Technical 303 Olds Rocker arm help
Discussion in 'The Hokey Ass Message Board' started by Thirdyfivepickup, Aug 14, 2014.
  1. Thirdyfivepickup
    Thirdyfivepickup
    Guys, I have a friend in need of some ***istance. His Dad has a 39 Ford Sedan with a 1950 vintage 303 Olds motor in it. (Legit late 50s hot rod) It has Thomas rockers and he's looking for adjuster screws for them.
    OR... a whole new set of shaft rockers.
    Any idea where a guy could get this stuff other than eBay or swap meets? At this point he's probably going to get a machinist to make him some, but he would rather buy a couple and go rather than wait for someone to make them.
    Any ideas? I did some searches and didn't find anything here and not much on Google either.
    Thanks in advance!
  2. d2_willys
    d2_willys
    from Kansas
    With my 371 Olds, I had to provide a means of adjusting the valve lash. Isky sold adjustable push rods, which worked well. Don't know if they still sell them, but you can try.
  3. chopolds
    chopolds
    from howell, nj
    Search here for "goatroper". He builds wicked early Olds engines.
  4. Thirdyfivepickup
    Thirdyfivepickup
    maybe I was misunderstanding him, but he was looking for some sort of 'screw' for them. I ***umed it was an adjuster. I couldn't see where any other screw would be involved other than hold down?
  5. ROADSTER1927
    ROADSTER1927
    Contact tony at ross racing engines----goatroper here. Gary
  6. Pete
    Pete
    Look up smith brothers push rods! Awesome service and prices.
  7. TR Waters
    TR Waters
    from Vermont
  8. Thirdyfivepickup
    Thirdyfivepickup
    this is what he needs... he drew up specs to have some made. I appreciate the help so far. Any other ideas?
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
  10. RichFox
    RichFox
    In a somewhat similar situation, I used standard Allen screws that I used a ball end end mill to round and radius out the hex end. Put flats on the other end. I guess a screwdriver slot would have been just as good. And used a nut to lock the screw in place when adjusting the valve. I didn't have an oil hole but you could cut one in yours.
  11. Thirdyfivepickup
    Thirdyfivepickup
    im gonna get him in touch with Ross. Thanks fellas!
