33 Chevy on ASC rails
Discussion in 'The Hokey Ass Message Board' started by bigheadbaxter, Sep 8, 2014.
  1. bigheadbaxter
    bigheadbaxter
    Well it was time to start looking for the next project. I kept seeing all of these chopped sedans that I really liked, they just looked so gangster to me. Like Kirk Hannings 34 - I just think it's the coolest and was truly inspired by this car. I tried to be patient hoping a Ford would come my way. Every thing I found was out of my price range. Then one Saturday morning I checked CL again, and found this rusty shell basicly in my backyard. It was a 33 Chevy Eagle. The guy had doors to go with it that fit, but something was different about them, the top corner to the B pillar was rounded. Come to find out they were for a Chevy coupe of some sort. So I went home and thought more about it. Only to return and make a deal
    ImageUploadedByH.A.M.B.1410190342.344394.jpg ImageUploadedByH.A.M.B.1410190376.660100.jpg ImageUploadedByH.A.M.B.1410190449.892972.jpg
    volvobrynk likes this.
  2. That tin looks pretty nice. How low is the lid going to go?
    4ever18 likes this.
  3. bigheadbaxter
    bigheadbaxter
    Once I got it home I started doing a little more research and started thinking 'oh man what have I gotten my self into' and realized I'm missing a lot of parts. With no ch***is I started weighing my options. First looking for an original frame which was quite difficult and **** ugly. Then I saw a post by Nailhead Terry and his Chevy on deuce rails. I liked and PM'ed him and was told its fits surprisingly well. So that was the plan ImageUploadedByH.A.M.B.1410191310.076440.jpg
  4. bigheadbaxter
    bigheadbaxter
    I found an ad here on the cl***ifieds that B*** had a couple of ASC rails for sale. So with the company van I made my way down to B*** Kustoms (very impressive shop with tons of eye candy) and made the purchase. They barely fit from back door to dash pad kissing gl*** ImageUploadedByH.A.M.B.1410192012.810195.jpg
  5. alchemy
    alchemy
    That should make a nice combo. Make sure to give them a nice taper inward so they line up nicely under the edge of the grille.
  6. bigheadbaxter
    bigheadbaxter
    Yes Sir that's one big *** hole that someone trimmed the the lip out of so there wasn't any thing to attach any form of original material too. So I started reading about fillers on here and found a post recommending the roof section from an Chevy AD suburban. So I found one, and it has the perfect crest. It's from a 48 ImageUploadedByH.A.M.B.1410192813.443225.jpg ImageUploadedByH.A.M.B.1410192837.109984.jpg ImageUploadedByH.A.M.B.1410192857.059852.jpg
  7. bigheadbaxter
    bigheadbaxter
    Slowly realizing that I was missing parts that I didn't even know I needed , and didn't want to make the doors that I have work, I started looking for another parts car and found one. In South Dakota, made a verbal deal and met the guy in Iowa to make the exchange ImageUploadedByH.A.M.B.1410194850.051409.jpg ImageUploadedByH.A.M.B.1410194872.067777.jpg ImageUploadedByH.A.M.B.1410194898.218107.jpg ImageUploadedByH.A.M.B.1410194931.669078.jpg
    volvobrynk and kidcampbell71 like this.
  8. bigheadbaxter
    bigheadbaxter
    It's hard to tell from the pictures, but the 2nd car kinda had a frame. I was told that the bulk of the frame was a mid 30's chevy truck frame. It was set up with a narrowed ford 9in. With disc brakes all the way around. It had some name brand coil overs. It had a mustang 2 front end and the cross member you can see in the pic. It was set up for a big block. With the bird **** welds and large power plant the ch***is would have literally exploded on the first acceleration. I got it home and dis***embled accordingly. Sorted and sold a lot of stuff making a lot of my money back
  9. bigheadbaxter
    bigheadbaxter
    Before I started strengthening the body I knew I needed to start on the frame. So I studied some of the frame builds on here. Determining that I had to build a frame table, I purchased the plans from Desert Hybrids. This table works well for me, I had it built and the frame square in no time. ImageUploadedByH.A.M.B.1410198147.192161.jpg ImageUploadedByH.A.M.B.1410198178.192153.jpg
    kidcampbell71 likes this.
  10. 34Fordtk
    34Fordtk
    Man I really like the 33-34 Chevy Sedans, cant wait to see more as you go.
    need louvers ? likes this.
  11. I'm thinking this will be a great thread.
  12. bigheadbaxter
    bigheadbaxter
    As I was building the ch***is I'm looking for a front end. And found an almost complete 37 ford axle ***embly that I traded for the rear fenders from car number 2. I used the front spring on the rear. Fabbed up some hardware and mounted. Also used the cross member from the ******* frame from car no2. Made some ladder bars and installed also ImageUploadedByH.A.M.B.1410200393.394775.jpg ImageUploadedByH.A.M.B.1410200427.079111.jpg
  13. bigheadbaxter
    bigheadbaxter
    I failed to mention that I kicked up the rear frame horn section level with the the body. And fully boxed the frame. I purchased the Posies flipped eye front leaf spring and added to the dropped front cross member. I had the I beam stretched and dropped by Nostalgia Sid. Purchased Lincoln backing plates from Wilson Welding with brakes. Split the bones and installed. ImageUploadedByH.A.M.B.1410211560.169020.jpg ImageUploadedByH.A.M.B.1410211597.718600.jpg ImageUploadedByH.A.M.B.1410211657.519316.jpg ImageUploadedByH.A.M.B.1410211745.569022.jpg
    Stogy, volvobrynk and kidcampbell71 like this.
