Desoto Grill Tooth Question
Discussion in 'The Hokey Ass Message Board' started by 19Fordy, May 9, 2009.
  1. 19Fordy
    19Fordy
    Does anyone know if the 1951 or 52 Desoto grille teeth are the exact same size as the
    center grille tooth of a 1953 Desoto? I have a 1953 center tooth but I don't have the '51 or '52 teeth to compare. Thanks, jim
  2. grizlyrr
    grizlyrr
    from Pueblo, Co
    The 52 center tooth is the same as the 53. The center 5 teeth are all the same for 52 and 53
  3. FredK
    FredK
    Jim,
    I own one of each and I can check for you the next time I go to the shop. I should be out there next Wednesday.
    Let me know by a PM.
    Fred
  4. FredK
    FredK
    Oh great! In the time it took me to two finger type my message Grizlyrr answered the question. You wipper snappers!!! Get off my lawn! :D:D
  5. Steelsmith
    Steelsmith
    Hi Jim, I'm in the final stages of tooling the last two teeth for the Desoto grille. I can manufacture whichever teeth you need. Your post stated you want 6 more center teeth. I can supply them polished or unpolished. The teeth I am manufacturing are made out of 3003 aluminum flatsheet. They are hammerformed and then pressed. The mounting lugs are welded in, and there is a center seam which is also welded.
    Since these teeth are made from flatsheet not cast, there are no flaws in the casting, and are polishable as an option to chroming. I am currently not offering a mounting pan, but I am considering that option as a kustom gravel pan to match your bumper profile.
    My first set of 11 teeth should be done end of next week, when I will take pictures.
    PM me if you have further interest
    Dan Stevens
    dba, Steelsmith
  6. hdchino
    hdchino
    I am very interested in seeing what you have made for this replacement!!
    I am looking for the complete set of 11 teeth.
    Thank you Lew
    hdchino@aol.com
  7. Frankie47
    Frankie47
    from omaha ne.
    Awake...awake I say, from your 5 year slumber.....lol
  8. hdchino
    hdchino
    Hahaha I'm awake now I just seen his post date lol
    I am knida new to this.
    Do you know of anyone remaking the Desoto Teeth?
