Projects 1957 Styled Deuce Build Update
Discussion in 'Traditional Hot Rods' started by ziffer, Aug 3, 2014.
  1. ziffer
    ziffer
    from michigan
    I was talking with a friend yesterday at the Gilmore Car Museum and he suggested I post some of my work. The car is being built as a 1955-1958 hot rod. I am building it the way it would have been done in the day recycling parts and giving the roadster
    If you want to see more of this type of stuff let me know and I will keep posting as the car progresses.
    I have an F1 column and need to make a bowl/bell to cover the hub and rear of the steering wheel. It will have a Bell 3-Spoke so I want the bell as small as possible while retaining some cl***. Enter a 1933 Cowl light.
    Using a circle template I roughed out the opening needed to slide it on the column. With the gauge set-up below I got a nice concentric circle so it will be straight on the column.
    Opening cut
    Now to fill the extra holes. These are 22ga steel so I am leaving the flange around the front for strength and then when it is welded to the column jacket it will have strength on the back. This 22ga makes for some fun welding. First, remove the chrome where the welds will be. Now is the time for the torch to shine as MIG will blow holes in this and you can't work the welds. Smith torches with 00 tip.
    Small holes filled[​IMG]
    Plug for large hole cut and hammered "on dolly" to stretch the metal so it stays put.
    Welds dressed with a 50 grit disk in DA. Be very careful to only dress the welds as one slip of the DA and you will go right through the 22ga. Now to metal finish I used two special dollies. Anyone want to identify the car part that became the two flanged dolly on the left?
    It is great for working "inside".
    Almost done metal finishing (using 100 grit on palm sander)[​IMG]
    Done and Done
    cptn60, Stogy, kidcampbell71 and 5 others like this.
  2. lurker mick
    lurker mick
    Nicely done, very cool. Please keep us in the loop, would love to see more.
    Mick
  3. tfeverfred
    tfeverfred
    GREAT job! 100%er. "Watched" WITH email alerts.
  4. MAD 034
    MAD 034
    from Washington
    Very creative. Yes -- keep posting.
  5. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Love your work. Very nice. Keep posting!
  6. clem
    clem
    Nice work, bit/dolly in pic looks like what a shoe repair guy uses, to re sole shoes.
  7. HOTRODPRIMER
    HOTRODPRIMER
    That is definitely think outside the box,using a cowl light,that's better than wrecking another column just to salvage a smaller bell like I have done in the past. HRP
  8. gwhite
    gwhite
    SUPER MODERATOR
    Nice work...one of your dollies looks like a slightly modified Model A kingpin, and the other looks like a crankshaft. Too cool!
  9. lothiandon1940
    lothiandon1940
    Nice work. Will be watching the progress.
  10. alchemy
    alchemy
    If that was an original cowl light it should be stainless. Maybe do I it again with the other light from the other side, but use stainless rod and polish it afterward.
  11. ziffer
    ziffer
    from michigan
    Greg White is correct, Model A crank.
  12. Scott F.
    Scott F.
    Definitely want to see more!
  13. 296ardun
    296ardun
    Yes, please keep posting, this is WORKMANSHIP!
  14. Barz51
    Barz51
    Looks great! Keep up the good work and keep posting!
  15. 3wLarry
    3wLarry
    from Owasso, Ok
    more please
    kidcampbell71 likes this.
  16. Mr48chev
    That is some interesting right now as I was trying to figure out how to come up with something similar, Thanks. Those two damaged cowl lights on my Model A Vic may not hit the s**** pile quite yet. And my son can weld stainless (insert smile).
  17. ziffer
    ziffer
    from michigan
    Rearching the swan neck shifter.
    The shifter was hitting the dash in 3rd gear so I had to rearch it. Started with a French curve and made a template. The key to getting a nice gentle radius without kinking is the buck. I had an old Bandsaw pulley that did just the trick. Picture 1 was the original then pic 2 after rearching.
  18. ziffer
    ziffer
    from michigan
    I am currently working on a hidden latch to hold the hood tops down. Should post after the weekend.
  19. timwhit
    timwhit
    I will be really interested in the hood latch set-up. I've been looking for the right thing for my hood.
  20. gwhite
    gwhite
    SUPER MODERATOR
    Great idea! I see your striker...***uming you heated & bent? I've heard some folks have had luck keeping the chrome/nickel from cracking by bending cold.
  21. ziffer
    ziffer
    from michigan
  22. ziffer
    ziffer
    from michigan
    I did not want to make any drastic modifications to the hood and since the original hinge hoops would not give me clearance I chose to TIG some stainless tube to the originals. (If I want to use hood sides in the future cut 3 tacks and move on.) The latches will be spring loaded stainless rods and the receivers will need to be adjustable to allow movement up/down, and in/out for body bead alignment.
    This is looking from front to rear where the rod will latch at the corner of the firewall
    Barz51 likes this.
  23. gnichols
    gnichols
    from Tampa, FL
    Clever idea. Gary
  24. Barz51
    Barz51
  25. ziffer
    ziffer
    from michigan
    Have not been in the shop fabing for 7 weeks. Hit it hard but did not have a chance to take pics along the way. Anyhow, here is a stock bone, my extended bone since I pushed the front axle out 5 inches. Finally, the 35/36 rear bone extended and beamed to add strength for the rear end.
    **If you are extending a bone make sure that you keep all the geometry straight, put slugs inside the tubing, and weld with plenty of penetration. Don't forget plug welds into the slugs.
    SAFETY FIRST.
    Barz51 likes this.
  26. ziffer
    ziffer
    from michigan
    Shot of master cylinder mounting plate with beaming for strength.
    Going to try to get some serious progress and updates done over the next few weeks.
  27. MercDeuceMan
    MercDeuceMan
    from Indiana
    very cool workmanship
  28. Barz51
    Barz51
    Looks good! Excited to see it rolling!
  29. lucas doolin
    lucas doolin
    Love your approach and craftsmanship. Got me thinking about why it is the build quality is so much better on today's "nostalgia" cars. You've probably got more time and effort invested in tooling than a lot of teenage builders had in the entire car which had to be built quickly with a minimum of tools and experience. Watching builds on the HAMB for me is like seeing a consummate artist create a masterpiece one step at a time. Just because most of us can't achieve this level of results doesn't mean we don't fully appreciate what you're doing. Thanks for posting. lucas doolin
    wicarnut and Barz51 like this.
  30. ziffer
    ziffer
    from michigan
    Made it back to the roadster and needed to look back at where I've been so I designed and made the rear view mirror components out of a chunk of 7/16 stainless. Since the roadster has a lot of Zephyr parts/influence I wanted to use the Zephyr tear drop as the base. It also gives that feel of speed as the droplet is stretched buy the biting wind. Since it is mounted behind the DuVall the stalk has to be angled accordingly. Pics below show the project.......
    .[​IMG]
    Wooden template
    Need to extract base by getting rid of "excess" stainless
    With some serious cutting and grinding with my 1/32 cutoff wheel and dart grinder I got the base done in 3-D. Some stainless rod and a stainless ball bearing and we have a way to mount the mirror head. The hole is drilled in Parallel to the DuVall windshield so the stalk can be welded in.
    With everything welded together and some studs welded into the base this is what we have. (Mounted to pie container to keep from tipping over.) Doesn't look like much but it sure took some time.
    kiwijeff, Kan Kustom, Tuck and 3 others like this.
