Customs Gonna chop my '58 Chevy big window truck. Any pointers on the glass and stainless part of the chop?
Discussion in 'The Hokey Ass Message Board' started by ElBrujo, Sep 14, 2014.
  1. ElBrujo
    ElBrujo
    So I decided on a moderate 2" chop and I recently saw an online article from custom cl***ic trucks on how to do that 2" chop. I think I have that part covered, my question is my truck came without gl*** and stainless. Would it be best to buy new stainless and cut it or get some original pieces and cut/weld those? How would you go about cutting the stainless and welding it back together? Should I get the gl*** cut first before chopping the top? Any input greatly appreciated.
  2. Hnstray
    Hnstray
    from Quincy, IL
    I don't believe you can cut the back gl***. It would have to be laminated safety gl***, like the windshield, to be cut down for your chop. Typically, curved rear gl*** is 'tempered' gl***, and will shatter into small bits, like gravel.
    As for the stainless moldings, if they must be welded, they should be TIG welded by a very competent welder.
  3. mgtstumpy
    mgtstumpy
  4. ElBrujo
    ElBrujo
    I talked to Chris Blattie here on the HAMB and he told me the gl*** shop can make the back gl*** to the size you want. They can also make it either laminated or tempered. So the gl*** cutting wouldn't be an issue.
  5. ElBrujo
    ElBrujo
  6. Hnstray
    Hnstray
    from Quincy, IL
    Your thread is ***led "Big back window '58 Chevy........." The big back window has a gentle curve it's entire width and tightly curved corners. I do not know the content of your conversation with Chris, but I suspect he was thinking flat gl*** when he said gl*** shops can make the window any size you want. Curved gl*** CAN be custom made, but not by a typical gl*** shop. It has to be ordered from specialty gl*** companies and it is not cheap. And, the pattern for a special order curved gl*** is a totally different animal than for flat gl*** and has to be exact, if the gl*** is to fit. I think you may have a bit more 'homework' to do before you start cutting.
    Ray
    Special Ed likes this.
  7. Stu D Baker
    Stu D Baker
    from Illinois
    ^^^^^^^^What he said. Stu
  8. dadseh
    dadseh
    Why not fill in the curved sides and use flat gl*** ?
  9. ElBrujo
    ElBrujo
    Chris referred me to the company that makes the gl*** for him and they said they can make the front and rear gl*** with whatever chop I wanted. They can also make it in tempered or laminated.
  10. ElBrujo
    ElBrujo
    I love the wrap around gl***.
  11. Well, there you go.
    Get the gl*** cut or made to the size you want and chop the top to match. Metal is much more forgiving than gl***
    turboroadster likes this.
  12. Hnstray
    Hnstray
    from Quincy, IL
    Well, in that case......"maintain heading.......full speed ahead"...........
    Best wishes with your project.
    Ray
  13. oldolds
    oldolds
    Get the gl*** first. Cut the roof to fit the gl***. You will have problems if you cut the roof and expect the gl*** to fit.
  14. And for gosh sake, how about pictures? No fair teasing.
    Ben
  15. Leevon
    Leevon
    from Nixa, MO
    My neighbor did it. It took 4 rear windows to get it right, broke 2 originals and one reproduction. He said he would never recommend doing it and regretted it due to cost and effort. I have to admit it's cool and the only one I've ever seen. I am not sure how they cut the final version but it was with heat...also second the motion to cut the gl*** first and fit the opening to it. Sorry I don't have any better pics.
    ElBrujo likes this.
  16. 1947vert
    1947vert
    from Minnesota
    Leevon your neighbors truck is right on. Simply a gorgeous truck.
  17. Just a thought, before you whack 2", try 1" and see if you like it, then 1 1/2" if you want more, etc.
    The subtle chop works so much better on TF's
  18. 2Loose
    2Loose
    I've thought about doing a slight chop on either or both of my '55 and '58 pickups. The gl*** issue has stopped me every time, living in Hawaii has it's drawbacks on finding the right parts for jobs like this. My '55 is a small back window, the '58 is a large back window.....
    I think it would look great with at least a 2" cut top....
  19. ElBrujo
    ElBrujo
    Here ya go. Photochop courtesy of madfish.
  20. ElBrujo
    ElBrujo
    Will do! Thanks.
  21. ElBrujo
    ElBrujo
    Thanks
  22. ElBrujo
    ElBrujo
    That is also something I have thought about but the end result is so awesome that I'm willing to risk it. Beautiful truck BTW.
  23. Mr48chev
    I would be very serious about inquiring as to the exact cost of the custom formed gl*** as that may be a budget blower before you start unless you have very deep pockets.
    Hnstray likes this.
  24. chopolds
    chopolds
    from howell, nj
    I was just goint to say what Mr48chev said. You better look at the cost of having custom curved gl*** made for your truck. From what I know fo a couple other jobs like that, it is extremely expensive!
    When we did the Kopper Kart, the aftermarket rear window, the big window, was laminated, and we could cut it.
  25. alchemy
    alchemy
    Do you have a quote from them yet? I bet it's in the thousands. Do yourself a favor and find out how much a new custom windshield and back window is gonna cost.
  26. flynstone
    flynstone
    when my friend chopped his 59 impala it was 2k for the back and he had to make the buck. the frt they were able to cut after 4 trys at 350 each....... check on the gl*** first unless money is no object
  27. ElBrujo
    ElBrujo
    I believe I didn't specify, but it's American made aftermarket gl***. It runs $350 before tax & shipping. And they charge $500 to cut it. I called Chris again this morning and he said to most definitely chop it first and then make have the gl*** cut to the new shape. Now the stainless part is where I haven't found any info on. I have a deluxe cab and want to run the stainless that goes around the gl*** and the stainless that goes inside the weatherstripping. Has anyone cut and welded these?
  28. chopolds
    chopolds
    from howell, nj
    The simple answer is cut it to fit, and carefully weld it back together. I know guys have used MIGs but I find that the wire is often a slightly different color than the stainless on old cars. I TIG them, using thin strips I cut off extra trim, so it's the same alloy and color. But it ain't easy! The trim is very thin and easy to blow holes in. You also have to fine finish them perfectly before polishing, and that also takes care and time.
  29. lewk
    lewk
    from Mt
  30. ElBrujo
    ElBrujo
    Like the gl*** cutting, this is one of those projects which I'm going to have to hire a professional. I'm a body man/painter by trade and I want to do as much on my project as possible, but this is one of those things which I'm not ashamed to say that I can't handle.