  14. bigheadbaxter
    bigheadbaxter
    With the ch***is stable enough I was able to start fitting the body. But you can't talk about early Chevys without talking about wood! There was some wood still tucked away in various places ImageUploadedByH.A.M.B.1410220727.674022.jpg ImageUploadedByH.A.M.B.1410220753.773471.jpg I removed what was left and used it to heat the shop back in the winter
    Stogy and volvobrynk like this.
  15. bigheadbaxter
    bigheadbaxter
    Ok with all of the wood removed I had it sandblasted by a local guy name Jay Goode. There's 2 things that don't belong on a car in my opinion and that's wood and rust. Very pleased with the bare metal I shot a healthy coat of DP40 ImageUploadedByH.A.M.B.1410222243.233896.jpg
    Stogy, volvobrynk and 54reno like this.
  16. That's going to be a real sweetheart! How long has it been in progress?
  17. bigheadbaxter
    bigheadbaxter
    Thanks Fan Attic, I've been at it for a year and a half. I'm down with a herniated disc and waiting on surgery. So I'm sorting through pics trying to put them in chronological order the best I can. Bare with me this is my first post
  18. bigheadbaxter
    bigheadbaxter
    With most of the rust gone I was able to concentrate on the daunting task of replacing the wooden structure with 1in. Square tubing. So I bought a bender and the dies that were for 1/2 square tubing and had them opened up to 1in. ImageUploadedByH.A.M.B.1410267537.286425.jpg it worked really well. It's almost like a mini roll cage through out the whole interior of the car. Radius bends over wheel wells,windows and under dash then tied it all together and it also gave me something to weld interior sheet metal to. Also used the roof bracing from the donor roof. Cut it to fit and put it in place. The inner structure is many times stronger than the wood ever was. I did this before chopping so there was plenty of support and no 'springing' action ImageUploadedByH.A.M.B.1410268378.386884.jpg ImageUploadedByH.A.M.B.1410268443.902797.jpg
    Stogy, volvobrynk and Flipper like this.
  19. bigheadbaxter
    bigheadbaxter
    With the body mostly braced I need to get the shaky *** doors supported, but that meant I had to get the doors swinging and latching. I purchased the mini bear claw latches and welded them in. Then positioned the door as needed and again bent and braced with 1in. Square tubing.
  20. bigheadbaxter
    bigheadbaxter
    ImageUploadedByH.A.M.B.1410272529.728464.jpg ImageUploadedByH.A.M.B.1410272548.194261.jpg ImageUploadedByH.A.M.B.1410272561.794257.jpg ImageUploadedByH.A.M.B.1410272595.044429.jpg ImageUploadedByH.A.M.B.1410272647.561329.jpg i was finally starting to get a real feel for the car with doors on and hood mocked up
  21. bigheadbaxter
    bigheadbaxter
    I still had had rusty pieces that had to be blasted, so instead of going back to the blaster I built a cabinet. If there's any data techs or commercial a/c guys out there you may recognize this? It was a chilled water Liebert unit that I gutted and shortened and made a blast cabinet out of. Dumped in some gl*** beads and off I went. The doors and hood fit fine with room to turn. ImageUploadedByH.A.M.B.1410274207.867928.jpg ImageUploadedByH.A.M.B.1410274224.874737.jpg
  22. tobyflh
    tobyflh
    from Peru il
    You are doing one hell of a job. Keep up the good work.
  23. TFoch
    TFoch
  24. bigheadbaxter
    bigheadbaxter
    The 1st car came with a 1933 chevy truck grill, little did I know at the time. And didn't know this until I got the parts car no.2. The car grill is much smaller and fortunately the car grill was in much better shape but still needed repair. While fitting the body and hood to the ch***is I realized the grill was now way to tall , so I had to take out almost 2 in. To get to fit right. But first I had to have the old chrome stripped off at the chromers. ImageUploadedByH.A.M.B.1410285803.668769.jpg ImageUploadedByH.A.M.B.1410285833.518749.jpg ImageUploadedByH.A.M.B.1410285885.085753.jpg ImageUploadedByH.A.M.B.1410285961.485378.jpg so after it was stripped I chopped it and trimmed the insert, and with the truck insert I cut out a piece to weld in to fill the crank hole (funny word) then found radiator cap cover that I think is from a 34? The Eagle is cool but a little to busy for me
    volvobrynk and Dakota.za like this.
  25. need louvers ?
    need louvers ?
    Wow! This is *****in'!!!
  26. bigheadbaxter
    bigheadbaxter
    Thanks for the encouraging comments guys, it's killing me not to be able to work on it right now. But this set back is at least giving me a chance to share
  27. Ouch! Discectomies can set ya back for sure. I've had a couple Lumbar 4/5's in years past. Listen to the the****** and do those daily exercises they tell you that you need to do after you are healed up and life is much better, for a while anyway! That sedan is going to be a hoot when you get it on the road.
  28. tb33anda3rd
    tb33anda3rd
    nice project, that is a 33 mascot.
  29. bigheadbaxter
    bigheadbaxter
    Tell me more. ImageUploadedByH.A.M.B.1410301372.064554.jpg my car is identical to this one and I was told it's an Eagle. Anymore info is much appreciated. Neither of the 2 cars I bought had any I.D
  30. I got a whole nother level of respect for guys who build Chevy Hot Rods.
    I love how this build is shaping up!
