Projects 1930 Plymouth Tudor build thread
Discussion in 'The Hokey Ass Message Board' started by charlesincharge09, Jan 8, 2013.
  1. charlesincharge09
    charlesincharge09
    from Wisconsin
    We'll after A long cold winter of not much getting done I decided to insulate and finish off the garage so I can actually work on stuff next winter
  2. charlesincharge09
    charlesincharge09
    from Wisconsin
    Mounted my steering box,
    made my column (still need to mount dash and figure out a clamp setup for the top of the column. Got some work done on the floor.
    Mounted the master cylinder, still need to tweak the arm depending on gas pedal. Got driver side bear claw latch assembly done.
  3. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got some lake pipes mounted, engine painted and now waiting for some more cash flow for the intake setup
    Thinking About painting the dash the same as the motor with some white and black pinstriping
  4. charlesincharge09
    charlesincharge09
    from Wisconsin
    Started my taillights
    Once I figured out how to cut the hole I used a cardboard tube to make them level ImageUploadedByH.A.M.B.1398643089.328828.jpg
    One down tone to go
  5. charlesincharge09
    charlesincharge09
    from Wisconsin
    All done
    Used clear plastic to make a template to transfer to the other side
  6. Mean Lean
    Mean Lean
    Man, that Plymouth is just right! Here are some pics of a bomber tank, not polished but still ok, and a pic of my Plymouth in progress, not chopped yet..
    cheers
    Leen
  7. charlesincharge09
    charlesincharge09
    from Wisconsin
    Thats the exact same paint scheme i plan on doing! lol except with a gold stripe all way the around between the red oxide and the black.
    Your car is definitely more complete and in nice shape than mine is, I'm digging the rear fenders! would you mind posting some pictures of the rear bottom sheet metal, i have no idea how it was originally because mine was completely rotted
  8. Mean Lean
    Mean Lean
    Here are the pics of the bottom from the inside
  9. charlesincharge09
    charlesincharge09
    from Wisconsin
    So that's what it's supposed to look like..... Haha. Do you have any pictures from the outside?
  10. Mean Lean
    Mean Lean
    Next time when it is up in the air I will take some pics. Do you have an idea what to do with the top of the front window, I want to cut it up after chopping and put a Model A visor on it, I did the same with my ''31 Chevy (I tried the Plymouth grille on her..)
    Leen
  11. charlesincharge09
    charlesincharge09
    from Wisconsin
    i had to cut it up a lot because once i chopped it 6" i had like maybe 4" to see out the windshield. Im still not done with it yet, still up in the air about how i will finish it off
  12. charlesincharge09
    charlesincharge09
    from Wisconsin
    Here is a pic of how it was without cutting it up and having it chopped 6"
  13. Mean Lean
    Mean Lean
    I fabricated some hinges for mine, for sure you need a lot of cutting to get that window open, even on the inside structure, I also tried my beadroller with a scateboardwheel at the bottom for the interiour
    Leen
  14. charlesincharge09
    charlesincharge09
    from Wisconsin
    That looks very Good! wish mine was more complete when i got it. i am probably going to have a fixed front windshield and eventually the rear window and the rear sides. as far as the doors, there isn't enough left to make functionable roll up and down windows (with my budget at least) so i am going without. Plus im keeping the top open so there is no point to have to have operating windows lol
  15. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got my intake and carbs. Webers!!!
  16. Mean Lean
    Mean Lean
    Man that looks so cool, and I was thinking you were on a budget...
  17. leadsled deluxe
    leadsled deluxe
  18. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got a great deal from a pierce manifolds as they are a vendor of mine through work. Got the setup for a whopping $700
  19. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got my radiator shell fitted and mounted, also made some support rods and got the radiator mounted
  20. charlesincharge09
    charlesincharge09
    from Wisconsin
    Stock model A steering arms modified and smoothed out, running heim joints
  21. jdownunder
    jdownunder
    coming along nicely
  22. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got my gauges ordered and installed, I am very happy with the outcome. Turned out better than I thought. I have heard lots of good as well as some bad things on these dolphin gauges. But the price was defiantly right
  23. charlesincharge09
    charlesincharge09
    from Wisconsin
    Got some uni-strut Andrade some drip rails
    Cut it in half
    Looks at home on the old Plymouth!
  24. charlesincharge09
    charlesincharge09
    from Wisconsin
    Finishing the cutting and lip on the windshield opening
  25. 31Dodger
    31Dodger
    I would be interested in the stock steering stuff if you still have it.
  26. charlesincharge09
    charlesincharge09
    from Wisconsin
    All I started with was the body so I don't have anything, sorry I can't help you out.
  27. charlesincharge09
    charlesincharge09
    from Wisconsin
    Last year my goal was to get it to be a rolling chassis, this year was to get the body off and painted so I could finish the frame over the winter and not have to worry about the body collecting more surface rust.
    The body had a lot of character, then again it spent 40+ years in a swamp, I did my best to make it straight but I knew there was no way to not have character with my limited abilities and experience but I am fine with that
    Here is the body after some body filler
    After a couple coats of sandable primer
    And finally the main color. I used 8:1 ppg dp74 and dp90, thanks to the others that figured out the perfect ratio! I still plan on painting the body lines black with a gold pinstripe
  28. Just read through the whole thread. Very cool how you get stuck in and get it done. I hope you still go with the pagan gold body one day, and at this rate, your,ll be driving it soon.
  29. charlesincharge09
    charlesincharge09
    from Wisconsin
    Thanks, it's been a learning experience that's for sure. I'll maybe paint it someday but for now it'll be fine for a couple years until I get sick of it. Since it's an epoxy primer it'll be easy enough to redo
  30. Recks30
    Recks30
    Awesome build, subscribed. That 9" rear looked super wide until the body went on. What is the width of that rear?
