Customs 63 F100 drop ?
Discussion in 'The Hokey Ass Message Board' started by GreaseNgears, Aug 28, 2014.
  1. GreaseNgears
    GreaseNgears
    Wanting to lower my 63 f100 ,but I don't want to slam her all the way to the ground , at least just not yet. I want to have her pretty low though.
    I'm looking for a stance about like this.
    Anyone have suggestions on who and what kits to go with that will not clean my pockets out ?
    Thanks folks.
  2. HIDDEN
    HIDDEN
    That truck has prob been clipped. But you can get an F100 fairly low w/ a dropped axle and dearched springs.
    Here is my '64.
    chaddilac likes this.
  3. chaddilac
    chaddilac
    Call Sid at Droppedaxles.com and he will hook you up!!
  4. 61dailyf100
    61dailyf100
    That truck you are referring to has a clip up front with air ride. Only way to go is with a drop axle and take two leafs out. Other than that an ifs clip is the way to go. The rear is easy if you want to notch it.
  5. chaddilac
    chaddilac
    Moonpie doesn't have air ride... the baby blue one behind it does... but I think Moonpie has a MII frontend.
  6. Ryan
    Ryan
    ADMINISTRATOR
    I'm not big on getting these trucks too low. They end up looking really un-athletic to me once you get past a certain point.
    Attached is mine. I think it needs to be 1.5" lower front and back.
  7. Ryan
    Ryan
    ADMINISTRATOR
    ****. Wrong pic.
  8. 61dailyf100
    61dailyf100
    My bad, I double checked that and it's not on air ride like I thought. It had been a while since I last saw that truck. Real nice stance for a non air ride truck though. But again it does have a m2 clip.
  9. GreaseNgears
    GreaseNgears
    Alright.... cool.. I'll check into pricing out some dropped axles ... and taking some leafs out of the front... 2 leafs max ?
  10. 61dailyf100
    61dailyf100
    I took two out on mine and it's fine. I have a 302 with an aod in it right now, idk how much my 223 with the three speed weighed but when I did the swap it still sat the same. ImageUploadedByH.A.M.B.1409347950.901669.jpg this is how it looks with two taken out .Now with a three inch drop axle you can expect it to look lower. You get the idea.
  11. 61dailyf100
    61dailyf100
    Is this 64 on a Sid axle ?
  12. HIDDEN
    HIDDEN
    Yeah. On a sid's axle and dearched springs. I've done on on my '46 coupe as well. I'd use another one in a heartbeat.
  13. 61dailyf100
    61dailyf100
    Damn, it sits real nice that way. I dig it! Any pics of underneath or a thread on how to de arch the springs ? Thanks,
    -Andrew
  14. luckystiff
    luckystiff
    the yellow truck has 2nd gen camaro clip. you WILL NOT get that low with any combination of dropped axle/springs. if that height is your goal IFS it is(well i guess you could Z the frame with straight axle) my 62 sits right around the same height as MoonPie(yellow truck) and it has Jag XJ notched into the frame. but if we don't want this to be the 100th thread on lowering these trucks to be deleted we best not talk about that here. i'll say theres plenty of info on the social groups or if you want the low down on jag in these trucks shoot me a pm(conversation) i've got it to a science in these trucks....ken......
  15. luckystiff
    luckystiff
    i think you're looking at around 5-6" max out of dropped axle/spring maniplulation.
    the camaro or jag 6-8" ain't hard and 10" is possible.
  16. stevethepreacher
    stevethepreacher
    Which two did you remove?
  17. 61dailyf100
    61dailyf100
    Don't really remember but this is a shot I took today of underneath ImageUploadedByH.A.M.B.1409696590.910498.jpg
  18. guthriesmith
    guthriesmith
    Sid just did his own 64. Shoot him an email or call him and I bet he will shoot you some pics. It has a dropped axle and Posie springs if I remember right.
  19. chaddilac
    chaddilac
    Lose 1 front leaf... Sid's Drop axle... Reverse the eyes on the main leaf.... It'll get you low!!
  20. ChuckleHead_Al
    ChuckleHead_Al
    Cool I need to get back on my F100.
  21. I started by reversing the spring eyes then remove leafs as needed to get the ride you are looking for. The picture in post #17 shows that the missing forth leaf should replace the current third leaf.
  22. stevethepreacher
    stevethepreacher
    I have read here on the HAMB that it works best to remove every other leaf in the spring pack... thanks 61dailyf100 for the pic.
  23. chaddilac
    chaddilac
    You don't need to.... just remove one and it'll be close to the frame without having to have a pipe notch. You want to remove the longest spring after the main leaf.
    I just got done doing mine and it's pretty low. Might have to go lower in the rear though! :)
  24. motoandy
    motoandy
    from MB, SC
    64grand, luckystiff and chaddilac like this.
  25. luckystiff
    luckystiff
    posting pics of that truck is like a mic drop in "lowered" slic f100 world.............
    stance and 'abones poncho powering habit made me smile from the first time i saw that truck...
  26. Crookshanks
    Crookshanks
    Here's my '64. Sid's 3" drop axle, lost 2 leaves and dearched front. Lost 4 leaves in the back and dearched. I still have an inch of travel and no steering arm issues or bumpsteer. I also used Sid's drop ties. ImageUploadedByH.A.M.B.1409897887.345397.jpg
  27. Crookshanks
    Crookshanks
    Can see the stance better here. *** still needs to come down... ImageUploadedByH.A.M.B.1409898171.845338.jpg
    pie pie likes this.
  28. 61dailyf100
    61dailyf100
    I personally think that's a perfect height. Sweet truck by the way :)
  29. 61dailyf100
    61dailyf100
    How long would you say it took you to take the old axle out and put everything back together ?
  30. Rob68
    Rob68
    Crookshanks, I've seen your truck on here many times. ****!, it's f&%$*#@g nice man.
