Technical Loud power steering ?
Discussion in 'The Hokey Ass Message Board' started by angelotti86, Sep 6, 2014.
  1. angelotti86
    angelotti86
    My power steering is the original unit in a 80 front clip and its loud when its starts to get to maximum turned direction both ways .What would cause this a worn out pump or worn out steering box ?I was going to change the pump since thats easier and hope that will solve the problem .Thanks
  2. caton462
    caton462
    Try flushing the fluid before replacing any hard parts. We fix a lot of late model power steering pump noise by flushing the fluid especially on Ford vehicles (debris and cavitation). Some systems will not fully bleed out without using a vacuum attached to the fill neck.
  3. angelotti86
    angelotti86
    I did drain it fully and add new fluid.Is there a better more intricate way to do it ?
  4. slddnmatt
    slddnmatt
    Jack the car up and cycle it side to side. If its still noisy I'd replace the pump
  5. angelotti86
    angelotti86
    I did that also and yeas when jacked up its still get loud when gets to the max turn .
  6. mgtstumpy
    mgtstumpy
    I bought my rebuild kit from PS Kits
  7. Even a microscopic leak at the inlet side of the pump can **** air and you can never bleed it out until you fix the leak.
  8. angelotti86
    angelotti86
    So bottom line is its going to be the pump if anything not the box?
  9. Mr48chev
    You re using "power steering fluid' and not transmission fluid? I lost track of how many cars I flushed ****** fluid out of and replaced it with Genuine GM power steering fluid. This is one place that it is well worth the time, money and effort to go to the dealer's parts counter and buy the real deal GM power steering fluid.
    The pumps have a ring, rotor and vanes in them and if the ring gets scored or the plates on each side of the rotor and vanes get scored they will leak some through the scores and be a bit noisy.
    If they chatter when you turn there is a chance that the vanes are sticking or the rotor is broken.
    About the only noise a box makes is crunch if the recirculating balls got smashed by heavy handed turning without power working. I saw it in a manual box with power ***ist in a forklift when my neighbors workers were too lazy to add fluid to the power steering and I had to rebuild the box.
  10. angelotti86
    angelotti86
    I did use power steering fluid but just generic brand .Its just grinds as its gets close to max turn.Its close to sound of squealing belt but for sure its not belt .
  11. High pitch squealing could be the pressure relief valve in the pump. When you had it jacked up bleeding air out of the system, did you happen to try turning the steering wheel with the engine off? It might be that you have other steering problems and it is taking more force to turn the wheels than your pump is set up to supply
  12. angelotti86
    angelotti86
    I did try turning it with engine off too and it seemed to turn ok .
