Technical Help on my 51 shoebox
Discussion in 'The Hokey Ass Message Board' started by markdob, Jul 28, 2014.
  1. markdob
    markdob
    Thinking about putting a front clip on so I can have disc brakes and bagging it, but not sure of who to use. Looking for advice on using different manufacturers good or bad. And on the same note advice for the rear bagging so it can lay down 2 link or 4 link, etc???. thanks
  2. Finnrodder
    Finnrodder
    from Finland
    I dont know about front clips,but why not buy a disc brake conversion kit for original hubs?
    You can use the original A-arms for bagging too and there are upgrades for steering too available.
    I think there is less work by doing it this way.
  3. Eric H
    Eric H
    Finnrodder has a good point. Check out shoebox central for all your needs, they are great people and thy will help you out. I clipped my last shoebox and all it did was create one new problem after another. Now that I am a little older I appreciate that my car feels like an old car, it's part of the experience for me. There is nothing wrong with the factory frame at all, everything you need can be bolted on.
  4. If the frame is solid don't clip it.
  5. Stefan T
    Stefan T
    from Sweden
    Don't clip it.
    Buy some converastion kit insted ther's more than one that sells that typ of kits.
    /Stefan
  6. Yeah, call Chris at Shoebox Central. He's been great help with our 49 project.
    Parts & tech support, he's the one ......................
  7. [​IMG]
    This looks like a helluva nice solid sedan. In your other posts you're talking about bagging it and laying frame, now you're talking 4 links and front clips. Got a mini truck or two in your background? It's not my car, but I'd hope you'll do some research into traditional customs and build techniques before you start ripping into this nice old shoebox. You can make it into a killer custom without all that kit-build stuff.
    There's a shoebox forum on here that has a ton of good info, and links to a lot of build threads from mild to insane. Do some reading and get some ideas...
    http://www.jalopyjournal.com/forum/social-forums/shoe-box-hambers.112/
    Eric H likes this.
  8. Oh and just for the record, I'm not a "it's too original to mess with" restorer, I'd chop that thing in a second :D
  9. Spidercoupe
    Spidercoupe
    from Bevier, MO
    if you want to clip it an s 10 front clip was made for it. I clipped mine in one day.
  10. choped41
    choped41
    PEOPLE AREN'T GOING TO LIKE THIS BUT I'VE GOT ONE AND IT DRIVES LIKE A DREAM . I'VE GOT A S 10 IN MINE BUT WIDEN IT 3" TO PUT THE WHEELS OUT WERE THEY BELONG . IF I DO ANOTHER ONE I WILL USE A METRIC GM CLIP {MONTE CARLO}GOT ALL THE TOYS DISC BRAKES, POWER STEERING , V 8 MOUNTS .AND PARTS AT YOUR LOCAL PART STORE ANY WERE' JUST A THROUGH
  11. F-ONE
    F-ONE
    from Alabama
    Search Craigslist, there's a world of inspirational s-10 swaps on there.
  12. loose49
    loose49
    from tucson az
    OK get out your crayon here we go got mine from Tom in 2012 its great he was super Mark in tucson az 49 ford name Tom Pierce street rod engineering llc 120 commerce dr. ste3 fort collins co. 80524 / 970 361 4447 order it stock height and it drops it about 2 or 3 in. I used 2 in. lowering blocks in back just the right stance . got independent suspension disc brakes power steering what a great setup and a nice guy to deal with
