Technical Misc 49-51 Mercury questions & answers
Discussion in 'The Hokey Ass Message Board' started by Jenkkiauto, Jul 25, 2014.
  1. Jenkkiauto
    Jenkkiauto
    from Finland
    Hey guys, I would like to know if a 50 Merc push ****on type door handle can be used on a 49 Merc?
    The reason for me asking this is the not so strong door handle found on 49 models.
    I would like to use a better solution (which I think the 50 door handle might be) that looks factory style though.
    Any thoughts?
  2. bottom feeder
    bottom feeder
    the door mechanism changed late in 1949. My recollection is the mechanism for the early 1949 is different than 1950. As a result I would be surprised if the two work together. You will need to take your door panels off and see which style you have.
    Jenkkiauto likes this.
  3. Slopok
    Slopok
    The 49 has a latch type mechanism and the 50 has like a star wheel type. In either case you would need the striker to match.
  4. Jenkkiauto
    Jenkkiauto
    from Finland
    Thanks @bottom feeder & @Slopok for the replies, maybe its better to stick with the stock 49 handles for now.
  5. Jenkkiauto
    Jenkkiauto
    from Finland
    Another 49 question guys if you dont mind...
    Whats the windshield wiper system like originally and how is the original wiper ****on supposed to work?
  6. Slopok
    Slopok
    It's vacuum operated. Just pull out the knob.
  7. slddnmatt
    slddnmatt
    If you don't like the 49 handles, 49 ford handles operate the same way but look a little more streamlined.. Anything other than the stock ones will take work to mount
  8. Jenkkiauto
    Jenkkiauto
    from Finland
    Thanks for the help guys!
    Solved my wiper problem by ordering a new electric wiper motor from www.newportwipers.com
    I decided to use the stock 49 door handles but will try to make em a bit stronger.
    How about a new question guys:
    does anyone make a one piece side gl*** kit for unchopped 1949 Mercurys?
  9. Yes you can change to the 50 style latch and handle. It just takes some surgery starting with doing a quality job of filling all 49 the holes. Then copy the pattern off a 50 door for both handle and latch. The door itself is the same stamping for 49 and 50. The difficult part is countersinking the screw holes for the latch. Back in the early 70's I mounted a 55 Chevy wiper motor to the stock wiper unit and hooked it right to the Stock wiper control cable. It still works today. Back then we didn't have all the aftermarket stuff.
    The Wizzard
    DanCollins and Jenkkiauto like this.
  10. Jenkkiauto
    Jenkkiauto
    from Finland
    Rainy days here now so might as well hit the garage amd tear down the Merc dash and remove the original wiper motor and start installing the new newportwipers electric wiper motor.
  11. slddnmatt
    slddnmatt
    The doors bend at the vent window division bar area. It can be done but looks bad in my opinion if you do not do work to the doors and make that area straight...as far as a gl*** kit not sure if there's one out there.
  12. Jenkkiauto
    Jenkkiauto
    from Finland
    Wow thanks for that important bend-info @slddnmatt , I did NOT know about the bend at all.
    I have seen one piece gl*** kits for many cl***ic cars but not for the 49-51 Mercs, unfortunately.
    Thanks again.
  13. Slopok
    Slopok
    Your dash and interior look very nice. I think you would miss the vent windows if you were to eliminate them anyway. I know I would.
  14. Jenkkiauto
    Jenkkiauto
    from Finland
    Does anyone happen to have a spare set of 1949 Mercury windshield wiper pads or any tips on where to buy pads?
    Mercuryland had em in their catalog for sale but they are no longer in business :(
    Example below.
  15. Slopok
    Slopok
    Try Birdhaven Vintage Auto Supply..Phone number 515-674-3949.
    Part # 8M-17541-AS Without windshield washers 8.95
    Part # 8M-17541-BS With windshield washers 8.95
    These are from a 2011 catalog, Hope this helps. Toll Free 866-302-3673
  16. Jenkkiauto
    Jenkkiauto
    from Finland
    Big thanks @Slopok , I am located in Finland so I prefer typing emails instead of calling & trying to make myself understood in spoken english.
    Trying to find a working email address for Birdhaven Vintage Auto Supply now.
  17. Slopok
    Slopok
    I can't find email either. Here is a fax # 515-674-9028 if that helps. Birdhaven.
    Mac's Antique Auto Parts has them part # 8M-17541-BPR 10.95 pair page190
    2014 Catalog
  18. Jenkkiauto
    Jenkkiauto
    from Finland
    Thanks again for the help @Slopok !
    For now, I made 2 pads from an old bicycle innertube and it seems to be a good, working material.
    Sharp cutter and all it took was about 10 mins.
    By the way, the material that had been used on em before by the previous owner was ordinary black tape (picture 2), no wonder my feet got wet :)
    Out with the old in with the new.jpg black tape does not work.jpg innertube and cutter.jpg done.jpg
  19. Slopok
    Slopok
    I was going to suggest something of that nature but thought as l0ng as they are available that would be somewhat tacky. I have used pick up camper top foam in the past. Sticky on one side and thicker than inner tubes.
  20. Jenkkiauto
    Jenkkiauto
    from Finland
    Yeah these can be changed one at a time if need be.
    Looks like these turned out to be good, final waterproofing tests still to be done. :cool:
  21. Slopok
    Slopok
    There wasn't much available for Mercs 32 years ago when I did my car.
  22. Jenkkiauto
    Jenkkiauto
    from Finland
    DIY usually leaves you with a better feeling than just using of the shelf parts.
    Btw, back when you have done your Merc, I have been just 13 years old, riding my moped.
    And just gotten interested in US cars.
    We had a bodyshop so I got to train & learn with my dad as much as I ever wanted.
  23. Jenkkiauto
    Jenkkiauto
    from Finland
    Here´s the 49:
    DanCollins likes this.
  24. Slopok
    Slopok
    Wow that is one beautiful Merc. Its cool that you were able to work with and learn from your dad. Did you do the bodywork and paint? If so your dad taught you well.
  25. Jenkkiauto
    Jenkkiauto
    from Finland
    Sorry, cant take credit for making this car beautiful, I bought this from US in 2014 and it was well done, better than expected. Now i´ll do my best to make it even better.
    Bodywork is the thing I am naturally the most familiar with, we did not have a paintbooth so all the major paintwork was... outsourced.
  26. Slopok
    Slopok
    It is very rare to see a Merc customized yet retain all the emblems and trim and even the original hub caps. Someone had some restraint. Very nicely done. You should be proud to own it no matter who built it. Still plenty for you to do to personalize to your own taste. Some mild pinstriping and skirts maybe?
  27. cwc.coonce
    cwc.coonce
    Try Sacramento vintage ford, i believe its vintageford.com
  28. rotorwrench
    rotorwrench
    I've been seeing a lot of stuff for 49/51 Mercs on Flea-Pay. Original wiper tower gaskets were leather but I think both rubber and leather are reproduced now.
  29. slddnmatt
    slddnmatt
    I get my stuff from C &G ford in Escondido.
  30. 19Fordy
    19Fordy
    A one piece windshield will ruin the cl***ic look of your beautiful Merc.
    DO NOT DO IT.
