a hambers websites list; or every site you need to know about
Discussion in 'The Hokey Ass Message Board' started by atch, Jan 6, 2006.
  1. atch
    atch
    a couple of years ago Brad54 started a post called "SOURCE, Reference Websites List"
    link here
    i look at it occasionally and today i tried to respond to it to bring it back to the top so that new folks could (a) see it and (b) add to it. well, it's in the "old hamb" and it wouldn't let me respond. so i copied it below for the same reasons.
    please add to the list if you can.
    (note: when i did a preview i saw that all my really cool formatting disappeared, so this is the way it's just gonna have to look)
    enjoy:
    Transmission ID: www.........
    FE Ford: www......
    Rear Ends Guide: www....
    194/215/230/250/292 straight-six specs, VINs, casting codes, production numbers, etc.: http://danielstrohl.com/sixinfo.html
    SBC Casting numbers: http://www.mortec.com/castnum.htm
    REAR AXLE WIDTHS REAR AXLE DIMENSIONS
    Mopar stuff: http://www.allpar.com/
    Engine castings: http://www.aacncclub.com/
    Buick facts, vin numbers, engine sizes, etc.: http://www.taperformance.com/referenc.htm
    Chevy W-Motor info, numbers, etc. at www.348-409.com
    just about anything for oldsmobile you could want to know.new and old.fatcs,vins,engines,and so on: Olds FAQ
    oldsmobile fullsize production statistics 61-64: 61-64 olds statistics
    Re-Pop Gas Tanks and Sending Units.
    http://www.cl***iccarautoparts.com - Used then, they were really good
    Replacement Suspension Parts
    http://www.espo.com - heard good things about them
    For those running Volary/Aspen/Chrylser/Diplomat front ends:
    torsion bar front end service manual
    S-10 T-5 info: http://www.vanpeltsales.com/FH_web/...storation-2.htm
    Flathead info: http://www.btc-bci.com/~billben/flathead.htm
    pinstriping: http://www.kustompinstriping.com
    "FlatheadEngineBuilding .. Tips and Tricks"
    http://www.jalopyjournal.com/ubbthr...rt=all&vc=1
    If you can't make it work; then go to the HAMB TECH-o-Matic.
    Generic Parts (I always look here first!)
    NAPA
    Auto Zone
    Checker/Kragen/Shucks
    ***le service: http://www.its-***les.com/index.htm
    The Old Car Manual Project; A TON of old manuals, brochures, etc. online and free - stuff like Rochester Carb shop manuals and the 53-54 Chevy Shop manual...lots of great stuff!
    nine inch ford rear info: 9" Ford rears
    lots and lots and lots of chevrolet identification and information links:
    Chevrolet ID links
    vintage Ford parts (including flatheads): JOBLOT Automotive
    The Hot Rod Works; quickchanges, open drive conversions, axle updates, etc.: The Hot Rod Works
    broken off bolt/stud removal: broken stud removal
    Modifieds: Daniel Strohl's Modified website
    early ford serial numbers: Early Ford Serial Numbers
    rivets; rivet tools; revet removal tools: Big Flats Rivet Company
    sandblasting materials and equipment: TP Tools
    shock absorber styles and dimensions: Monroe Shock web page
    automotive companies: Automotive Links
    a site with links to just about every automotive type company or manufacturer you could need.
    HUB CAPS
    Automotive company links...by Name or by Part..and 41 good Tech Articles from major magazines.
    http://www.seattlestreetrods.com/links_by_part.htm
    Help you find out your speed... http://www.richmondgear.com/101032.html
    old straight 6? go here: http://www.stovebolt.com/
    Turbo charge a chevy? Go here http://www.g****aperacing.com/G****ApeRacing/
    hood ornaments: http://www.lepoix.de/
    My site has about 8,000 organized links. To find links to parts manufacturers' sites, start here: http://www.roadsters.com/speed/
    Dave
    When those old "Reference" URL's, Bookmarks & Favorites come back as a "dead link", go to the "Wayback Machine" a portal to the web PAST!!
    And NOW, it's got a search engine! Kinda like Googling in the FOURTH dimension. How cool is THAT?
    Heres a good one for wheel bolt patterns: Bolt patterns.
    another wheel bolt pattern site: wheel bolt patterns
    yet another wheel bolt pattern site: another wheel bolt pattern site
    zoomie header baffle how-to: zoomies
    accelerator calculator:accelerator calculator
    no explanation necessary: awful awful fuel altereds
    rear axle dimensions
    Very resonable auto shippers that I happen to be using at this very minute....... Auto shipper
    rear axle widths and front track widths
    bonneville/scta web page
    brake adjusting
    buick engine identification
    nailhead identification
    small block chevy casting numbers
    6V to 12V conversion
    another 6V to 12V site
    flathead introduction
    flathead porting by AV8 (...VERY COOL...)
