Hot Rods What engine is this?
Discussion in 'The Hokey Ass Message Board' started by propwash, Sep 15, 2014.
  1. propwash
    propwash
    from Las Vegas
    I see the distributor in front, but it's angled, so I'm thinking not an sbf. Asking for help telling me what it is.
  2. squirrel
    that is an AMC
  3. propwash
    propwash
    from Las Vegas
    Jim - any idea what size? 304? 401? other? I thought maybe AMC also, but do they really have that many v/c hold-down bolts?
  4. propwash
    propwash
    from Las Vegas
    Jim - I just "googled" AMC V8 - you are correct. Don't think there's any way to tell the size, unless all orange means something. Thanks much for your quick answer.
  5. kidcampbell71
    kidcampbell71
    ha ha you may be in luck bud. Can you get under the engine and look up? Check the motor mount area on the block.......both sides. Tell me what you see. Should be a 3 digit number on each side of the block in those areas. Hopefully the engine has its original internals.
