New KING CHASSIS dragster build
Discussion in 'The Hokey Ass Message Board' started by ChassisResearchKid, Apr 15, 2011.
  1. ChassisResearchKid
    ChassisResearchKid
    from Michigan
  2. dragsled
    dragsled
    from Panama IA
    Beautiful work on the car , great attention to detail, is that zebra wood on the handles,,,, Tim Jones
  3. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Yes Tim, African zebra wood.
  4. dreracecar
    dreracecar
    from so-cal
    You need to "Key-Hole" the tab for the rerverser, after awhile they tend to get loose and pop out of gear. Since the tab is welded to housing-now would be the time to change it.
  5. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Bruce. I can still so that and that is the plan. I just plan on slotting the tab and turning a grove in the handle on the lathe.
  6. Hi Harry, I was curious I've seen the chute pack bodies for sale but not one that goes over the cage. Is that available from somewhere or is it hand made?
  7. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    That was a one off body done for my chassis with the agreement between Harry and my self that no other bodies be made from my bucks. I haven't heard from Harry in a while, but he's a talented, top notch craftsman that I'm sureyou'll could help you out with a body if he is still doing that of work.
  8. saltflats
    saltflats
    from Missouri
    Cant believe that I have missed this one. You have a great looking car hope to get a chance to see it run .I need to get over to King chassis and check him out I have got to have a digger some day.
  9. powrshftr
    powrshftr
    This is the thread that got me to become a member of the site man.
    Have you read it right from the start?Cause it is nothing short of amazing.
    I can't wait to see this car finished.The level of work on it is absolutely top notch.:)
  10. saltflats
    saltflats
    from Missouri
    Yes I did Scott I have wanted a digger as long as I can remember. All I can say is this car is bad ass.
  11. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Sorry once again for the delayed updates, but when the Hollish car comes out work stops on the new car. Winter is on the way so I'll get back on it soon. I did manage to score Don Long spill plates and connecting rods for a front wing. Everything was "raw" and needed to be machined and hand filed. wing.jpg wing2.jpg
  12. dragsled
    dragsled
    from Panama IA
    Man that looks Great!!!! Tim Jones
  13. seatex
    seatex
    Beautiful, just beautiful! OUTSTANDING!
  14. rd martin
    rd martin
    from indiana
    dam todd! that thing sure looks great! cant wait to see it in person. it will be worth all the hard work and time!
  15. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Thanks Rich, Stop by when your in town.
  16. rd martin
    rd martin
    from indiana
    I have to do that todd, I just moved , busy as hell, but I will get up to see that car! dave c. just had surgery, call him when you can.
  17. hlhpa
    hlhpa
    King:
    I was reading some of your old post and I have a 1959 FED, have just put a 409 in it, and now putting a Cubert in and out box, which has a six spine out put shaft, like I saw in your 2009 post. I need to have one made like did. Any suggestions
    I have been running Buick with Ford 1940 trans with 2nd/3rd, hooked to 40 Ford rearend with a Scotty Fin safety hubs, have been thinking about putting Ford9" axles in banjo housing.
  18. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    DonoWizvans.jpg polished.jpg polished1.jpg cover2.jpg cover1.jpg cover3.jpg cover.jpg wing4.jpg wing5.jpg wing6.jpg rockers.jpg up.jpg mounted.jpg mounted1.jpg Well It's been a while between updates but here is the latest. Body mount tabs 95% installed, Corey Conyers updated my Donovan breathers to make them NHRA legal (per my Ideas). Coupler cover made, Valve covers polished, Intake polished. Matched the wood from the pedal, wheel, and brake handle to the front wing and got my Dearmore Rockers from Roger (RiceMan) Lee. Not much else to say for now.
  19. AHotRod
    AHotRod
    Wow .... the dragster is "Spot-On-Perfect" !
  20. ChassisResearchKid
    ChassisResearchKid
    from Michigan
  21. UK Slingshot
    UK Slingshot
    How did you make your breathers NHRA legal. Got some MT breathers similar that I need to do something with.
  22. rooman
    rooman
    Ponti461,
    look closely at the photos and you will see a stub for the burndown tube welded to the front breather stack on each cover. Really only required if you plan to run NT/F but not a bad idea.
    Roo
  23. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Rooman is right. However the top of the breather was also cut off and and a plate welded into the mushroom part to seal it up and make it a non-breather.
    Ponti461 likes this.
  24. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    Well, the body is 95 percent mounted. Scored a real Frankenstein Magneto. I'll be mounting the swing clutch pedal at some point this weekend.
    Ponti461, powrshftr and saltflats like this.
  25. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    More.
  26. 51box
    51box
    from MA
    Looks really good man, can't wait to see it done. What are your current paint plans?
  27. ChassisResearchKid
    ChassisResearchKid
    from Michigan
    A nice early Ford non metallic maroon / burgundy.
    powrshftr likes this.
  28. ChassisResearchKid
    ChassisResearchKid
    from Michigan
  29. powrshftr
    powrshftr
    Todd,say it ain't so....Just take some time,step back for a bit,and come back to it Man.
    30dodgeboy likes this.
  30. ChassisResearchKid
    ChassisResearchKid
    from Michigan
