Hot Rods Replacement axle quality. Forged or Cast
Discussion in 'The Hokey Ass Message Board' started by FlyingTB, Aug 25, 2014.
  1. FlyingTB
    FlyingTB
    I have a '33 Plymouth that was completed 30 years ago. I put in a used Ford dropped I-Beam with Four Bar front suspension. That axle was dropped 5" and stretched to 50" by Mor-Drop Axle Company. It served me well over the years.
    A few weeks ago traveling 60+MPH I ran into a drive shaft that fell out from under a truck in front of me on the highway. That impact bent my axle back about 4" to 5". I want to replace the axle with one that's 48" and a 4" drop. I've read a number of older posts on here about poor quality, possibly off shore cast iron axles breaking. I'm very afraid that if I had one of those under my car the results would have been a lot worse. I know this has been asked and answered several times but all those posts are quite old. Things change and I'd like to know more about the current availability. How do I make sure I'm getting a forged, made in USA, axle?
  2. racemad55
    racemad55
    Find someone with a press that will straighten your bent one.
  3. FlyingTB
    FlyingTB
    I want to put in a narrower axle with less drop to get it off the ground a little. I figure now is a good time to do that.
  4. racemad55
    racemad55
    Ch***is engineering.
    FlyingTB likes this.
  5. xix32
    xix32
    Cast axle? try to find the January 2014 issue of Street Rodder, go to page 70 lower left, look at the photo of a broken cast axle from a relatively minor collision.
    Ch***is Engineering in Iowa used to make the only U.S.A. made forged dropped axle, there may be others now, but not sure where they come from.
  6. Unkl Ian
    Unkl Ian
  7. TagMan
    TagMan
    Ch***is Engineering, hands down !
  8. hayu
    hayu
    As they said ch***is engineering. So Cal now makes a forged axel also.
  9. ALEISTER
    ALEISTER
    Had one of those "Magnum" axles that were in question. Now a wall hanger in the garage. Replaced it with the Ch***is Engineering axle. I believe the So-Cal axle is forged, but done so offshore, the Ch***is Engineering axle is USA - Forged. I've heard they have them forged by John Deere, can't confirm that though. Nothing wrong with an original "Henry" several good options on guys that will drop them.
  10. Texas Webb
    Texas Webb
    Check with Okie Joe or Sid (Oklahoma)to get one dropped.Always axels in the for sale section here, Fordbarn and local swap meets.
  11. quickchangeV8
    quickchangeV8
    Absolutely Ch***is Engineering forged axle or original Henry Ford forged axle. Made right in the good old USA!! Hold up either one of these axles and give it a light tap with a hammer. These axles will ring. That ring is the sound of quality. Don't even look at the cast axles. In my opinion they are nothing but ****.
  12. FlyingTB
    FlyingTB
    Well, I decided to buy the axle from Ch***is Engineering. I contacted them today and asked for 48" Kingpin centers axle with 36-1/2" between spring perch hole centers. They said they can provide a 47-1/2" axle with 36-1/2" but it would come from So-Cal. I checked them out and they also have forged axles but not for this size. Their 48" axles are Super Bell from Pete and Jakes and are Cast Iron. It seems that everywhere I turn there is nothing but cast iron axles available.
  13. HOTRODPRIMER
    HOTRODPRIMER
    I wouldn't worry about a 1/2 " and I prefer a forged axle,,I have Ch***is Engineering axle under both my Deuces. HRP
    saltflats likes this.
  14. FlyingTB
    FlyingTB
    I can work with the kingpin centers bring anywhere between 46" and 48". It's the spring perch hole center that's causing an issue. It seems the choices are 34-1/2" or 36-1/2". I need the 36-1/2" otherwise the bat wings end up right against the frame.
    I can't find anyone supplying forged axles with 36 to 36-1/2" between perch hooked. That includes So-Cal and Ch***is Engineering. The gal at Ch***is Engineering said it takes two years to get an order for forged axles filled.
  15. scrap metal 48
    scrap metal 48
    I think cast axles are cast steel not cast iron and are considerably stronger than cast iron.. I wonder how many cast steel axles are still in use without any problems...
  16. gimpyshotrods
    gimpyshotrods
    Just get that on straightened.
    This is a Model A axle. You didn't hurt it:
    Hitchhiker and saltflats like this.
  17. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I'd get a gennie axle and have Sid magnaflux it and drop it to your specs. He's the real deal.
  18. El KaMiNo KiD
    El KaMiNo KiD
    After looking at that pic an original axle is the only way to go..
    gimpyshotrods likes this.
  19. RidgeRunner
    RidgeRunner
    from Western MA
    The tour guide pointed out an axle like that hanging on the wall at Speedy Bill's museum in '08. Might have been that exact same one, IIRC he said Henry had it done to demonstrate how though they were. Impressed me enough That I'd follow the advice of others and get an original done to your specs by someone reputable if I were in your situation.
    Ed
  20. flthd31
    flthd31
    Magnum does make a tube axle with the exact dimensions you need. Axles are made with 1018 forged steel ends with 2"x.250" wall 1018 seamless tubing. The ends are welded into the tube.
    I had one of these years ago in a '47 coupe with the wishbone still intact...nice beefy axle. These are best used on cars with original wishbones because there is no axle twist during suspension travel.
    Forged I-beam would be best but it should work fine in under your Plymouth with 4 link suspension.
    Here's a link to their product list:
    http://magnumaxle.net/MagnumAxelCatalogWeb.pdf
    And don't toss that bent axle, it can be straightened perfectly quite easily with no heat or impact...just needs a large press and some experience.
  21. FlyingTB
    FlyingTB
    That Magnum axle looks interesting. I had ruled out the tube in favor of the I-Beam because of the twist, or lack of, factor but that I can't find a forged I-Beam the tube is looking better.
  22. FlyingTB
    FlyingTB
    I sent him an email. I see he sells SuperBell axles, which are cast. I'm curious what he'll have to say.
  23. FlyingTB
    FlyingTB
    I talked to Sid. Yes he is the real deal. He'll tell you that he doesn't drop the '28 to '36 Ford car axles. He referred me to Joe at Joe's Speed Shop. After talking to him I found my solution. An original Henry Ford axle dropped the way I want it. He does it all the right way. These guys are getting harder and harder to find but they're out there. I guess there's just not enough of us left that want that old style Hot Rod. IFS has taken over. Everyone says you have to do that if you want a good ride and handling. I think if that's what I wanted I'd go to a new car dealer. Just my opinion.
  24. El KaMiNo KiD
    El KaMiNo KiD
    IFS and hot rod don't belong in the same sentence. ..I was pretty sure Sid didn't drop early ford axles..just didn't want to give out wrong info...been there done that..
  25. 2935ford
    2935ford
    I sent Okie Joe two of my axles.....a '32 and a '34.....had them both dropped 4"......he does very nice work.
  26. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Whats the going rate to get a ford stocker dropped nowadays?
  27. El KaMiNo KiD
    El KaMiNo KiD
    Okie joe charges $200..core charge between $50-$75..32' heavy is $400.. I have a model a & 34' axle I want him to drop...thats a great price IMO..if I recall correctly 296v8 was charging $300..
  28. FlyingTB
    FlyingTB
    Thanks! I called Sid and hooked up with Joe. Both sound like they know the right way of doing things.
