Customs Turn Signal Column Mount
Discussion in 'The Hokey Ass Message Board' started by gow589gow, Aug 9, 2014.
  1. gow589gow
    gow589gow
    from Indiana
    I make a turn signal controller which cancels with Inertia. I am working on a turn signal column mount for cars which are impractical to mount the momentary switch on the dash.
    I have a question I would like some input.
    For cars of all types with straight columns, What are your column diameters?
  2. 1 1/4 " & 1 1/2 "
  3. Fenders
    Fenders
    2" (made from exhaust pipe)
  4. gow589gow
    gow589gow
    from Indiana
    Is 1 1/4 and 1 1/2 generally standard on most 30's and 40's columns?
  5. tfeverfred
    tfeverfred
    I'd check a few manufacturers websites. They usually list the sizes.
  6. HOTRODPRIMER
    HOTRODPRIMER
    What ever the size of a 39 Ford is. HRP
  7. Jakesrocks
    Jakesrocks
    I'd sure like to see a pic of what you're manufacturing. If it looks better than the ****py turn signals already on the market, I'd be interested in buying one of yours.
  8. gow589gow
    gow589gow
    from Indiana
    What I have is an inertia based system which cancels the signal when it feels a turn has been made. It does a lot. Look up Cleverturnsignal.com. It uses a 2-position momentary.
    On some cars, the dash is close to the wheel. In my Pantera the switch is real close with the dash location. It is on the left here (no the dash is not covered yet):
    Cars with longer columns have a harder time with mounting a momentary. It is out of reach. I am coming up with a mount which is made from steel. I actually make this for something else but it lends itself well to making different sizes. If I can pin down a few key sizes I can make them for the older cars too:
    This is the unit mounted on a forklift column:
