Has anyone had a custom aluminum radiator made for a 1933 Plymouth PD Coupe with a Small Block Chevy? I'd like to get a referral to a radiator shop and see photos of the finished product. Also, how should the radiator be mounted? Does it fasten to the lower support or just to the sides of the grill shell? I modified a copper junk yard donor for my car 30 years ago and it's now leaking. I'd like to take the opportunity to improve upon what I did back then.
custom auto radiator does a 33 Dodge one send them an email dcustom1@netscape.net I prefer the br***/copper ones
http://www.customautoradiator.com/ http://www.walkerradiatorworks.com/...ght&MotorModified=Stock&AirCond=NO&Search=YES
Brice Thomas in Gadsden Al built the one for a friend of mine for his 33 ply good looking work https://www.facebook.com/pages/Brice-Thomas-Radiator/115705268448700
In my 33 ply. 5 window I used a 32 ford . Grill and radiator. In fact my car is also a grey and looks a lot like yours. I liked the ford grill better because it's not sweeping down between the frame rails.I also run a ford 460ci and c6 with a crown vic complete rear. Bob
I FORGOT TO MENTION THAT IMINE IS MOUNTED ON THE BOTTOM TO A FRAME CROSS MEMBER THAT ALSO IS THE SPEEDWAY FRONT AXLE SPRING MOUNTS. HOPE THIS HELPS.
The grill she'll is mounted to cross member but the AFTERMARKET alum radiator mounts to the shell sides. WORKS GREAT . HOPE THIS HELPS. BOB
