Technical Speedo hookups (mixing new with old)?
Discussion in 'The Hokey Ass Message Board' started by tailpipe47, Aug 4, 2014.
  1. tailpipe47
    tailpipe47
    I have built a few rods in my life and mixed new with old (1980s being the newest til now), but I have run into one I am at a loss on. I am building a 49 Plymouth with a 78 318 backed with a 5 speed from a 99 Ram 1500 and a 67 Mustang 8" rearend. The speedometer senser was on the rearend of the Ram 1500. Not in the trans. Where do I hook up a speedometer in this old and new mismash? Is there a way?
  2. What squirrel suggests below!
    Posted using Full box of Crayons on the Kitchen Walls App!
  3. squirrel
    TonyVoltron likes this.
  4. e1956v
    e1956v
    Alliance Vendor
    Since you are into it this far I think your only option is a GPS speedometer. Take a look at www.speedhut.com
    They make a quality product. Cl***ic instruments also has their Sky drive system. Good luck.
  5. tailpipe47
    tailpipe47
    The GPS was the one that I didn't want to go to because of prices, but that seems to be the only true answer with this combo. I thank you for your input. Changing the trans. is out of the question. The hole running gear combo was based around the 5 speed. To change the trans. to fewer gears is just pouring more money in the tank. The GPS is the answer. Thanks again guys.
