Pics of 1/4 elliptical fronts .... please
Discussion in 'The Hokey Ass Message Board' started by Gr8lite, Jan 12, 2006.
  1. Gr8lite
    Gr8lite
    from Maine
    Lookin fo pics and advise on running 1/4 elliptical front suspentions.
    Thanks to all!
  2. Mule Farmer
    Mule Farmer
    from Holland MI
    if you do a search i know there is some on here.
  3. Gr8lite
    Gr8lite
    from Maine
    I did search I got 3 results . No pics of front setups. Sorry to be a PIA. But thanks for the heads up.
  4. nobux
    nobux
    Here's a picture of the set-up I put together. It's 2 12" spring packs made from 53 F100 front springs bolt into pockets welded to the bottom front of the frame. Rode very nice, had some handling issues(tire bounce at about 55-60mph) that I kind of attributed to having the shocks mounted too far back on the wishbone with the somewhat soft springs. Aother problem with the set-up is that it really made tie-rod placement a chore.
    Nobux
  5. buffaloracer
    buffaloracer
    from kansas
    Might want to take at look at this year's HAMB Drag pictures. The best example that I've seen was on the front end of the barebones roadster with the Stutz Bearcat section behind the seats.
    Pete
  6. tommy
    tommy
    here is one.
  7. do two searches one for elips and one for eliptical go back a year. I got several.
    This get revisited about every so often, if you find a rear it is the same principal as the front.
    you might also look in the tech section.
  8. FiddyFour
    FiddyFour
    you talkin about that red one? the "barbarian" i think it was called... *****in lil car :cool:
  9. I did a search on here yesterday and found 3 pages of threads about 1/4 elliptics
