Help on rear end
Discussion in 'Traditional Customs' started by olgraybeard, Aug 15, 2014.
  1. olgraybeard
    olgraybeard
  2. GeezersP15
    GeezersP15
    from N.E. PA
    What specifically do you need help with ??
  3. olgraybeard
    olgraybeard
    Havent used this app before on my phone I have a 37 Pontiac coupe that I have repowered working front to back. Got to rear end that previous owner put in. Need to get a postive id on it. It has 10 bolts on front smooth on rear I hope pics come out ok. Last owner seem to think it was a 57 chevy, it needs all new shoes spring cylinders maybe drums so I have to pin it down
    volvobrynk likes this.
  4. olgraybeard
    olgraybeard
    Also missing the front piece that clamps the u joint. I'm going to try to find a combination u joint to mate it to a drive shaft out of a 83 mustang
  5. squirrel
    that could well be a 57 chevy rearend. You can buy the U joint U bolts at a parts store. The flange will come off the Ford driveshaft...it may have the correct size U joint already, both Chevy and Ford used the 1310 series ****er joint in many cars for decades.
    http://www.rockauto.com/catalog/x,carcode,1326169,parttype,2404
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep, 55-57 Chevy rear ***embly. In 58 they went to coil springs, but 55-57 had leaf springs.
    Don
  7. olgraybeard
    olgraybeard
  8. squirrel
    looks to me like the driveshaft will be too short. you need it to fit into the transmission end pretty far...
  9. olgraybeard
    olgraybeard
    Good catch on your part, but rear end has to move forward at least 3 inches to center the wheels in the wheel wells so it will be OK. Got the u bolts for the rear u joint today and ordering the u joint Monday as soon as vendor gets back to me on the Mustang end. I found some conflicting info on the internet. I also got some 3" lowering blocks I need to put on before firming up the axle position. All this because I wanted to mount gas tank but had to deal with axle first.
    [​IMG] [​IMG]
  10. olgraybeard
    olgraybeard
    got axle lowered moved forward and mated to mustang driveshaft
  11. olgraybeard
    olgraybeard
    10836552_10203326098980915_1342778912_n.jpg 10846722_10203326099380925_276859808_n.jpg 10859525_10203326098660907_1522684647_n.jpg 10859661_10203326105341074_742763639_n.jpg 10863644_10203326099780935_1716077451_n.jpg 10867127_10203326100420951_2002961366_n.jpg Progress pictures drive train in ,brakes and wiring. lowered all around. put keyless door locks in today. Having windshield put in after Christmas, then I'll regester it. I put in the rest of the fixed gl***. just put on 15" rims on back with bigger tires.
    tb33anda3rd and volvobrynk like this.
  12. volvobrynk
    volvobrynk
    from Denmark
    That is a beautiful car! I like it a lot, tell more!
    Engine,trans, color and plans?
  13. 41hemi
    41hemi
    Just a small tidbit of info for you is that the rear axle ***embly most likely is a 55-56 Chevy rear. 57 rears have a drain plug in them. I think axle bearings are slightly different in 57 from the 55-56 rears. Good knowledge to have when ordering parts.
    olgraybeard and volvobrynk like this.
  14. Yes the went to a bigger axle bearing in 57.
  15. 55/56 bearing 2.835" O.D.
    57-64 bearing 3.00" O.D.
  16. olgraybeard
    olgraybeard
    3.8l ford v6, c5 auto got it registered 3 weeks ago...just finished duel exhaust, working on interior now, finally get to drive it around.....
  17. olgraybeard
    olgraybeard
    [​IMG] [​IMG]
    This is what she looks like now...working on interior now and having allot of fun driving it....lots of thumbs up
  18. olgraybeard
    olgraybeard
    [​IMG] [​IMG]
    work on it this summer slowed down alittle...driving it allot, quite a few cruise in and 4-5 local shows, fun project
  19. steinauge
    steinauge
    from 1960
    Neat car,not one you see every day. interesting engine choice.