    gear ratio/tire size chart
    another gear ratio calculator
    Heres a good one for resizing pics so you can use them as avatars.
    avatar maker thingy
    Mostly muscle car info,but still holds alot of axle,engine and brake info in the archives:
    http://www.moparts.com/Tech/
    http://www.moparts.org/moparts/tech/index.html
    every thing HEMI... www.hemi.com
    1958 - 1969 Chev VIN decoder:
    http://www.1963chevrolet.com/tools.htm
    Links to metalworking sites:
    http://users.moscow.com/oiseming/lc_ant_p/lnk_mtal.htm
    Automatic transmission diagrams:
    http://www.aceomatic.com/catalog/au...cs/mfg.asp?n=gm
    Steering shafts, U-joints, support bearings- http://www.borgeson.com/products.htm
    Y-Blocks..... http://www.y-blocksforever.com/
    McCulloch Superchargers...... http://www.vs57.com/
    rpm calculator
    front suspension options
    volare, M-II, & camaro clip comparison for use in F-1 trucks
    saginaw ****** ratio identification chart
    build your own sand blast cabinet instructions
    sbc casting numbers
    MoKan Dragway website
    SCTA webpage
    speedometer faq's (united speedometer)
    more speedo information
    stationwagon.com; a longroof site
    suspension dimensions
    buick and cadilac casting numbers
    Supercharger info: http://www.dyersblowers.com/
    http://www.blowerdriveservice.com/
    http://www.goodvibesracing.com/technical_info.htm
    building a three phase converter
    muncie 4-speeds
    the "T-5" page
    nailhead ****** adapters
    ****** identifications
    "T-10" page
    "T-5" page (another one)
    tear drop trailer links
    47-54 chevy/gmc truck identification
    '50 chevy truck info and links (actually '47-'54)
    lot-o-tech links (ntba)
    wide and close ratio ****** discussion
    the hot rod works (banjo conversions, quickies, and bullit-proofing)
    another T-5 page
    tire size vs speed calculator
    source for ***les
    more ***les
    T-10 exploded views
    ****** id (really good)
    lots-o-****** info; gear ratios, etc.
    ****** gear ratios and speed calculator
    ****** adapters
    more ****** gear ratios
    still more ****** gear ratios
    even more ****** gear ratios
    twin engine dragsters
    lsr (land speed record) discussion
    utah salt flats racing ***ociation
    97heaven
    vintage speed; fuel systems
    volare clip install on '53 f-100
    weesner ('nuff said)
    decals
    welding message board
    metalshapers ***ociation
    '26 - '40 frame dimensions and sketches (Westcott's)
    wheel bolt pattern chart
    more wheel bolt patterns
    vaccuum windshield wipers
    zoomie baffles
    one more casting number decoding site
  2. burger
    burger
    Car Audio
    Ch***is
    Cl***ifieds
    Drivetrain
    Early Chevy
    Electrical
    Message Boards
    Misc
    Mopar
    Motorcycles
    Picture Sites
    Shows & Events
  3. VintageIgnition
    VintageIgnition
    Alliance Vendor
    from ma
  4. Automotive Stud
    Automotive Stud
  5. new2u
    new2u
    from Okla
  6. extremist
    extremist
  7. axle
    axle
    from Drag City
  8. mojo66
    mojo66
  9. Slide
    Slide
    Muncie 4-speed info I found helpful.
  10. Levis Classic
    Levis Classic
  11. 4tl8ford
    4tl8ford
    from Erie, Pa
  12. jerry
    jerry
    This needs to go to tech-o-matic!!!
    t
    Too damned good to lose.
    jerry
  13. nor cal nic
    nor cal nic
    WOW! thanks a lot... fu#$%'n cool.:D
    nic
  14. ian
    ian
    great post. this will all definitley come in handy for everyone sooner or later.
  15. Nixer
    Nixer
    Love it.
    tok
  16. mine, just stuff I like to save n look at-- G***ers = my current n past cars , Hamb stuff, tin,members cars and local to MN car show coverage
    http://groups.msn.com/g***ers
  17. atch
    atch
  18. graverobber63
    graverobber63
    Alliance Vendor
  19. joeycarpunk
    joeycarpunk
    from MN,USA
    This should definitely be in the Tech Archive, great post.
  20. Mutt
    Mutt
  21. Rocket
    Rocket
    from Austin Tx
    thanks for bringing this back to the newbies
  22. TRAVEZ
    TRAVEZ
    killer post!!!!!! thanks guys
  23. CGkidd
    CGkidd
    Awesome thread...
  24. jalopyshots
    jalopyshots
  25. chrisntx
    chrisntx
    from Texas .
  26. atch
    atch
  27. HOTRODRUBBER
    HOTRODRUBBER
    VINTAGE TIRES
    HURSTRACINGTIRES.COM
    PIE CRUST SLICKS AND CHEATERS
    CUSTOM CAPPING
    503-656-1572
    Thank You
    Cody Adams
