I have a complete, original '36 Ford front bench seat with the exception of one vital part. If anyone has a '36 seat dis***embled, in pieces, I'd greatly appreciate a photo of the p***enger side seat adjustment pawl/ratchet mechanism. I have the center handle mechanism, the 2 rod links to either side, and the driver's side pawl and spring, but the p***enger side mechanism and spring are missing and I've not come up with a design that works with the existing seat frame and adjuster rod. I am ***uming it is a simple stamped steel piece with some bends and a spring which holds it engaged in the slots in the seat base. Thanks!
tennsmith, I can take some pics for you of the seat mechanism in my 3w, but I won't be able to do so until Friday morning. If somebody doesn't beat me to it, PM me ("Start a conversation" it's called now) and I'll post them for you.
