Technical What would be the "era correct" intake for a SBC?
Discussion in 'The Hokey Ass Message Board' started by deto, Aug 15, 2014.
  1. falcongeorge
    falcongeorge
    from BC
    Yea, I would agree with that. Most guys dont even know about the early carbs anyway. If it were me, and close enough was close enough, I'd use an avs instead, it looks just as much like an early afb as the later large neck carbs do, and its a superior carb.
  2. need louvers ?
    need louvers ?
    ...And again, '62 is well within the discussion at hand. The two, although obviously different, are close enough at a glance that it works. The slightly later stuff as you said uses the larger neck that is common to the Edelbrock to this day. That would be on of those deals where I would be tempted to run the later stuff with a few tweaks (yankin' the logo and dulling it down) until I could find the true earlier stuff. You, me and about 6 other people on this planet are really gonna know the difference.
    1Nimrod and enloe like this.
  3. falcongeorge
    falcongeorge
    from BC
    He actually said pre-62 in his first post. Chip is right that most arent going to know the difference, and that being the case, if you arent gonna do it right anyway, why not run the AVS with its 3 stage metering rods and more important, an easily adjustable air door? But if you are gonna throw down the gauntlet and call it "period-correct circa 1961" be prepared for someone to call you on it, because eventually, someone will. In those dreaded "musclecar" circles, its pretty common knowledge when the E-series came out.
    If it were me, and I was trying to piece together a set-up within the parameters of this thread, (period correct, low buck, 380 hp) I'd use a C355B with three rochesters.
  4. squirrel
    That would be the way to go. I wonder if you could get away with putting a 283 damper on it, too? we'd notice that just as quick...and the modern heads...etc
    1Nimrod likes this.
  5. Well these particular intakes are all the way on or all the way off performance. You could tweak them a little and make them a little more street worthy.
    1Nimrod likes this.
  6. falcongeorge
    falcongeorge
    from BC
    I'll make one more comment here. Just speculation on my part (based on 30+ years of flowbench and tuning experience) The C4B would probably improve a LOT if you milled the septum into two ovals, cut the divider down around 1/4 to 3/8", and smoothed and radiused the tops of the runners where they enter the plenum.
  7. I think that is pretty good speculation. A cross over helps about any of 'em.
    1Nimrod likes this.
  8. need louvers ?
    need louvers ?
    Hey George, what issue was that in? I remember it, but not which one.
  9. falcongeorge
    falcongeorge
    from BC
    July 2010. Its got a blondie pin-up in front of a bunch of old magazines on the cover, with a smaller photo of a red Model A coupe in the upper right-hand corner.
  10. need louvers ?
    need louvers ?
    Thanks man, I'll go pull it now.
  11. tcbigblock
    tcbigblock
    I go with an offenhuser 2x4 lowrise with a pair of 450-500 cfm afb's easy to tune and still streetable and it wont brake the bank .
    1Nimrod likes this.
  12. deto
    deto
    You guys are great. Thanks for all of the insight and knowledge.
    1Nimrod likes this.
  13. deto
    deto
    Is this manifold still reproduced or is it gonna be a swap meet find
  14. tcbigblock
    tcbigblock
  15. landseaandair
    landseaandair
    from phoenix
    Thanks for the numbers. Have a really nice C4B, just want to cruise with it. Top end charge may be lacking but could really shine down low and with economy.
    1Nimrod likes this.
  16. falcongeorge
    falcongeorge
    from BC
    Yea, I'd think it would probably give good part throttle fuel economy numbers...
  17. RICH B
    RICH B
    Swap are always a possibility; saw a couple 3x2 set-ups at the swap this weekend. Picked
    up this C357B and 97's with linkage a couple years ago at much better than new parts prices.
    1Nimrod likes this.
  18. deto
    deto
  19. deto
    deto
    Correct intake
  20. deto
    deto
    they mention it being a small cube motor. just how small was it?
  21. RICH B
    RICH B
    316. .060 over 283 with a 327 crank. Wouldn't that like be glorified way of describing a .60 over 307.
  22. deto
    deto
    I might just go belly ****on and run a 350 but every once and awhile a nice 283 or 327 pops up on Craigslist. That's a good over view of what to expect. Thank you.
  23. deto
    deto
    @falcongeorge what were the cam specs?
  24. falcongeorge
    falcongeorge
    from BC
    Well yes, Rich, and thats the way I would usually describe it, but here on the HAMB, its a "stroker 283"...:rolleyes::D
  25. DenverDave
    DenverDave
    from Denver, CO
    Weiand Dual Quad
  26. tcbigblock
    tcbigblock
    I am sure the 3 twos could be made to work better to maintain the right air fuel ratio with the right linkage and tuning, finding the right carbs can be tuff , and the cost ?? 2x4s is much easer and cost effective . and they look COOL !!
    1Nimrod likes this.
  27. 4 pedals
    4 pedals
    from Nor Cal
    Where did Offy come in? Weiand? Others? Seems there used to be plenty of old intakes kicking around with tubes in the front of them.
    Devin
    1Nimrod likes this.
  28. tcbigblock
    tcbigblock
    Another thing to look at is the car set up
    a heavy car with 3:08 gears 8:1 compression and a small cam stock converter will like the 3x2 setup
    a light car with 4:11 10:1 and up compression mild cam 26 " 28" tire will love the 2x4s
    1Nimrod likes this.
  29. An off the shelf 307 had a bad deck height. When people were stroking 283s using a 327 crank you could buy pistons with the proper piston pin location off the shelf. I have heard that TRW still makes the proper piston but I can't remember the part number and the guy at the counter is not going to know it or know how to find it. You can buy custom pistons from companies like JE.
    Anyway in answer to your question NO.
    1Nimrod likes this.
  30. tcbigblock
    tcbigblock
    Yup, that sounds right, 307 was a torque motor ok, but I would not build one .
    I liked the 302 setup 327 block 283 crank but its hard to find a small journal 327 block
    opps I am off topic , sorry
    1Nimrod likes this.
