1952 Ford F1 gas tank location
Discussion in 'The Hokey Ass Message Board' started by Bob 1743, Nov 14, 2010.
  1. JonF
    JonF
    I'm agreeing with those who think the stock location is best and behind the pumpkin is the worst. Has anybody figured out what tank will sit in frot the rear end on one side or the other between the frame rails? That's where it is on my OT late model Ford pickup.
  2. ironpile
    ironpile
    Between the frame rails behind the rear end,my filler neck is in the bed but it doesn`t bother me
  3. hopped up
    hopped up
    from So Cal
    I wish i could use the stock location, but with a channeled cab i think the mustang tank will work best for me.
  4. RagtopA
    RagtopA
    I have a 51 Ford F1. I had to replace the gas tank behind the seat in the cab. I bought new mounting pads but for the tank but for the life of me can't figure out where go. They are hard rubbe, about 1.5" X 3" X 1/4" thick. Any hints?
  5. mtflat
    mtflat
    The tank seam flange locates in the long slot on the floor - the pads are attached to the bottom of the tank either behind or in front of the seam. They keep the metal tank from contacting the floor. I stuck mine on the tank with a dab of silicone caulk.
  6. rusty1
    rusty1
    ditto on the 'Stang tanks but I use early ones ...64-68, they fit perfectly and cheap, less than $200 for new tank and sender.
  7. RagtopA
    RagtopA
    Awesome, I get the picture. Thanks.
  8. Wrigley61
    Wrigley61
    ?? I recently bought a 1951 Ford F1 and the tank is in the stock location. The fumes are awful. Any suggestions on where I should start in remedying this?
  9. InPrimer
    InPrimer
    check the drain area under the tank, it has a rubber line( at least mine did)other than that it could be a cap issue. personally in another thread where tank placement is or should be my preference is way in the back where the spare is, I have a 16 gal poly tank
  10. atch
    atch
    i know that the post i'm answering is a year old, but maybe someone else needs the information.
    48-52 panel trucks use the same frame as the pickemup truck. obviously they don't have a tank behind the seat. the stock ford gas tank on them sits between the left framerail and the driveshaft. the filler runs upward and outward. one of these tanks would fit right into a pick up. the filler would then be routed through a new hole in the splash apron/running board behind the cab but in front of the rear fender.
  11. THR1LL3R
    THR1LL3R
    from St. Louis
    Mines in the stock location, put it under the bed and you can't fuel up when you have a load in your bed and if you don't use your truck like a truck youre no friend of mine...
  12. Mark in Japan
    Mark in Japan
    Kind of like, 'why don't they make the whole plane out of the stuff they use for the black boxes'???
  13. Ford52PU
    Ford52PU
    from PA
    I put a 20 gallon mustang tank in my 52, ran the filler out to the driver side fender and used a marine style filler. My old tank was rusted thru from sitting, plus I'm fat and moving the seat back even a little helped.
  14. Normbc9
    Normbc9
    All of that vintage F series came stock with a behind the seat gas tank unless it was an f-5 or larger which had an option for a set of saddle tanks. We got the stock version in our F-8's and had a aftermarket 36 gallon steel tank installed under the skid pump package. Those all served until 1974 when they were sold. I saw one last week still running with the 336 V-8 flat head and the aftermarket tank still functioning. They are available on line. I also see a 18 gallon version online also.
    Normbc9
  15. Abomination
    Abomination
    I've seen this setup from the factory - the filler was inside the rear fender though. Inside the wheel well!
    It was on an old flatbed or something.
    I figured I'd use the stock, in-cab tank and the delivery tank as well. If I have the space, and am towing a camper through the mountains, why not?
    ~Jason
  16. atch
    atch
    if you're using both can you just connect the tanks with a tube/pipe/hose and just fill the top (behind the seat) one; which would fill both (and draw/use out of the botton tank)?
  17. Jetpro
    Jetpro
    from Alaska
    I am still undecided. Would someone share pics of the filler routed from the mustang tank? Thanks
  18. rusty1
    rusty1
    ...early Mustang in mine but mounted it under the bottom of the framerails
    using small square tubimg to get it to sit level., fills thru bed floor, but you get used to it. You can run the filler out to the side of bed or fender , or down thru the stake pocket, but make sure your filler pipe has slope on it or gas will kick back when filling tank.
  19. ChefMike
    ChefMike
    I have a 47 ford and dont want the tank under my seat so I built a cabinet in the back of the bed thefiller neck is in the side of the bed drivers side and for a door on the cabinet I used a later year ford tail gate, for pins to lock the gate Im using tail gate locks. photo doesnt show them but found a set they look and work great
  20. ChefMike
    ChefMike
  21. rusty_bits
    rusty_bits
    I put a saddle tank out of the same era panel truck (1948 Ford) between the inside of the left frame rail and the drive shaft, using the stock mounting brackets and straps. I relocated it slightly aft and I modified it to suit filling from the stock location on a pick-up (p***enger side), I also modified it to accept my Dodge Dakota electric fuel pump and pressure regulator. So far everything seems to be working fine, and it leaves room for the spare tire at the back, and a motorcycle in the box.
  22. 52lomofo
    52lomofo
    wheres your filler location at on this??drivers side
  23. Right rear. You can either put in in the bed or just under the tailgate. Facing out the back. I've done it both ways.
  24. Abomination
    Abomination
    :cool:
    Glad this one came back from the dead - it's kind of cool seeing different solutions to the same problem.
  25. aerocolor
    aerocolor
    from dayton
