Hot Rods supercharged banger modified...now has a V8
Discussion in 'The Hokey Ass Message Board' started by Clark, Dec 7, 2013.
  1. Grahamsc
    Grahamsc
    from Colorado
    Clark
    The crank pulley is 6.5 in
  2. Clark
    Clark
    Grahamsc...thanks again....right now im a little under driven at 5.5
    Mac... Here's the grill. I cut 2.5 out of the middle and 4 out of height. The emblem emboss was round with a bump out on the right
  3. Looks like '28 Studebaker (either Commander or Dictator), but the crank hole doesn't match- did you graft that in something else, or is the crank hole the original?
  4. woodbutcher
    woodbutcher
    :cool:Now that looks like its going to be a fun ride.
    Good luck.Have fun.Be safe.
    Leo
  5. Clark
    Clark
    Crankhole is original.....I cut either side of it so I could keep it. I found a couple that looked right but the crank hole didn't match I searched a lot of late twenties cars. It was chrome, so I doubt it was truck.
  6. squigy
    squigy
    from SO.FLO.
    You sir are the man!
    That is gonna be ***ties!:)
    Clark likes this.
  7. Very Interesting. I put a magneson blower on Dodge colt once in the 70s but it is a roots type. Long before magneson was into automotive blowers. Have pic but a colt isn't hamb friendly. Always wanted to try mounting a centrifugal style blower on the front of one of my slant six motors with the fan proper bolted to the crank pulley/vib damper. I figured I might have to make the whole thing. This deal even though the blower is not crank mounted has rekindled that flame. I will be watching to see how this turns out.
    don
  8. RichFox
    RichFox
    As it happens I have a couple of those supercharger heads that were cut from the angle drive, which got used for something else. Of little or no value to me. I also have a pretty large turbocharger from a GM 8:92 diesel. At one time i was thinking of a belt driven blower. I looked at an Air Cycle machine from a B-52 at a swap meet. $25 fresh from O'haul with the manual. Should have bought it. If you re interested in a compressor I mentioned email me back.
  9. Clark
    Clark
    Got the metal work done and it's now in primer
    volvobrynk and Outback like this.
  10. Clark
    Clark
    Here's a shot of the tank in the works
    volvobrynk, Outback and Kjell Elias like this.
  11. Clark
    Clark
    Getting there!!
    Clark
  12. Outback
    Outback
    from NE Vic, Oz
    Woohoo!
    Sent via carrier pidgeon & smoke signals with the HAMB App
  13. What is the extra rear cross member for?? I do not see it in the previous images.
    Great build......collecting parts for one similar....
  14. Clark
    Clark
    It's for the gas tank...more pics later
    Clark
  15. Clark
    Clark
    Rick's can you see it now? The idea was to hide the spring to make the rear look like it's just floating out there.
    Clark
  16. Clark, that looks fantastic- reminds me of the '15 Stutz Indy team cars :D!
    volvobrynk and Clark like this.
  17. Quite a simple rear end setup...
    When will it make noise?
    volvobrynk likes this.
  18. Clark
    Clark
    It's gotta run for the Race of Gentlemen
    Clark
    MrModelT likes this.
  19. hrm2k
    hrm2k
    damn cool Clark
  20. Grahamsc
    Grahamsc
    from Colorado
    I'm really digging this Clark.
    Is there a chance you could post a couple more picks of the rear suspension?
  21. Clark
    Clark
    I'll have to take some more pics....might take a day or two
    Clark
  22. Grahamsc
    Grahamsc
    from Colorado
    Thanks
    When ever it works out
    You are moving way faster on your build than I am.
  23. Six Ball
    Six Ball
    from Nevada
    Clark, This is a great build. Thanks for telling me about it.
    Even though I have logged thousands of hours on 8Ns & 9Ns I have never had one of those engines totally apart. Do they have oil pressure to the rods? You might get water for the SC by tapping the water pump or the housing near the top hose and return it to the drain hole on the block. What frame did you start with and what is the front axle? A '49-'53 Merc trans with the BW OD should bolt right on.
  24. Rusty O'Toole
    Rusty O'Toole
  25. Clark
    Clark
    20140823_163936.jpg 20140823_164019.jpg 20140823_163936.jpg 20140823_164019.jpg 20140823_164108.jpg 20140823_164034.jpg
    Graham..here's the rear pics. I added a gusset to the rear bones. I know everybody says you can't split the rear bones......I've done several cars with the later short bones and had no problems. One car we beat hard too.
    The axle bells are just flipped side to side to put the springs infront of the axle.
    I do need to add a lead or two to get some clearance
    Clark
  26. Clark
    Clark
    I'm gonna start out without the water to the supercharger.
    The frame is an Es***. The front axle is a most double dip. Not sure of the year.
    Here's the steering box mount. The box is a 42/47 Chevy truck
    Clark
  27. 34Fordtk
    34Fordtk
    Great build man! I for one would like to see a full shot of the car if you get the chance.
  28. Clark
    Clark
  29. Six Ball
    Six Ball
    from Nevada
    This thing is looking soooo good and moving quickly. Did you make the steering box mount or is it stock from the 42/47 Chevy truck?
  30. Clark
    Clark
    I made it...lots of welding and grinding. Wanted it to look like a cast part.
    Clark
