Hey guys I came across a 4 door wagon that was in pretty bad shape..To much rot on the roof and front floor panel. Even the front frame area is rotted out. So I decided to take the parts I need and get rid of the rest..Anyone need anything? I'll post some pictures later. I listed a few things in the for sale section. I have two customlines and fairlane so sometimes one must be a donor to keep our cars going.
Where are you located? I might need some larger items and was wondering how close you are to Winchester, Virginia. Do you happen to know what rear is in the wagon?
Pfffffttttt... you should see what I've had shipped lately. Like the last post, Greyhound or try Fed Ex. I think the US postal will do big things but may have a over-size rate.
I think that I've found a dash that is rusted badly but the cluster may be ok. I didn't look past the rust on the p***enger side. I'll check when I go back that way and see if you still have the dash. Takes me a while to answer because I can't seem to get this site to send notifications. Thanks.
br***pike,When the HAMB did the upgrade the pm became "conversations" up on the top right you see the 3 icons,click on the head figure then click on "conversations" this is how you contact a member which will trigger an email letting you know they responded.
