Technical windshield wipers
Discussion in 'The Hokey Ass Message Board' started by lil runaway, Aug 1, 2014.
  1. lil runaway
    lil runaway
    from Wisconsin
    I have a 40 Chev and am wanting to do away with the original wipers. Does anybody know of a swap that will work?
  2. borpa11
    borpa11
    from Colorado
    Lots of swaps available, you can find several bolt in e-motors that will run a couple hundred but most go to the junk yard and find one. Dodge minivans seems to be a popular choice oddly enough. Measure your throw length and go from there,
  3. flamed34
    flamed34
    Old jaguars (and probably other British brands) use a cable driven system that is pretty adaptable. The aftermarket has stolen the idea and made them for hot rods.
  4. OLDSMAN
    OLDSMAN
    Why mess around trying to make other OEM wipers work. Go to Newport engineering, and check them out. They have direct bolt in units that work super. They are great prople to work with, and their units are not all that bad in price. Give them a chance, that is what I use
  5. HOTRODPRIMER
    HOTRODPRIMER
    They are nice but at 209.95 bucks they sure ain't cheap! HRP
    https://www.newportwipers.com/products.php?year=1940&make_id=1
    I use Rain-X myself. HRP
    bchrismer likes this.
  6. K13
    K13
  7. HOTRODPRIMER
    HOTRODPRIMER
    Rain-X, $3.69 a bottle.:D HRP
  8. K13
    K13
    Haha unfortunately I legally have to have working wipers.
  9. HOTRODPRIMER
    HOTRODPRIMER
    All my hot rods have working windshield wipers but as you already know the original styled wipers are marginal at best. HRP
  10. OLDSMAN
    OLDSMAN
    Newport is not cheap, but they work great, and fit in with no modifications to the car, just unbolt the vacuum motor, bolt in the electric motor, wire in the switch, and presto wipers that work as they are supposed to
  11. mashed
    mashed
    from 4077th
    I've heard Jeep rear wiper motors used with a little modification.
    Some are two speed, self-parking.
  12. The best option by far in my opinion, they can be placed anywhere and work like a dream, the aftermarket rip offs of them are absolute junk, I had a customer have me fit one a couple of years back and it broke before I even fired it up. I only use the genuine English ones now made by Lucas, problem is they are getting a bit hard to come by..
  13. RICH B
    RICH B
    The Lucas cable ones are good for an earlier car, with the wiper over the windshield and no room for a decent motor. Recently put the Lucas type on a 54 and the drive motor ***embly took up what I considered valuable room in the p***enger kick panel area, while there was plenty of unused room in the middle. I guess I would just get a United Technologies (or what ever the brand is currently) motor and adapt it like Newport does. I did this on my '47 Ford, not that complex a deal. Rain-X works great on the road; but stop and go city traffic in the rain ****s without some sort of wiper.
  14. lil runaway
    lil runaway
    from Wisconsin
    I have a Newport in there now from 96, it didnt work very well from the word go. Thats why Im looking now while I have to do a few mods and paint.
  15. mgtstumpy
    mgtstumpy
    Newport again, direct bolt in. Mandatory safety item down here. I've adapted BMC cable drives before, you can mount motor and trim cable to suit your application. Recently used and adapted 2sp Hyundai car to a friends Pommy rod with minor fabrication. Good sweep with park provision.
  16. 48ford
    48ford
    you could look at te unit on a old v.w. bug ,it may work for you. a nice little unit
  17. 29moonshine
    29moonshine
    i used vw beatle wiper ***embly on my 36 chevy .it mounts under the dash has 2speeds and park. takes up very little room . the arm mounts are 15 1/2 " cc. $15 at the pick and pull.
  18. Searcher
    Searcher
    Even with wipers I agree you can't beat RainX... on all your gl*** and rear view mirrors.
  19. OLDSMAN
    OLDSMAN
    If you have a Newport and it doesn't work right, have you contacted them? Bob and his wife are super people to work with, and if they don't know there are problems with the product can't fix them. Give them a call
  20. okiedokie
    okiedokie
    from Ok
    I have used four Newport units, all trouble free. I like driving my rods and want good working wipers in hard rain. If the original linkage is not in good condition then Newport is not at fault.
  21. bchrismer
    bchrismer
    Bob, at Newport, is a really good guy. That being said, I have yet to use his products, but I've heard nothing but good about them.
    Both of my '40s still have the stock vacuum motors in them. I took the coupe's wiper motor apart and used a bunch of Vaseline inside it, and it works pretty well, in conjunction with a fresh application of RainX. The Vaseline helps the paddle seal against the housing.
    I haven't pulled the motor apart, on the stake truck, but I had temporarily installed a vacuum canister, out of a '96 or older Ford Truck (the kind that looks like a coffee can), and it helped regulate the available vacuum, through acceleration. One of these days, when I find a good label from a #10 can of baked beans, or something like that, I will affix it to the vacuum canister and mount it under the hood somewhere. Our local "pick a part" sold me my "can of ****" for less than $10.
