Technical 235 Idle issue
Discussion in 'The Hokey Ass Message Board' started by tkmark, Aug 23, 2014.
  1. tkmark
    tkmark
    Guys, I'm try to get my '61 235 broken in but she's not wanting to run smooth or idle. It has a mild cam, Fenton dual exhaust, offy dual intake with Carter Weber carbs, Langdons HEI distributor. Everything is fresh but after I get it started, I have to keep both hands over both carbs before it smooths out and runs pretty well. I've adjusted the idle screws in and out but it makes no difference. It did start the first time and ran pretty well without any adjustments, etc. but it's been downhill ever since. This is in a 1950 Fleetline w/ manual trans. Sure could use some help. Thanks, Mark
  2. tfeverfred
    tfeverfred
    My friends all run 235's and when this problem pops up, it always seems to be choke related.
  3. tkmark
    tkmark
    It has electric chokes and they appear to be working fine. I have to choke it even more with hands over the carb venturi's to make it run smooth. Help!!
  4. tfeverfred
    tfeverfred
    Let me see, if I can reach a friend with your basic set up by phone. I'll get back.
  5. tfeverfred
    tfeverfred
    No answer, he must be away from his phone. I'll try again later and get back. This guy is an engine guru and just built your same basic setup for a customer. Stay tuned. No pun intended.
  6. saltflats
    saltflats
    from Missouri
    Have you sprayed around with some car cleaner to check for vacuum leaks?
    If they are new carbs there could be some machining particles in there causing problems.
  7. Dave Downs
    Dave Downs
    from S.E. Penna
    Sure does sound like a vacuum leak. 235's can be a little tricky to get the intake to seal especially when have aftermarket intake/exhaust manifolds. The little 'C' shaped things that bridge between the 'ears' on the two manifolds sometime have to be ground on one side so they sit flush.
    You did put the positioning/sealing rings in the intake?
    And check your carb base gaskets.
    Good luck....!
  8. tkmark
    tkmark
    I did put the rings in guys, but that doesn't mean there isn't some problem at the gasket. This is my 1st 235 and although the engine was pro built, I bolted the intake and exhaust on as well as the carbs. I really need to check for a leak but can't use carb cleaner as there is fresh paint everywhere. Thanks so far for the help. Any tricks on checking for an intake/vacuum leak will help. Mark
  9. saltflats
    saltflats
    from Missouri
    You can use water out of a spray bottle.
  10. Very common for the manifold alignment rings to get ****ed or tilted and the manifold will not pull down against the gasket and head. There will be an intake leak then, most usually at one end or the other before center of manifold. With the adapters for the Webers there are few more gaskets to worry with also. Try spraying starting fluid at gasket areas on intake?
    You do have the windshield wiper vacuum sealed up? Good luck
  11. 325w
    325w
    You got both carbs covered with your hands to make it run. You got to be getting air in from somewhere. Get a helper to use heater hose and place one end to their ear and listen around the intake for an air leak. WD 40 will find a leak also.
  12. tfeverfred
    tfeverfred
    Okay, here's what my guy says, "Sounds like a vacuum leak. If it's a HEI, check the vacuum canister and all your hoses. Also, keep in mind, that a dual carb setup is tricky in it's own right. You will need to play with the carbs a bit."
    Hope that helps.
  13. Cosmo49
    Cosmo49
    Me too on the vacuum leak. I have that exact set up (check that, really close) on my '56 235, fentons, dual Carter-Webers on an Edelbrock intake, etc.[​IMG]
    I had to replace that pos gasket you see on there, got that from Larrowe's (in Oregon I think) did I say pos? I meant pos gasket burned off and had several breaks (gaps) after a couple months. Got a new age intake/exhaust man. gasket and 'Bob's your uncle'. Spray bottle with soap solution, have at it, find the leak(s). This is a daily driver only vehicle and she runs like a top.
  14. Dave Downs
    Dave Downs
    from S.E. Penna
    You can use an un-lit propane torch to check for leaks, doesn't make a mess; just turn the propane on and hold the tip near the joints
  15. Engine man
    Engine man
    from Wisconsin
    I've seen clothes pins on fuel lines before but the horse shoe has me puzzled.
  16. belair
    belair
    At least the clothes pins are the traditional wooden ones.
    CurbFeeler likes this.
  17. tkmark
    tkmark
    Thanks again guys. It was what I think is a quality gasket at the cyl head. I'll try the propane trick 1st and hope i find something.what will the engine do if the propane finds a vacuum leak? Also, i think i mentioned that this has been a progressive downward turn for the engine as it started for the 1st time 4 or 5 weeks ago and ran great, 2 weeks ago it started running ****py but i was able to adjust out the idle mixture screws and it got better. Know it wont stay running unless hand are over the carbs tightly. Would spray bottle of soap and water actually work instead of propane? I loved Cosmo's horseshoe deal also and maybe its for luck??? Thanks, Mark
  18. txturbo
    txturbo
    The horseshoe is attached to the fender brace to go around the back carb.
  19. tkmark
    tkmark
    Here are a couple of pics of my set-up just FYI. Thanks again, Mark IMG_5197.JPG IMG_5198.JPG IMG_5199.JPG IMG_5200.JPG IMG_5201.JPG
    i.rant and saltflats like this.
  20. saltflats
    saltflats
    from Missouri
    Looks good hope you get it lined out man.
  21. tkmark
    tkmark
    I ran the propane check and it was very hard to tell if aiming the gas at the intake/head area and base of the carbs made any difference. I did pull the carbs last nite to check the gaskets and they both appeared to be sealing well. I'm going to replace them both with new and start the engine to see if there is any difference. Mark
  22. lowrd
    lowrd
    Had similar issues on my 235. I found I needed to break the carb linkage loose and set the idle independently and reconnect the linkage. You might try using a Unisyn to sync the carbs if you can locate one.
  23. tkmark
    tkmark
    Well... i finally got it figured out. It ended up being a combination of bad fuel (I let a very small amount sit in the tank for a long time) and rust in the main fuel line, from the tank to fuel pump. Both my bonehead for not replacing the line a long time ago and for letting the fuel sit so long. I flushed both carbs, replaced the line and she runs *****en!!! Thanks for all your help and suggestions. Mark
  24. Rusty Heaps
    Rusty Heaps
    I love a happy ending!
    pharrand likes this.
  25. PLUS, the propane, being a gas and not a liquid ....... the gas finds leaks so much easier and is CLEANER than water and or spray fluids.
