Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. birdman62
    birdman62
    from mass
    I'm not sure what right is but I've done something i find right ha. Full Mustang 2 front end with KYB shocks around, full 5 lug conversion, ss brake lines, discs, 67 shelby master cyl, 67 8" rear, built 5.0 HO, t5 world cl*** ****** and soo on.. never would know
  2. gimpyshotrods
    gimpyshotrods
    Coming along. Back up to just 3" down. Wheels/tires would not clear.
    Front wheel arches, installed on the rear openings, are up next. Bat-rolling the lips was not enough.
  3. Mike51Merc
    Mike51Merc
    Sounds familiar. Working on mine this weekend.
  4. gimpyshotrods
    gimpyshotrods
    Looks good. I scored one fender already, and found another. Now, if I can just get the guy selling it to respond, in any way. Ahh, Craigslist.
  5. need louvers ?
    need louvers ?
    Gimpy, what side do you need?
  6. Mike51Merc
    Mike51Merc
    Just make sure you get a fender without a proportioning flange. You don't need it. :rolleyes:
  7. gimpyshotrods
    gimpyshotrods
    I scored it about two hours after the last post. Now I have both.
    The first one I scored is nicer than the one on the car already, so the original will likely become the donor.
  8. need louvers ?
    need louvers ?
    Cool, I have couple of beater fenders with good lips I could have cut and sent your way.
  9. gimpyshotrods
    gimpyshotrods
    We shall see, after media blast....
  10. Falcon61wagon
    Falcon61wagon
    from Indiana
    Im looking for rockers for my 61 and want to know if there are any available with the extension on the front, that wraps under the fender. I've called dearborn and they say its " exactly like the original but I'm not sure if the girl on the phone understands what I'm talking about. It should look like this. ImageUploadedByH.A.M.B.1406833740.818044.jpg
    Posted using my Big THUMB on a small screen!
  11. gimpyshotrods
    gimpyshotrods
    Who here has a pair of post-early-'61 6-cylinder spindles (later, full-size ball joint) that they want to part with?
  12. gimpyshotrods
    gimpyshotrods
    The part number should start with C2, or higher, like C3.
    For the uninitiated, in Ford dating nomenclature, C is the 1960's, with the number being the year. D is the 70's, etc.
  13. Mike51Merc
    Mike51Merc
    I have 63 V8 spindles if you're interested.
  14. gimpyshotrods
    gimpyshotrods
    Nope, thanks. Looking for 4-lug, 6-cylinder ones.
  15. need louvers ?
    need louvers ?
    I'll check and see what I have around the ranch...
  16. gimpyshotrods
    gimpyshotrods
    They would be for Falcon61wagon. He's doing an upgrade, and has the dinky little early ball joints.
  17. Falcon61wagon
    Falcon61wagon
    from Indiana
    I'm shocked, that somebody across the country would ask that for somebody they never met.… I do need those spindles! lol
  18. gimpyshotrods
    gimpyshotrods
    If us weirdos don't try to take care of each other, who will?
  19. need louvers ?
    need louvers ?
    I don't have any loose right now. I could probably lay hands on some fairly quickly and inexpensively if nothing is found closer. I wish I was done with the legalities on the wagon, I'd just send them out...
  20. lothiandon1940
    lothiandon1940
    08082014.jpg Just saw this when I was thumbing through some of my old R&Cees.....July 1965, Baltimore, Md. Anyone remember it? Apparently ran A/G with a punched out 389 Pontiac.
    zombie289 likes this.
  21. tyrannosullyrex
    tyrannosullyrex
    I may, I'll have to go look for a part number this weekend.
    MrModelT likes this.
  22. gimpyshotrods
    gimpyshotrods
    The part number should start with C3, not C0, C1. C0-1 are the earliest spindle, with the micro-joints.
    Should be something like C3DZ-3106-A and C3DZ-3106-B.
  23. 61falcon
    61falcon
    so I finally got the correct pitman arm. removed the old steering linkage and installed the new parts. I reused the outer tied rods and adjusting sleeves. the tie rods turned all the way in are to long. looks like I need to trim some threads off the tie rods and shorten the adjusting sleeve. also the center link hits the oil pan on full right turn. its a milodon deep sump pan. before I cut the adjusting sleeves, is there a shorter sleeve available?
  24. tyrannosullyrex
    tyrannosullyrex
    It's C1.
  25. Mike51Merc
    Mike51Merc
    Do the rod ends meet inside the sleeve? If not, maybe you just have rust built-up inside the sleeves. I sprayed some PB Blaster inside the sleeves and worked through the rust enough to get my toe-in set.
  26. gimpyshotrods
    gimpyshotrods
    Those are first-generation ones.
  27. gimpyshotrods
    gimpyshotrods
    If none turn up, I will dig out my first-generation ones, and re-taper them for you.
  28. LWEL9226
    LWEL9226
    from So. Oregon
    I had to shorten my tie rods about 3/16 in. (total on each side) didn't need to do anything with the sleeves.
    LW
  29. Falcon61wagon
    Falcon61wagon
    from Indiana
    I've found somebody parting out a 64 comet and a 65 ranchero I'll have to find out if either one of those has the right spindles and if he's asking a reasonable price.
  30. Falcon61wagon
    Falcon61wagon
    from Indiana
    On a side note I ordered a couple of new "ranchero" quarter panels for my wagon. They match fairly well.
