TH350 passing gear?
Discussion in 'The Hokey Ass Message Board' started by hotrod54chevy, Aug 9, 2014.
  1. hotrod54chevy
    hotrod54chevy
    from Ohio
    We're wrapping up putting a '65 283 in my '54 Chevy with a 350 ****** and I have some questions: the blown up engine we took out had aq-jet, the 283 has a Rochester 2 jet. I'm keeping the 2 jet because it runs and should be cheaper on gas, but what do I do with the p***ing gear? We bolted it to the inner fender until we replace the plug wires, but do any HAMBers have a suggestion of what to do with it? I might go back to a 4 barrel later, I don't know. I have to 2 intakes and 2 4 barrels, I just wanna know what to do with it in the meantime! Thanks, guys!
    It's primitive technology that is further compromised in the name of vanity.- HAMBer Cleatus
  2. deto
    deto
    Do you mean the kick down cable?
  3. hotrod54chevy
    hotrod54chevy
    from Ohio
    Yeah, I'm not too familiar with the terminology, I've just unbolted and rebolted what I've had. Here's a pic of what I've got. ImageUploadedByH.A.M.B.1407633543.708066.jpg
    The piece I'm talking about's on the p***enger side inner fender by the vent opening on the firewall.
  4. primed34
    primed34
    Put it back on the carb. It'll work with the 2 barrel. Might have to do some adjusting.
  5. hotrod54chevy
    hotrod54chevy
    from Ohio
    Where?
  6. tfeverfred
    tfeverfred
    There should have been a bracket. Or is that part of it in the picture? If so, connect it all back up. It should work together with the throttle ***embly, when you put the peddle to the metal. A heavy car, like a '54, will love a p***ing gear. Remember.... "What's behind me, is NOT important."
  7. hotrod54chevy
    hotrod54chevy
    from Ohio
    All the throttle brackets I currently have came off the q-jet. The 2 barrel just has the arms for throttle and choke. No brackets. The q-jet brackets won't work with this carb.
  8. tfeverfred
    tfeverfred
    You might hit the internet and find an illustration or picture of how it was all hooked up.
  9. gimpyshotrods
    gimpyshotrods
    Like so:
  10. hotrod54chevy
    hotrod54chevy
    from Ohio
    Thanks, yeah, I've already burned through google and seen a billion pics. That pic is actually from a thread with the topic of "this doesn't work, what do I do?" or something similar. I'm pretty sure I've got a TH350, not a 700R where a kickdown vs. TV cable is VERY important! I'll have to double check, but I think I know where I can get a bracket to use the cable. Thanks, everyone! Any other pics and advice is appreciated!
  11. gimpyshotrods
    gimpyshotrods
  12. junkyardjeff
    junkyardjeff
    Time to hit the junkyards and find a 2 bbl bracket.
  13. ev88f
    ev88f
    just put the quadrajet back on it. It'll get better mileage than the 2bbl anyway
    BORRACHO13 likes this.
  14. hotrod54chevy
    hotrod54chevy
    from Ohio
    Nononono... Just about finished putting an engine in, I'm not doing an intake/carb swap unless I have to!
  15. 56sedandelivery
    56sedandelivery
    There should be plenty of 2 barrel brackets in the wrecking yards. BUT, the TH350 transmissions sold by Summit under their "name", do not come with a throttle pressure/kickdown cable; even the hole in the trans for the cable is plugged. There are also some universal type, aftermarket, brackets sold that even come chrome plated. I'd still look for something off a factory motor. I am Butch/56sedandelivery.
  16. If it's got a vacuum modulator in the back, it's a T350.
    You don't need a bracket that bolts to the carb. It can bolt to the intake like the one in the picture. You might have to weld a couple of them together. Place the clip on part of the cable where you can get full pull at full throttle. That part is adjustable too, so need not be perfect.
  17. BLAKE
    BLAKE
    To answer your question, just set it aside until you find the right carb/bracket combination to let you use it. It won't hurt anything being disconnected.
  18. 325w
    325w
    As said it will not hurt the trans. But you will not have a down shift with the accelerator pedal to second gear. With that that 3400 pound chevy it would be nice to have and is a no brainier to hook up. You got the engine in what's one cable?
  19. mashed
    mashed
    from 4077th
    Manually downshift in the event you need to p***.
  20. hotrod54chevy
    hotrod54chevy
    from Ohio
    Will one of these work? ImageUploadedByH.A.M.B.1407776553.228293.jpg ImageUploadedByH.A.M.B.1407776562.295289.jpg
  21. txturbo
    txturbo
    That top one should work.
