Technical The Painting at home in the driveway or garage thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Sep 15, 2014.
  1. Blue One
    Blue One
    from Alberta
    We should get this going and keep it going :)
    Let's see all the examples of what you have painted, what you are planning to paint, equipment you used and where you did it.
    It would be great to have a thread devoted to just that. :cool:
    Larry.
  2. HOTRODPRIMER
    HOTRODPRIMER
    My Deuce pickup was built & painted in my shop at home,we also built and painted my pal Dave's 40 Coupe in my shop at home. HRP
    First time it rolled out of the shop and read to start for the first time.
    Daves 40 coupe. HRP
    AB Normal, alanp561, Steves46 and 9 others like this.
  3. banjorear
    banjorear
    I painted the third VW Bug I owed in my driveway. I used DuPont Centari (sp?) Mars Red with my dad's tiny DeViblis compressor. I remember using tweezers to pick out the bugs as it dried.
    I was about 17 when I did this.
    alanp561 likes this.
  4. Atwater Mike
    Atwater Mike
    I painted my '32 five window in my graveled back yard outside the garage, 32 coats of red Nitrocellulose lacquer. My Mom thought I was crazy...
    "How many times are you gonna paint that damned thing?" That was 1958, at my Grandma's house.
    If you walk back the drive to the front of the garage, there is STILL red gravel...
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Painted the engine bay and interior of my unibody in the garage.
    All my painting aside from the flake is done with a 4 oz touch up gun as I haven't made up my mind on what to buy as a better gun.
    Also shot this b*** and pedal car. Shadows make the pedal car look zebra striped.
    little red 50 likes this.
  6. K13
    K13
    Good thread Larry. I have done all the primer work on this in my garage and plan on painting it there as well. I will be using lacquer so I will be facing a few less concerns that if I was spraying BC/CC.
    UNCLECHET, alanp561, TagMan and 5 others like this.
  7. Jim636
    Jim636
    from Wyandotte
    The 49 was painted in the garage the 40 is just primer from the garage,build both in a 11/2 car garage.....
  8. lothiandon1940
    lothiandon1940
    Great thread idea.
  9. wreckfixer
    wreckfixer
    I have been working on my 57 in my garage for a couple years now. ImageUploadedByH.A.M.B.1410807108.653649.jpg ImageUploadedByH.A.M.B.1410807130.803466.jpg ImageUploadedByH.A.M.B.1410807152.303480.jpg ImageUploadedByH.A.M.B.1410807175.770311.jpg ImageUploadedByH.A.M.B.1410807194.320760.jpg
    UNCLECHET, alanp561, brEad and 7 others like this.
  10. falcongeorge
    falcongeorge
    from BC
    I'd like to hear about how guys are dealing with the potential health risks ***ociated with shooting modern BC/CC at home. Or are you just crossing your fingers and hoping for the best???
    Gasser 57 and MO54Frank like this.
  11. txturbo
    txturbo
    image.jpg image.jpg Not as much of a concern outside but still wear a respirator. Painted this Impala in this driveway with my TP Tools turbine system. BC/CC
    2Blue2 likes this.
  12. LOST ANGEL
    LOST ANGEL
    Acrylic enamel, old **** from egay. Basic 2-car garage.-MIKE:D
    swade41, -Brent-, 2Blue2 and 22 others like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    34 repaint 8.jpg P1310004.JPG P3030001.JPG P3030007.JPG P1010011.JPG ] Two of them and that's about it for this cookie.
    Both are enamel.
    UNCLECHET, dan31, Gizzy and 10 others like this.
  14. RICH B
    RICH B
    Fumes really bugged me the last couple times we painted stuff at my kid's house. Found this gizmo at last years Twin Cities Roadster swap for $25. Works real good, fresh air all the time.
    mario711 and alanp561 like this.
  15. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I wear a respirator every time. Have a couple of fans I run with furnace filters on them.
    I know it doesn't do it all... but it's all I can do at home.
  16. Hookedtrout
    Hookedtrout
    from East Idaho
    Currently doing the body work on my 62 F100 Unibody, plan to paint it when ready in my shop.
