1950 Merc - Chopped, Channeled, Shaved
Discussion in 'Cars For Sale' started by SCR8PINHRD, Sep 8, 2014.
  1. SCR8PINHRD
    SCR8PINHRD
    from delta pa
    City: Delta
    State: Pennsylvania
    Price: $38,000
    This is a full fibergl*** car that includes a 6" chop, front fenders and grill section molded as one, channeled, shaved, decked, louvered hood andfrenched headlights & ***led as a 1950 Mercury. The body includes hand-crafted fibergl*** laminate featuring: hand laid layers of fibergl***, durable gelcoat surface and an inner core, providing high strength and superior surface quality. All high stress areas are reinforced with heavy woven roving [woven strands fibergl*** at 90 degrees, used in most boat manufacturing] providing the strongest most durable body in the industry. It sits on an Art Morrison designed ch***is with the following specs (Pictured below) -
    -Frame rails are mig and tig welded for superior strength and durability
    -118" wheel base
    -Main rails and K member are fabricated from 5" x 2" 3/16" wall tubing
    -K member is designed for ease of routing exhaust with 3" exhaust holes installed.
    -Front cross member is setup for stock or tubular Mustang II front suspension and is formed from 3/16" cold finished mild steel with all mounting point for upper and lower control arms and rack and pinion steering precisely located with custom fixtures.
    -Rear cross member is constructed from 2" x 2" square tubing. Outriggers are drilled to match existing holes in floor and inside steel.
    Body –
    -Block sanded epoxy sealed, primed and painted Synergy Green w/ pearl white scallops
    -1950 Lincoln tail lights
    -1953 Chevy grille (center section)
    -Frenched headlights
    -Shaved door handles
    -Louvered hood
    -Channeled 4”
    -Tubbed
    Frame/Suspension –
    -Mustang II tubular upper & lower control arms
    -Four wheel disc brakes (drilled & slotted up front)
    -Air ride
    -Parallel four link
    -10 bolt Posi rear (3:42) Auburn Posi Unit
    Interior –
    -Custom dash & center console
    -Four **** bucket seats
    -ABS 1/8” door panels, kick panels, rear panels installed
    -Black carpet
    -28” tall shifter
    -Kicker speakers w/ Sony head unit
    -55/56 Chevy 15” steering wheel
    -Floor was lizard skinned & dynamat’d
    -Power windows
    -Tinted gl***
    Motor/Trans –
    -Crate 383 stroker (421 HP)
    -Rebuilt turbo 400 trans
    -Aluminum radiator
    -MSD distributor
    -Holley 750 carb
    -Elebrock intake
    -10 mm Taylor 409 Race wires
    -Finned valve covers & air cleaner
    -2.5” Exhaust w/ Flow master mufflers
    -All braided stainless steel lines
  2. SCR8PINHRD
    SCR8PINHRD
    from delta pa
