Features Outside mirror for Model A
Discussion in 'The Hokey Ass Message Board' started by Russ B, Aug 3, 2014.
  1. Russ B
    Russ B
    I have been frustrated on finding a good looking mirror for my cabriolet. My preference is a hinge style mirror, but the Briggs Body middle hinges are lower than those of the coupe, sedan or pickup, and different shape and height, too. The lower hinge mean the mirror head of the mirror I have can not even be seen from the driver's seat. Aftermarket hinge mirrors for later cars are generally made of pot metal and can not be readily modified. I was thinking of having some parts machined of SS and welding them together, and then bend the arm into the shape I wanted. ...but finally I got convinced that making a pattern and having it cast in br*** would be my best solution.
    I am not done but have made significant progress. Here are a few pics.
    I started by shaping an arm and making a hinge mount
    the arm was shaped in a compatible style for the body
    I drilled the arm to fit a mirror head, so I could be sure the height and visibility would work for me.
    After being sure of the location, I put a more complete bracket together for each side
    each one is made from five pieces of oak.
    Next I started getting them ready for molding.
    bondo, sand ...bondo, sand ...bondo sand
    finally seal and varnish
    I took the pieces to a local foundry and a mold pattern was made.
    ...two weeks later, I got a batch of castings
    I made a few extra sets so I could make a couple different styles and sets for my other A's, if they can be fitted. And the additional cost was not that great after all the other setup expenses.
    the raw castings have extra 'meat' to allow casting in a two piece mold, and the casting has to be cut to fit to the hinge
    The piece on the left has been cut for the hinge and shaping has started. Both are driver's side castings.
    ...and in place
    the other side
    ...and that is where I am so far. I still need to finish shaping the casting, thinning and smoothing the upper arm, and shaping a reveal accent at the base. ...then to the machinist to drill the pin holes and fit the pin to the hinges and drill the mirror head. ...and then off for chrome plating. I am three weeks into the process, two were taken by the foundry.
  2. Muttley
    Muttley
    Those are going to look great.
    osage orange and Stogy like this.
  3. clem
    clem
    An incredible amount of work and then you get the castings back and realise its all been worth it - they look fantastic. Thanks for showing us.
  4. Beautiful work, having parts cast is a great way to go, the initial work pays off big time when you can have many castings done anytime you feel the need..
  5. Amazing talent.
  6. hipster
    hipster
    Really nice!
  7. motoandy
    motoandy
    from MB, SC
    Thanks for sharing the process. A true custom piece.
  8. Hotrodmyk
    Hotrodmyk
    Very nice project. They look just right on the car.
  9. 117harv
    117harv
    Thanks for taking the time to do***ent and share...very nice.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Man,that is a lot of work but the effort paid off in spades,,you made a part that looks like it could have been a factory accessory part produced when the Model A was new. HRP
  11. daddylama
    daddylama
    Very nice!
    what material are they cast in?
    Stogy likes this.
  12. Russ B
    Russ B
    It is 'red' br***, which as I understand is not as strong as 'yellow' br***, but is better if pieces are to be plated. It has a higher copper content. I am new to this casting stuff, so my knowledge is primitive. The foundry owner did some small replacement spacer pieces for an old coat rack for me at the same time out of yellow, and it seems to be pretty hard. The red cuts/shapes pretty easy in comparison.
    Stogy likes this.
  13. daddylama
    daddylama
    i've played around with back yard casting... mostly aluminum, br*** and bronze. i haven't tried red br*** yet.
    great project you've got there!
    Stogy likes this.
  14. Russ B
    Russ B
    slowly getting the mirror brackets into shape
  15. tb33anda3rd
    tb33anda3rd
    nice work!
    Stogy likes this.
  16. dirty old man
    dirty old man
    That's nice work, and as a machinist for 40+ years, I know nice work when I see it. Looks are gonna be much nicer than the ones I have on my "A" roadster, which are off the hinge bolt on the windshield posts. I don't like the look of them, at all, but I also don't like driving on Atlanta metro area Xways without side mirrors.
    You should consider marketing these on the HAMB cl***ifieds.
    osage orange, Stogy and 66fora69er like this.
  17. look great! I guess I should rethink my mirrors now.
    Stogy likes this.
  18. Pat Thompson
    Pat Thompson
    They look good. Did you make the follow board for the foundry or did they?
    Stogy likes this.
  19. Russ B
    Russ B
    The foundry has an on site pattern maker who did the follow board. As a novice, I am not sure of my terminology.
    I have to thank my machinist friend, Dave Cantwell, who encouraged me to try this and looked at my progress, commenting, to help me produce something that could be cast.
    Stogy likes this.
  20. Russ B
    Russ B
    and a pic of the mirror with mirror head installed
  21. Russ B
    Russ B
    just an update, my mirror arms are now plated and installed
  22. kevinwalshe
    kevinwalshe
    Those look amazing. Any plans on having another run made?
    Stogy likes this.
  23. rust&patina
    rust&patina
    WOW... those are NICE :cool:
    Stogy likes this.
  24. Chucky
    Chucky
    Mine, mounted on top hinge, are useless. I can't adjust them to really see behind me. Those look great, but I bet they actually work too! Nice job.
    Stogy likes this.
  25. Bam.inc
    Bam.inc
    from KS
    Very nice. A lot of labor, so can idea be sold into production , so a few more of us could enjoy these too?
    Stogy likes this.
  26. Russ B
    Russ B
    The foundry that did the casting has closed down. I do not have another foundry lined up, so will not be recasting more soon. If I did another batch, I would only sell them as raw castings. the buyer would need to fit and finish them. If someone else was interested in taking over the project they can PM me.
    They do work very good as mirrors since functionality was the reason for making them in the first place. I spent time making sure the head would be in a good location for seeing behind. The different sets I have for a coupe and a closed cab PU do not work great.
    Stogy likes this.
  27. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    LQQKS Great Russ!
    Stogy likes this.
  28. mike bowling
    mike bowling
    Beautiful work.
    You should enter this in next years "Tech Week" thread.
    Stogy likes this.
  29. Stogy
    Stogy
    :rolleyes:...Wow is all that I can say...Russ I rotated this for you, right clic save it and edit your post as it deserves the proper orientation to appreciate the effort put in to this project...I will delete this pic as I'm just bringing this back up as it's amazing really...What is the mirror you used for this stem you made...
    As noted this was tech before the tech Threads...I wouldn't have known this if you hadn't have posted in the Homogenized Thread sharing another unique detail on your Cabrio...
    You may get some PMs on this Bttt...you did a lot of finish work to make this happen...How do you spell p***ion...This...;)
    osage orange likes this.
  30. Russ B
    Russ B
    Thank you for the kind words. The cabriolet build was one of pure p***ion, without deadlines. I don’t recall exactly the mirror source, but in all probability it came from a Model A parts supplier.
    tb33anda3rd and Stogy like this.