  17. falcongeorge
    falcongeorge
    from BC
    I guess I should elaborate a bit, I need to paint a vehicle that is not a hot rod, way O/T, and is going to be beaten like a red-headed stepchild. The paint on this POS needs to be REALLY tough and durable, which is why I am asking about health issues ***ociated with home spraying BC/CC.
    For a garage kept hot rod, I would just shoot acrylic lacquer and not even give it a second thought, done it several times in the past. I was hoping to avoid even mentioning lacquer because of all the ensuing ******** that results.
    Lost angel, love your truck, noticed it on here several times. RichB the hood/respirator deal looks like a possible, I also plan to switch over to turbine, I think the reduced overspray should help. Hope to continue to hear more on the health side of the modern paint issue. from what I understand, there are major health issues ***ociated with even handling the modern isocynate based paints, let alone breathing the fumes...
  18. Outside driveway job with a tarp overhead. Where I live I shoot in the morning before the wind kicks up. Wet down the surrounding area first. I use single stage to keep it simple. Lay enough paint on to cut and buff. Won't win Best Paint but everyone that sees it exclaims "You did that?" DSC00387.JPG
  19. oldolds
    oldolds
    I have heard that guys use a small shop vac to supply fresh air. Mount it outside, run a hose inside to a gas mask. Polish surplus gas masks are like $20 at milatary surplus places.
    Here is an auction listing. http://www.ebay.com/itm/US-M-Gas-Ma...927?pt=LH_DefaultDomain_0&hash=item3a9747db17
  20. Uncle Bob
    Uncle Bob
    from Salado, Tx
    I paint parts in what I call my solar powered spray booth. Very good ventilation and a great bake cycle on the "right" days. solar powered spray booth.jpg spray booth bake mode.jpg 41 wheels in booth.jpg
  21. squirrel
    painted these at home in my shop. acrylic enamel. I even painted the trailer, but with rustoleum. towing.jpg
  22. cshades
    cshades
    from wi
    I painted the truck in my avatar with bc/cc in the shed behind me in the pic. It was the first time i had painted bc/cc and that was done in 1998. it is still looking good with a few chips and scratches.
  23. Chucky
    Chucky
    image.jpg I've painted three cars inside my 21 x 21 garage. I wear a 3M charcoal filter mask. I don't ever want to paint in such a small, ill equipped space again. The driveway works much better.:cool:
    RockinRivi, rab71 and svrdhooligan like this.
  24. k1w1rodder
    k1w1rodder
  25. falcongeorge
    falcongeorge
    from BC
    What did you do as far as safety precautions? Mask and air supply? Just a mask?
  26. woodiewagon46
    woodiewagon46
    from New York
    I painted a Model A front fender in my driveway once and about two weeks later I got a visit from the EPA police. These guys do NOT have a sense of humor. He gave me a written warning and told me if he comes back it is a mandatory $2500 fine. I get along great with all my neighbors, they all come over and borrow tools and I weld things for them, so I don't know who blew the whistle on me but I am done with painting in my driveway!
  27. camerl2009
    camerl2009
    that's rough I hear the guys out in cali have to go though all kinds of BS where I am no one give two s***'s most of us never used a respirator painting or doing body work. I don't really like the idea of painting outside my bad enough my current O/T daily driver was painted in a barn and is nothing but orange peel by its prior owner(also has a lot of bondo that should not be there) my outdoor rattle can job on the lower door,quaters,rocker came out better
  28. 56 Dodge Pickup
    56 Dodge Pickup
    Has anyone used the dupliu color paint shop lacquer I am doing a gas pump for a charity auction and was thinking about painting it in my garage with that paint.
    Chris Paull likes this.
  29. K13
    K13
    I have used a little just to play around with. It is pre thinned and sprays pretty nice but I have no idea about it's longevity.
    bantam likes this.
  30. chainsaw
    chainsaw
    In the process of painting my econoline in the garage. Using tp tools turbine. ImageUploadedByTJJ1410825637.680573.jpg ImageUploadedByTJJ1410825698.393311.jpg
