catch the chips.
  9. bobss396
    bobss396
    That is probably the "worst case scenario" kit if its what I think it is. It has a larger outer thread that takes the helicoil insert. We used them on boat engines years back.
  10. zgears
    zgears
  11. F-6Garagerat
    F-6Garagerat
    These work. Used them before on a set my brother had. Nice kit.
  12. Grahamsc
    Grahamsc
    from Colorado
  13. dreracecar
    dreracecar
    from so-cal
    Time serts and Perma plug are basicly the same thing and both are handled by Thread kits inc
  14. DD COOPMAN
    DD COOPMAN
    My God, good heads (in better overall condition) are almost a dime-a-dozen. You've already done the hardest part in removing the boogered head. DD
  15. 55 dude
    55 dude
  16. zgears
    zgears
    Guess there's more to it than I thought.
  17. 40FordGuy
    40FordGuy
    I'm with # 3,...Find a different machinist !!
    4TTRUK
  18. RichFox
    RichFox
    I believe you could but 18-14 or 10mm adapters in steel. Coat them with JB weld and screw them in. Then use commonly available plugs.
