Projects Armstrong on the rear?
Discussion in 'Traditional Hot Rods' started by 53OlderThanMe, Aug 31, 2014.
  1. 53OlderThanMe
    53OlderThanMe
    Haven't seen this done on the rear but I like the look. Got a good pair of these on the HAMB. I will be running the stock rear on the 31 Roadster. Anyone think of a reason I shouldn't do this? It will be hidden behind the 16-750 tires anyway.
  2. Should work, do you know the original use?
    If they are spaced away from the frame, they should be fully supported with a plate behind or bolt hole ears could break from twist in use.
  3. Fedcospeed
    Fedcospeed
    Heres two pics of my setup.They are rebuilt and work real good!!
  4. Ric Dean
    Ric Dean
    from Central NY
    .. Individuality is what most Rod builders are after so I say; more power to ya.
    But if you like I’ll take off your hands.
  5. skidmarks
    skidmarks
    from USA
    when I built the entire ch***is that is in this car, I used Armstrong shocks front and rear. had to make a small aluminum spacer on the rear to clear the wheel well. They work fine. Just check you full travel
    lothiandon1940 likes this.
  6. Runnin shine
    Runnin shine
    I'm going to run my Armstrongs on the front and the rear of my 32 pickup build. They're one of my favorite details. I'm sad to say I'm not the first to do this, I'm just another white sheep.
    "Listen Mr... It ain't broke if I can't fix it"
  7. 53OlderThanMe
    53OlderThanMe
    Thanks for the confirmations all. I realize I'm not reinventing the wheel here but I do like the looks of the lever shocks. I will try it with some spacers behind the mount tabs as they don't appear to be too stiff I think the shock lever will move fine before any kind of twist to the mount.
  8. saucerhead
    saucerhead
    I had them on the front and rear of my avatar, and they worked great. I also used them on the front of a '34 roadster highboy back in '84. They worked great on that car to.
  9. fab32
    fab32
    I think they are a great subs***ute for the old Ford lever hydraulics. I got a pair off Ebay and another pair off the cl***ifieds here for a tribute project I'm working on. I got lucky and one pair is stiffer (a bit larger) than the other so it should be a perfect match front to rear.
    Frank
    kidcampbell71 likes this.
  10. Runnin shine
    Runnin shine
    I'm running my stiffer(bigger body shorter arm) on the front also in effort to achieve balance. Although I have no idea which was intended to go fore or aft.
  11. The usual sources were Sprite/Midget, MG B, and big Healy's. They can be adjusted by fluid viscosity and the valve springing.
  12. Ned Ludd
    Ned Ludd
    I've got a pair on the back of the Morris Minor, which was the stock set-up. For some reason known only to Alec Issigonis and his team they are attached to the axle with links to the rear floor structure. I suspect that they are worn or empty or both, because the car rides exactly the same with the dampers connected as disconnected.
  13. I've run them on the back of all my A's. MGB ones are the same bolt centre. I just weld a replacement model A ball in the wrong way round.
  14. My A has them in the rear.
    Been there 10 years and probably more than 40,000 miles.
    Ride hasent changed a bit.
    Never even looked inside since they wer filled.
    Not a spot of oil ever on the outside.
    I would use them again, and wouldn't hesitate to put a set on the front.
