Projects 1950 Mercury Hardtop build
Discussion in 'Traditional Customs' started by slddnmatt, Aug 3, 2014.
  1. HOTRODPRIMER
    HOTRODPRIMER
    Another great build! HRP
  2. slddnmatt
    slddnmatt
    All these are old pics Andrew!!
  3. slddnmatt
    slddnmatt
    ya it just takes some eyeballing, you have to slide the window forward a little more and I wouldn't go over a 4" chop in the rear..My old 51 was a 4"& 4" Repop rear window would help the flow out also..
    kidcampbell71 likes this.
  4. slddnmatt
    slddnmatt
    craigs 50 040.jpg craigs 50 041.jpg craigs 50 032.jpg craigs 50 070.jpg craigs 50 071.jpg
    Welding, welding, and some more welding...When creating a Hardtop, and you want to have functioning windows for it to seal, you have to try and think a few steps ahead of what your doing to not screw yourself up. Revamping the door jambs to accomodate weatherstripping and stuff can be a PITA!
  5. slddnmatt
    slddnmatt
    Now the fun stuff, creating all the window frames. I opted to make a new vent window housing frame since it would be visible and needed to be sturdy enough to hold the vent frame and not be attached to the top of the door. After the frame was finished and reshaped the vent frame and shortened the division bar.
  6. The Doddfather
    The Doddfather
    from Va
    Hey Matt, good to see you are posting the full build of my car. The finished pictures don't do the car justice on the quality of the work....the chop is perfect and the windows are impressive!
  7. K13
    K13
    Nice work Matt always cool to see build thread especially on Merc's!!
  8. michaelvz51
    michaelvz51
    from So Cal
    Awesome work Matt, you continue to give me inspiration on my project.
  9. Wow! I've never seen that vent window treatment before. That is out of the park and well done. I'm impressed. I can't remember when I said that last.
    The Wizzard
  10. 'Mo
    'Mo
    That's real craftsmanship.
    The catwalk area is beautiful. It reminds me of the Buddy Alcorn Merc. Maybe even nicer!
    Thanks for posting.
  11. Doctor Detroit
    Doctor Detroit
    This is better than Fifty Shades of Metalwork. I study each photo and think 'my skill is nowhere near even being allowed in the same garage as Matt'.
  12. Verbal Kint
    Verbal Kint
    from Washington
    Great work, a good friend started this "hardtop" while he was in High School....
    - The hardtop was a ton of work and he's mentioned more than a few times he wouldn't ever do it again -
    (I apologize if you've seen these they are old posts)
    (Again old posts) His latest with the '51 back gl***
  13. slddnmatt
    slddnmatt
    craigs 50 090.jpg craigs 50 047.jpg craigs 50 048.jpg craigs 50 085.jpg craigs 50 091.jpg
    Never hurts to see pics of Mercs Verbal Kint!!!
    I made the frames of the windows out of some 1/2"x 1" rectangle tube then trimed it down to 5/8"
    If I have to make these again in the future, they will be from stainless, REALLY ****S when the chromer's screw up the shape and all your perfect fitting edges...
    kidcampbell71, drdave and 51 mercules like this.
  14. lewk
    lewk
    from Mt
    Looks great!
  15. cblake66
    cblake66
    from TEXAS
  16. slddnmatt
    slddnmatt
    So after getting the chop all done and doing some miscellanious stuff, I get a call from the owner and were talking for a bit....Then he spits out...I think I might sell the car, I'm liking the look of 51's better!!! My jaw dropped!! Well after some more chit chat I brought up the idea of grafting some 51 quarters on instead of starting over thank god! I called my fellow Merc brother Chad (Ether), because I remember him recently dragging home a rust bucket 51 that he was going to part out. Ended up getting everything I needed pretty much to start the swap.
  17. slddnmatt
    slddnmatt
    craigs 063.jpg craigs 064.jpg craigs 068.jpg craigs 069.jpg craigs 070.jpg craigs 071.jpg
    Once everything was sand blasted, I trimmed off the 50 rear 1/4's. I had pics of this process, but I believe they were on my phone which just happened to fall in a pan of ****** fluid...Ooops..I left a little 1/4" flange on the top part by the body seam to let the new panel rest on. When I cut the 51 1/4's loose from It's body, I used a thin cut off wheel to keep as close to the edge as possible to retain as much metal as I could.
    The 51's peak along the top edge, is pretty much the full length of the upper 4 door 1/4. So I used almost every bit that Chad had sent me. I marked everything out where I was happy and made my cuts and once fit and tacked on, everything lined up really well. Then on to some tedious welding/ grinding and some dolly work...
  18. Doctor Detroit
    Doctor Detroit
    Awesome work...
    I'd be interested in knowing what welder you use, and what your settings are. I see a blue welder in your pics, I'm ***uming it's a Miller. Do you mig everything, or just tack weld with a mig and finish with a tig?
  19. X38
    X38
    Really appreciate this thread. Good story, good information, well crafted work. Thanks!
  20. slddnmatt
    slddnmatt
    I will use my MIG to tack if I'm not able to position something and tack with the TIG to get it set. Then follow up with The TIG. My TIG is an older syncrowave 180. Usually have it set around 70 and I will use 023 mig wire when ****ing the panels. I use the mig (Miller 185) in certain areas on the chops, usually will have less distortion in the spots that I can't hammer. It's usually set on 2 & 50 and I use 023 wire
  21. brady1929
    brady1929
  22. ebfabman
    ebfabman
    Matt, are you going to address the support that the 51's have along the back edge under the trunk floor that is from side to side? Just wondering what you think about it? I have full 51 1/4's I had planned on using on my 50 before the 51 showed up. May still use them.
  23. shoebox1950
    shoebox1950
    Awesome work, Matt!
  24. slddnmatt
    slddnmatt
    I didn't add that support to the floor. I personally just think it was an improvement on the design in the floor to keep the sheet metal from bowing in the floor. I didn't think the new 1/4's would affect it at all one way or another. Like on this 50 the flathead was in the trunk so the floor was banged up and sagging a bit, and that structure would of stiffened up at least a section of the floor.
  25. ebfabman
    ebfabman
    Pretty much what I thought....great project.
  26. layedout49
    layedout49
    Very nice work . Just the thread I needed to look at for ideas and direction
  27. Zed
    Zed
    from FRANCE
    very kool Matt, thanks for sharing ;)
  28. slddnmatt
    slddnmatt
    Ok a little update on the build from where I left off. Been a bit busy, my wife had our second child a couple weeks back and I forgot how much sleep you don't get with a new born!! Got the upper and lower 1/4's all smoothed out and dollied, then gave the body a once over with the DA before I shot some epoxy on it. This car was 99% rust free but had some bad previous body work so I opted to trim off the p***enger rocker and replace the skin. Firewall was left stock, just filled in some holes...
  29. slddnmatt
    slddnmatt
    craigs50 117.jpg craigs50 100.jpg craigs50 102.jpg craigs50 110.jpg craigs50 113.jpg craigs50 115.jpg craigs50 111.jpg [/ATTACH] craigs50 110.jpg craigs50 113.jpg craigs50 115.jpg craigs50 117.jpg craigs50 102.jpg craigs50 110.jpg craigs50 113.jpg craigs50 100.jpg
    Picked up the ch***i from the powder coater and started running the fuel and brake lines, then got the body sitting back on the ch***is. Owner wanted to keep this car simple so a bolt on disc kit and dropped spindles is what was mounted up front. The rear is running a block.. You got to love Merc floor boards when they are as purty as that!
    bako48 and kidcampbell71 like this.
