Projects 46 chebby coupe
Discussion in 'The Hokey Ass Message Board' started by wheelnutmarc, Jan 29, 2014.
  1. wheelnutmarc
    wheelnutmarc
    photo's for the last post!!
  2. wheelnutmarc
    wheelnutmarc
    20140428_212343.jpg 20140501_225332.jpg next after tack welding the front bodymounts,finnish welding the corners and mounting it on the bodyrotator .
  3. wheelnutmarc
    wheelnutmarc
    20140515_225427.jpg 20140515_225437.jpg 20140508_225120.jpg 59 old's bench shortened two inch on both side's by Sander,and he made the new floor posts for the seat.
  4. wheelnutmarc
    wheelnutmarc
    And build a gas tank for in the boot,behind the rear seat.
  5. wheelnutmarc
    wheelnutmarc
    1401053386432.jpg Redo the rear fender welding and reshaping the patch panels to perfection
  6. wheelnutmarc
    wheelnutmarc
    Other side is next.looked like the inside off a cave , so removed the bad and inn with the good!!
    And copied the other side with some Sander's hand made handy cleaver tools,with measured,
    markings as guide line's
    10366248_10202011798205565_6716157824855050549_n.jpg 10371651_10202011797765554_1475392341254989425_n.jpg 10366226_10202012087412795_4511565534356709657_n.jpg
  7. wheelnutmarc
    wheelnutmarc
    Sander finnished welding the rear fenders
  8. wheelnutmarc
    wheelnutmarc
    Supports where made and a floor made too
  9. wheelnutmarc
    wheelnutmarc
    Now where cleaning up the underside,and some minor spots need fresh metal before i can apply anti rust stuff and paint.
  10. wheelnutmarc
    wheelnutmarc
    Meanwhile the frame is on the move,and made it to it's second outing and car show!!
    Thats on the back of the coe made by Sander of corse.:D
    kiwijeff likes this.
  11. wheelnutmarc
    wheelnutmarc
    Small update:last "small" patch panel in the floor,replaced previeus bad repairpanel.
    The V shaped bit in the boot is also cut out and replaced by a fresh pice with double beat roll
  12. 47.Poncho
    47.Poncho
    Very nice work. Your coupe is a business coupe. The hole you guys filled on the p***enger side behind the door was where the gas tank filler neck was. Business coupe ment no back seat, longer package tray, and different trunk floor. The 49-54 front end swap is a good idea. Thats what I did and it rides great. I've been over 100 mph in mine and it's fine. Just make sure to pack the re pack the bearings if your driving it lots. Keep up the good work.
  13. wheelnutmarc
    wheelnutmarc
    Thanks 47.Poncho!
    Youre right the body is from a 47 business coupe,and they aready butchered out the longer package tray and filled the hole in the side panel.
    I've got 54 front hubs and 60 corvette drums witch only needed 5 mil turned down and fitted right away.
    And the bearings are firmly packed with high grade wheelbearing grease,thanks for the tip.
  14. wheelnutmarc
    wheelnutmarc
  15. wheelnutmarc
    wheelnutmarc
    And rejoint with the ch***is for now,to fit the doors and boot to check fitment and gaps.
  16. wheelnutmarc
    wheelnutmarc
    And putting on a skim coat of filler and a coat of primer to check things out.
  17. wheelnutmarc
    wheelnutmarc
    Test fitted the grille and front sheet metal,after a little fitteling and checking the gaps,a little skim of bondo to get some bumps and dings fixt.
  18. wheelnutmarc
    wheelnutmarc
    Grille !!!
    philedealer likes this.
  19. Great work !! Are you painting it Sport Beige ?
  20. wheelnutmarc
    wheelnutmarc
    Try to make it an original kolor sceme from chevrolet
  21. Same colour as mine ;)
  22. chopolds
    chopolds
    from howell, nj
    Looking great!
  23. wheelnutmarc
    wheelnutmarc
    First coat of real paint,not the final color!!for a basecoat and look for hidden low spots and scratches.
  24. mgtstumpy
    mgtstumpy
    Great transformation. Can't wait to see it finished.
  25. wheelnutmarc
    wheelnutmarc
    Got the final color on the body and put it back on it's frame for the final time.
    redzula and kiwijeff like this.
  26. motoandy
    motoandy
    from MB, SC
    Very nice. Love the color combo. Great work.
  27. wheelnutmarc
    wheelnutmarc
    Got the hardwood floor in,and one coat of clear for wood.
    And the gas tank retuned from a friend,who put on some stripes an customised ethyl logo.
  28. wheelnutmarc
    wheelnutmarc
    Doors and bootlid fitted,pulled and repainted the engine,striped/decorated the fire wall,and refitted the motor,radiator and inner fenders.
  29. wheelnutmarc
    wheelnutmarc
    Engine!!
  30. Rusty Heaps
    Rusty Heaps
    looking good , lik your progress
